  3. Graphite stuck starting
5 Posts 3 Posters 1.4k Views 3 Watching
  • eyecreateE Offline
    eyecreateE Offline
    eyecreate
    On my cloudron instance, I can't see any disk stats because graphite is stuck starting. There seems to be a migration issue or something.
    Mar 14 17:34:59 Apply all migrations: account, admin, auth, contenttypes, dashboard, events, sessions, tagging, tags, url_shortener
    Mar 14 17:34:59 Running migrations:
    Mar 14 17:34:59 Traceback (most recent call last):
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/db/backends/utils.py", line 82, in _execute
    Mar 14 17:34:59 return self.cursor.execute(sql)
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/db/backends/sqlite3/base.py", line 381, in execute
    Mar 14 17:34:59 return Database.Cursor.execute(self, query)
    Mar 14 17:34:59 sqlite3.OperationalError: table "account_mygraph" already exists
    Mar 14 17:34:59 The above exception was the direct cause of the following exception:
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/bin/django-admin.py", line 5, in <module>
    Mar 14 17:34:59 management.execute_from_command_line()
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/core/management/__init__.py", line 381, in execute_from_command_line
    Mar 14 17:34:59 utility.execute()
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/core/management/__init__.py", line 375, in execute
    Mar 14 17:34:59 self.fetch_command(subcommand).run_from_argv(self.argv)
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/core/management/base.py", line 323, in run_from_argv
    Mar 14 17:34:59 self.execute(*args, **cmd_options)
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/core/management/base.py", line 364, in execute
    Mar 14 17:34:59 output = self.handle(*args, **options)
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/core/management/base.py", line 83, in wrapped
    Mar 14 17:34:59 res = handle_func(*args, **kwargs)
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/core/management/commands/migrate.py", line 232, in handle
    Mar 14 17:34:59 post_migrate_state = executor.migrate(
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/db/migrations/executor.py", line 117, in migrate
    Mar 14 17:34:59 state = self._migrate_all_forwards(state, plan, full_plan, fake=fake, fake_initial=fake_initial)
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/db/migrations/executor.py", line 147, in _migrate_all_forwards
    Mar 14 17:34:59 state = self.apply_migration(state, migration, fake=fake, fake_initial=fake_initial)
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/db/migrations/executor.py", line 245, in apply_migration
    Mar 14 17:34:59 state = migration.apply(state, schema_editor)
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/db/migrations/migration.py", line 124, in apply
    Mar 14 17:34:59 operation.database_forwards(self.app_label, schema_editor, old_state, project_state)
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/db/migrations/operations/models.py", line 92, in database_forwards
    Mar 14 17:34:59 schema_editor.create_model(model)
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/db/backends/base/schema.py", line 307, in create_model
    Mar 14 17:34:59 self.execute(sql, params or None)
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/db/backends/base/schema.py", line 137, in execute
    Mar 14 17:34:59 cursor.execute(sql, params)
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/db/backends/utils.py", line 67, in execute
    Mar 14 17:34:59 return self._execute_with_wrappers(sql, params, many=False, executor=self._execute)
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/db/backends/utils.py", line 76, in _execute_with_wrappers
    Mar 14 17:34:59 return executor(sql, params, many, context)
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/db/backends/utils.py", line 84, in _execute
    Mar 14 17:34:59 return self.cursor.execute(sql, params)
    Mar 14 17:34:59 File "/usr/lib/python3/dist-packages/django/db/utils.py", line 89, in __exit__
    Mar 14 17:34:59 raise dj_exc_value.with_traceback(traceback) from exc_value
    Mar 14 17:34:59 django.db.utils.OperationalError: table "account_mygraph" already exists
    Mar 14 17:34:59 Applying account.0001_initial...
