  2. N8N
  3. Using handlebars.js
Using handlebars.js
Scheduled Pinned Locked Moved Solved N8N
17 Posts 6 Posters 8.8k Views 7 Watching
  • jeauJ
    jeauJ
    jeau
    I would like activate handelbars (an extension to the Mustache templating language) for Function-nodes so I've had this line in /app/data/.env
    export NODE_FUNCTION_ALLOW_EXTERNAL=handlebars
    but, it doesn't work when I execute my workflow, I have this error
    "Cannot find module 'handlebars'"
    • jeauJ jeau
      @jeau I have to check in the package, but looks like we could add the required handlebars node module then in the package directly to get it supported if this is a common thing in n8n
        The package already has N8N_CUSTOM_EXTENSIONS="/app/data/custom" though I don't know if this means that a user can npm install handlebars in that directory and use it. Maybe @BrutalBirdie knows.
          BrutalBirdieB
          BrutalBirdieB
          @girish Got no clue either 😄
          Will have to take a look at it.
          • BrutalBirdieB BrutalBirdie
            @brutalbirdie looks like N8N_CUSTOM_EXTENSIONS is for custom nodes - https://docs.n8n.io/getting-started/installation/advanced/configuration.html#examples and not for custom node modules
            jeauJ 1 Reply Last reply
              jeauJ
              jeauJ
              jeau
              thanks to all, I am a newbe with n8n
              @girish @BrutalBirdie this doc indicate that for security reasons, importing modules is restricted by default in the Function-Nodes and that it is possible to lift that restriction by setting the following environment variables:
              • NODE_FUNCTION_ALLOW_BUILTIN: For builtin modules
              • NODE_FUNCTION_ALLOW_EXTERNAL: For external modules sourced from n8n/node_modules directory
              So I created a node_modules directory in /app/data/ and installed in it the module handlebars with the command npm install handlebars but it doesn't work. I also tried in /app/data/.n8n directory with the same result.
              • jeauJ jeau
                @jeau I think the module has to be installed in the docker image itself. Is there a way to not use handlebars? Just curious why it's needed. Maybe we can add it to the n8n image itself.
                  jeauJ
                  jeauJ
                  jeau
                  wrote on last edited by jeau
                  @girish you can read this discussion https://community.n8n.io/t/text-templating-node/1965
                  handelbars is a template system to facilitate the creation of html document pages, https://handlebarsjs.com/
                  in my case, I want to get information from baserow tables and use n8n to generate reports and send them by mails
                  • jeauJ jeau
                    @jeau there is a env var NODE_PATH that tells node where to find additional node modules. So, you can set the variable in /app/data/env like NODE_PATH=/app/data/modules and then in Web Terminal:
                    mkdir /app/data/modules
                    cd /app/data/modules
                    Restart the app afterwards.
                      jeauJ
                      jeauJ
                      jeau
                      @girish thanks, however I have this errors after passing the command npm install handlebars
                      npm ERR! code EROFS
                      npm ERR! syscall open
                      npm ERR! path /root/.npm/_cacache/tmp/2122bb8f
                      npm ERR! errno -30
                      npm ERR! rofs EROFS: read-only file system, open '/root/.npm/_cacache/tmp/2122bb8f'
                      npm ERR! rofs Often virtualized file systems, or other file systems
                      npm ERR! rofs that don't support symlinks, give this error.
                      I tried npm install --prefix /app/data/modules handlebars but the result was the same
                      however, I have already successfully installed handelbars before, but I forgot how to do it 😞
                      robiR girishG 2 Replies Last reply
                      • jeauJ jeau
                        npm ERR! code EROFS
                        npm ERR! errno -30
                        • jeauJ jeau
                          npm ERR! code EROFS
                          npm ERR! errno -30
                          @jeau I can fix that . Can you try npm install handlebars --cache /tmp/foo in the meantime ?
                            jeauJ
                            jeauJ
                            jeau
                            @girish I went back to a fresh installation, because I had not checked the changes of the recent updates. This fix allows me to install handelbars. But it still doesn't work, I still get the message Cannot find module 'handlebars' with this example.
                            My session:
                            root@XYZ:/app/data# vi env
                            root@XYZ:/app/data# cat env
                            # Set the logging level to 'debug'
                            export EXECUTIONS_DATA_SAVE_MANUAL_EXECUTIONS=true
                            export EXECUTIONS_DATA_SAVE_ON_ERROR=all
                            export EXECUTIONS_DATA_SAVE_ON_SUCCESS=all
                            export N8N_LOG_LEVEL=info
                            export NODE_PATH=/app/data/modules
                            root@XYZ:/app/data# mkdir modules
                            root@XYZ:/app/data# cd /app/data/modules
                            root@XYZ:/app/data/modules# npm install handlebars --cache /tmp/foo
                            npm WARN saveError ENOENT: no such file or directory, open '/app/data/modules/package.json'
                            npm notice created a lockfile as package-lock.json. You should commit this file.
                            npm WARN enoent ENOENT: no such file or directory, open '/app/data/modules/package.json'
                            npm WARN modules No description
                            npm WARN modules No repository field.
                            npm WARN modules No README data
                            npm WARN modules No license field.
                            + handlebars@4.7.7
                            added 6 packages from 39 contributors and audited 6 packages in 0.834s
                            found 0 vulnerabilities
                            │              npm update check failed              │
                            │        Try running with sudo or get access        │
                            │       to the local update config store via        │
                            │ sudo chown -R $USER:$(id -gn $USER) /root/.config │
                            root@XYZ:/app/data/modules# ls -al
                            total 16
                            drwxr-xr-x 3 root     root     4096 Oct  9 16:25 .
                            drwxr-xr-x 8 cloudron cloudron 4096 Oct  9 16:23 ..
                            drwxr-xr-x 9 root     root     4096 Oct  9 16:25 node_modules
                            -rw-r--r-- 1 root     root     1711 Oct  9 16:25 package-lock.json
                            root@XYZ:/app/data/modules# ls -al node_modules/
                            total 36
                            drwxr-xr-x 9 root root 4096 Oct  9 16:25 .
                            drwxr-xr-x 3 root root 4096 Oct  9 16:25 ..
                            drwxr-xr-x 2 root root 4096 Oct  9 16:25 .bin
                            drwxr-xr-x 6 root root 4096 Oct  9 16:25 handlebars
                            drwxr-xr-x 4 root root 4096 Oct  9 16:25 minimist
                            drwxr-xr-x 2 root root 4096 Oct  9 16:25 neo-async
                            drwxr-xr-x 4 root root 4096 Oct  9 16:25 source-map
                            drwxr-xr-x 5 root root 4096 Oct  9 16:25 uglify-js
                            drwxr-xr-x 4 root root 4096 Oct  9 16:25 wordwrap
                            • jeauJ jeau
                              My session:
                              + handlebars@4.7.7
                              total 16
                              total 36
                              @jeau I have fixed the package to support this. Please try https://docs.cloudron.io/apps/n8n/#custom-node-modules with the latest package 1.16.0
                              jeauJ rmdesR 2 Replies Last reply
                                jeauJ
                                jeauJ
                                jeau
                                @girish great thank's, it works 👍
                                S 1 Reply Last reply
                                  rmdesR
                                  rmdesR
                                  rmdes
                                  @girish Two questions:
                                  Do I understand correctly that this is the only way to install external modules ?
                                  Is there anything that need to be done (beside app restart) after adding the line in the env file?
                                  • rmdesR rmdes
                                    @rmdes right, if you want external modules, we have to fix the package. The modules are hardcoded in the Dockerfile.
