  3. Connection Reset
Connection Reset
nginxapache
6 Posts 3 Posters 3.4k Views 3 Watching
  • S
    S
    SolarSimon
    Hi there,
    I have some trouble with my server.
    When I want to connect to cloudron my browser says: ERR_CONNECTION_RESET
    What I did:
    • My Server is running at hetzner, I did a rescale.
    • I wanted to use my domain for a different Server, so changed DNS configuration. And returned to original setting.
    Since than, I'm having the connection Issue.
    What I tried:
    • I did not find a solution so I reinstalled cloudron
    • I wannted to upload and restore my backups, but apparently it's not that easy
    • With snapshot of my Server I returned to the "connection_reset" state
    Any suggestions to fix connection?
    Or to setup and restore?
    • S SolarSimon
      Hi there,
      What I did:
      What I tried:
      @solarsimon have you checked the various things we mention at https://docs.cloudron.io/troubleshooting/#unreachable-dashboard ?
      If those don't help in your case, maybe you can send us a mail to support@cloudron.io with further details about your domain and possibly enable remote SSH for us to debug this directly.
      S 1 Reply Last reply
        S
        S
        SolarSimon
        @nebulon said in Connection Reset:
        I did it again with some more fokus.
        Result: nginx wasn't active.
        I found out port 80 already in use. Apache is installed
        I did these steps and cloudron was back online
        netstat -tulpn | grep --color :u6e80:
        fuser -k 80/tcp
        nginx -t
        service nginx start
        But after restart of the server, same issue.
        Where is apache coming from? I operated this server only by cloudron.
        Last action there, I installed git lab.
        So now I have to stop apache and start nginx after every reboot.
        Should i remove apache?
        apt purge apache2
          apache should not be installed. Have you installed anything on the side besides Cloudron on your server? This is generally not supported due to issues like you hit here. Sometimes though the VPS provider images come with extra packages though. Would be good to understand if this is the case for you?
          • S SolarSimon
            fuser -k 80/tcp
            nginx -t
            service nginx start
            apt purge apache2
            @solarsimon said in Connection Reset:
            apt purge apache2
            yes, in addition, you might have to stop the apache2 service using systemctl stop apache2 and maybe also systemctl disable apache2 for good measure . After that, systemctl restart nginx should have nginx running.
              apt purge apache2
              S
              S
              SolarSimon
              I did a clean installation and restored a backup.
              Since than, everything is working fine.
              Thanks