    Mar 14 17:35:52 Graphite already initialized
    Mar 14 17:35:52 Operations to perform:
    Mar 14 17:35:52 Apply all migrations: account, admin, auth, contenttypes, dashboard, events, sessions, tagging, tags, url_shortener
    Mar 14 17:35:52 Running migrations:
    Mar 14 17:35:52 Traceback (most recent call last):
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/db/backends/utils.py", line 82, in _execute
    Mar 14 17:35:52 return self.cursor.execute(sql)
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/db/backends/sqlite3/base.py", line 381, in execute
    Mar 14 17:35:52 return Database.Cursor.execute(self, query)
    Mar 14 17:35:52 sqlite3.OperationalError: table "account_mygraph" already exists
    Mar 14 17:35:52 The above exception was the direct cause of the following exception:
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/bin/django-admin.py", line 5, in <module>
    Mar 14 17:35:52 management.execute_from_command_line()
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/core/management/__init__.py", line 381, in execute_from_command_line
    Mar 14 17:35:52 utility.execute()
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/core/management/__init__.py", line 375, in execute
    Mar 14 17:35:52 self.fetch_command(subcommand).run_from_argv(self.argv)
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/core/management/base.py", line 323, in run_from_argv
    Mar 14 17:35:52 self.execute(*args, **cmd_options)
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/core/management/base.py", line 364, in execute
    Mar 14 17:35:52 output = self.handle(*args, **options)
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/core/management/base.py", line 83, in wrapped
    Mar 14 17:35:52 res = handle_func(*args, **kwargs)
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/core/management/commands/migrate.py", line 232, in handle
    Mar 14 17:35:52 post_migrate_state = executor.migrate(
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/db/migrations/executor.py", line 117, in migrate
    Mar 14 17:35:52 state = self._migrate_all_forwards(state, plan, full_plan, fake=fake, fake_initial=fake_initial)
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/db/migrations/executor.py", line 147, in _migrate_all_forwards
    Mar 14 17:35:52 state = self.apply_migration(state, migration, fake=fake, fake_initial=fake_initial)
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/db/migrations/executor.py", line 245, in apply_migration
    Mar 14 17:35:52 state = migration.apply(state, schema_editor)
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/db/migrations/migration.py", line 124, in apply
    Mar 14 17:35:52 operation.database_forwards(self.app_label, schema_editor, old_state, project_state)
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/db/migrations/operations/models.py", line 92, in database_forwards
    Mar 14 17:35:52 schema_editor.create_model(model)
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/db/backends/base/schema.py", line 307, in create_model
    Mar 14 17:35:52 self.execute(sql, params or None)
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/db/backends/base/schema.py", line 137, in execute
    Mar 14 17:35:52 cursor.execute(sql, params)
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/db/backends/utils.py", line 67, in execute
    Mar 14 17:35:52 return self._execute_with_wrappers(sql, params, many=False, executor=self._execute)
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/db/backends/utils.py", line 76, in _execute_with_wrappers
    Mar 14 17:35:52 return executor(sql, params, many, context)
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/db/backends/utils.py", line 84, in _execute
    Mar 14 17:35:52 return self.cursor.execute(sql, params)
    Mar 14 17:35:52 File "/usr/lib/python3/dist-packages/django/db/utils.py", line 89, in __exit__
    Mar 14 17:35:52 raise dj_exc_value.with_traceback(traceback) from exc_value
    Mar 14 17:35:52 django.db.utils.OperationalError: table "account_mygraph" already exists
    Mar 14 17:35:52 Applying account.0001_initial...
    Is there a way I can correct this in the filesystem or is a patch needed?
    murgeroM 1 Reply Last reply
    • eyecreateE eyecreate
      murgeroM Offline
      murgeroM Offline
      murgero
      @eyecreate Give the graphite service some more RAM. I had to do this a long time ago, thought it was patch but as a quick work around give it a try.
      https://urgero.org
        From another use reporting the same issue, if you don't care about stat history, you can purge the graphite database when running the following commands via SSH into your server:
        docker exec -ti graphite /bin/bash
        > rm -rf /var/lib/graphite/* && rm /var/lib/graphite/.initialized
        Then restart the service via the dashboard.
        edited the .initialized path
        eyecreateE 1 Reply Last reply
          eyecreateE Offline
          eyecreateE Offline
          eyecreate
          @nebulon Adding memory didn't do anything, but taking your direction to erase database ended up working out.
          Note that /var/lib/.initialized didn't exist and was in the graphite directory. Also, I had to manually stop and start the container and execute the command right away or docker wouldn't let me do anything because the container was in the process of restarting/starting.
            @eyecreate ah good catch about the .initialized file, I've adjusted my snippet.
