  2. Matrix (Synapse/Element)
  3. Customizing Element Homepage
8 Posts 4 Posters 3.2k Views 4 Watching
  • ericdrgnE Offline
    ericdrgnE Offline
    ericdrgn
    Can anyone help me customize the element homepage a little more? I was able to use the background, header, and footer just fine using config.json but is there a way to customize a little bit more?
    For example this https://webchat.kde.org/#/welcome doesn't have the "Welcome to Element" piece, it has everything customized. Any thoughts? Or is this not possible within Cloudron yet?
    ianhyzyI girishG 2 Replies Last reply
    • ericdrgnE ericdrgn
      ianhyzyI Offline
      ianhyzyI Offline
      ianhyzy
        @ericdrgn Do you know if the upstream project supports customization of the home page? I did a quick search but could not find anything useful immediately.
        ericdrgnE 1 Reply Last reply
          I found welcomeUrl in https://github.com/vector-im/element-web/blob/develop/docs/config.md which says "Initial content shown on the outside of the app when not logged in. Defaults to welcome.html supplied with Element.". There's however no examples.
          Another idea is to of course is to ask the KDE guys on matrix 🙂 (I am an ex-KDE developer btw).
          M 1 Reply Last reply
            ericdrgnE Offline
            ericdrgnE Offline
            ericdrgn
            @girish Sadly that was the same problem I ran into. I will reach out to the KDE guys like you mentioned, but figured I would check here first.
              M Offline
              M Offline
              martin
              @ericdrgn
              Hi, I am also looking to customize this page, and wondered how you got on so far?
              ianhyzyI 1 Reply Last reply
                M Offline
                M Offline
                martin
                @girish
                Just as a Matrix-y and KDE-ish aside, I've been following development of the Neochat client, which seems to be coming along nicely.
                And I'm curious as to which KDE thing you were on (I use KDE mainly at the moment) ..
                • M martin
                  @ericdrgn
                  ianhyzyI Offline
                  ianhyzyI Offline
                  ianhyzy
                  @martin you can open the HTML file in the file browser app or via SSH and edit it. At least for me, it appears to persist across updates.
