  2. Off-topic
  3. daedalOS
daedalOS
13 Posts 3 Posters 5.9k Views 3 Watching
  • timconsidineT
    This is pretty cool : https://dustinbrett.com/
    • Source Code: https://github.com/DustinBrett/daedalOS
    robiR ? 2 Replies Last reply
      @timconsidine Cool, now we can run cloudron UI from a cloudron container app!
      Package it!
        Package it!
        @robi said in daedalOS:
        Package it!
        I wish I was capable !
        But I will take a look out of interest.
          A Former User
          @timconsidine I created a web-based portfolio, It replicates the features of windows 10 named Windfolio (Windows + Portfolio). The user has to just configure the user.config file and can easily deploy on the netlify.
          URL: https://www.arsh.dev/link/windfolio/
          GitHub: https://github.com/arshsahzad/Windfolio
          Config File: https://github.com/arshsahzad/Windfolio/blob/main/src/utils/data/user.config.js
          timconsidineT 2 Replies Last reply
          • ? A Former User
            @arshsahzad amazing, thank you ! 🍾
            I was starting to look at it, but got distracted.
            This saves a lot of time, thank you.
            I will for sure give it a go.
            ? 1 Reply Last reply
              A Former User
              @timconsidine If you need any help regarding configuration, just let me know
              • ? A Former User
                @arshsahzad thank you
                Diverted on trying to get some other more urgent self-hosting
                Tried Penpot in Caprover, but exporting doesn't work
                Got it working eventually on my docker VPS
                Looking forward to finding some time for this soon
                • ? A Former User
                  @arshsahzad do files created in Word or Excel in the container save ?
                  I didn't see a save button
                  maybe of persistence of saved files ?
                  • ? A Former User
                    @arshsahzad I got the repo built for Cloudron and installed.
                    Biggest question I have : does the browser work fully ?
                    Seems to go to (render) some sites but not others.
                    ? robiR 2 Replies Last reply
                      A Former User
                      @timconsidine said in daedalOS:
                      @arshsahzad do files created in Word or Excel in the container save?
                      No, It does not work right now but has plan in windows 11 theme
                        A Former User
                        Yes, the browser works perfectly
                        • ? A Former User
                          @arshsahzad said in daedalOS:
                          I find it works on some/many sites
                          But it doesn't on others e.g. https://www.bbc.co.uk
                          EDIT : just to be clear, that's on my deployment on my Cloudron
                            where's the repo?
                            or is it easy to install into another app?
