  2. Guacamole
  3. Setting up Duo with Guacamole
Scheduled Pinned Locked Moved Solved Guacamole
5 Posts 2 Posters 3.0k Views 2 Watching
  • E Offline
    E Offline
    eball218
    Can anyone explain how to implement Duo 2fa? I have successfully uploaded the .jar file to the extensions folder. I have also already prepared Duo and have all the needed items but i am unable to update or modify the guacamole.properties as required to complete this setup. Any guidance would be greatly appreciated.
    girishG 2 Replies Last reply
    • E eball218
      @eball218 I was reading up https://guacamole.apache.org/doc/gug/duo-auth.html and it seems that as you say guacamole.properties has to be editable to finish the setup. I will fix up the package shortly.
        Added this in https://git.cloudron.io/cloudron/guacamole-app/-/commit/10e944b6be5d09e7c1ee07efad017be0bdd86c01 .
        • E eball218
          @eball218 I have pushed an update to guacamole. You can update by app configure -> Updates -> Check for updates and then Update . Once updated, you will see a file named guacamole.properties in the File manager. You can add the properties there and restart the app.
          • E Offline
            E Offline
            eball218
            @girish Thank you for your prompt action on this. I have tested and all is now working as intended.
