  2. Announcements
  3. Baserow
Baserow
6 Posts 3 Posters 2.8k Views 4 Watching
  • nebulonN Away
    nebulonN Away
    Hi everyone!
    Thanks to all the help from @bram and feedback from other members here, we are able to finally publish a stable app package version 1.0.0 now.
    Forum section: https://forum.cloudron.io/category/136/baserow
    Docs: https://docs.cloudron.io/apps/baserow/
    App Library: https://www.cloudron.io/store/io.baserow.cloudronapp.html
    Package Repo: https://git.cloudron.io/cloudron/baserow-app
    As always, we will fixup the docs and the package as we go from here based on your feedback. The stable release marks a point, where we are confident enough that data migration for updates will be possible without interruption.
    brianbB 1 Reply Last reply
    10
      Hi everyone!
      brianbB Offline
      brianbB Offline
      brianb
      @nebulon What category on the https://www.cloudron.io/store/index.html# page is Baserow and related NocoDB on? I think that page is missing a category because I don't see either of those apps listed in the existing categories.
      • brianbB brianb
        girishG Do not disturb
        @brianb good question. The category is derived from tags - https://git.cloudron.io/cloudron/baserow-app/-/blob/master/CloudronManifest.json#L16 .
        I will create a "no-code" section for baserow.
          brianbB Offline
          brianbB Offline
          brianb
          @girish "database" tag would include baserow and nocodb, in nocodb it has "nocode" without the dash for a tag.
          • brianbB brianb
            @brianb https://www.cloudron.io/store/index.html#no-code .
            I went for the one with hyphen since that's the wikipedia article has - https://en.wikipedia.org/wiki/No-code_development_platform . The tags are also used in search, so we tend to add some related terms (and sometimes with intentional typos). Let me know if I should add more search terms!
            • girishG Do not disturb
              For some reason, the category does not appear on the left pane sometimes... I will ask @nebulon to take a look.
