  3. After a reboot, nginx does not start
nginxcertificates
10 Posts 4 Posters 6.3k Views 5 Watching
  • jeauJ Offline
    jeauJ Offline
    jeau
    I have these messages after a reboot attempt
    root@emendesfr-vt-prod-cloudron:/home/client_176_2# systemctl restart nginx
    Job for nginx.service failed because the control process exited with error code.
    See "systemctl status nginx.service" and "journalctl -xe" for details.
    root@emendesfr-vt-prod-cloudron:/home/client_176_2# systemctl status nginx.service
    ● nginx.service - nginx - high performance web server
       Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
      Drop-In: /etc/systemd/system/nginx.service.d
               └─cloudron.conf
       Active: failed (Result: exit-code) since Tue 2022-02-15 23:23:07 UTC; 5s ago
         Docs: http://nginx.org/en/docs/
      Process: 27606 ExecStart=/usr/sbin/nginx -c /etc/nginx/nginx.conf (code=exited, status=1/FAILURE)
    févr. 15 23:23:07 emendesfr-vt-prod-cloudron systemd[1]: nginx.service: Service hold-off time over, scheduling restart.
    févr. 15 23:23:07 emendesfr-vt-prod-cloudron systemd[1]: nginx.service: Scheduled restart job, restart counter is at 5.
    févr. 15 23:23:07 emendesfr-vt-prod-cloudron systemd[1]: Stopped nginx - high performance web server.
    févr. 15 23:23:07 emendesfr-vt-prod-cloudron systemd[1]: nginx.service: Start request repeated too quickly.
    févr. 15 23:23:07 emendesfr-vt-prod-cloudron systemd[1]: nginx.service: Failed with result 'exit-code'.
    févr. 15 23:23:07 emendesfr-vt-prod-cloudron systemd[1]: Failed to start nginx - high performance web server.
    jeauJ 1 Reply Last reply
    • jeauJ jeau
                 └─cloudron.conf
      jeauJ Offline
      jeauJ Offline
      jeau
      the journalctl -xeresult
      root@emendesfr-vt-prod-cloudron:/home/client_176_2# journalctl -xe
      -- Defined-By: systemd
      -- Support: http://www.ubuntu.com/support
      -- L'unité (unit) nginx.service a échoué, avec le résultat RESULT.
      févr. 15 23:29:20 emendesfr-vt-prod-cloudron systemd[1]: nginx.service: Service hold-off time over, scheduling restart.
      févr. 15 23:29:20 emendesfr-vt-prod-cloudron systemd[1]: nginx.service: Scheduled restart job, restart counter is at 5.
      -- Subject: Le redémarrage automatique d'une unité (unit) a été planifié
      -- Le redémarrage automatique de l'unité (unit) nginx.service a été planifié, en
      -- raison de sa configuration avec le paramètre Restart=.
      févr. 15 23:29:20 emendesfr-vt-prod-cloudron systemd[1]: Stopped nginx - high performance web server.
      -- Subject: L'unité (unit) nginx.service a terminé son arrêt
      -- L'unité (unit) nginx.service a terminé son arrêt.
      févr. 15 23:29:20 emendesfr-vt-prod-cloudron systemd[1]: nginx.service: Start request repeated too quickly.
      févr. 15 23:29:20 emendesfr-vt-prod-cloudron systemd[1]: nginx.service: Failed with result 'exit-code'.
      févr. 15 23:29:20 emendesfr-vt-prod-cloudron systemd[1]: Failed to start nginx - high performance web server.
      -- Subject: L'unité (unit) nginx.service a échoué
      févr. 15 23:29:23 emendesfr-vt-prod-cloudron sshd[31508]: Invalid user test02 from XX.XX.XX.XX port 42620
      févr. 15 23:29:23 emendesfr-vt-prod-cloudron sshd[31508]: pam_unix(sshd:auth): check pass; user unknown
      févr. 15 23:29:23 emendesfr-vt-prod-cloudron sshd[31508]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=92.255.8
      févr. 15 23:29:24 emendesfr-vt-prod-cloudron sshd[31508]: Failed password for invalid user test02 from XX.XX.XX.XX port 42620 ssh2
      févr. 15 23:29:24 emendesfr-vt-prod-cloudron sshd[31508]: Received disconnect from XX.XX.XX.XX port 42620:11: Bye Bye [preauth]
      févr. 15 23:29:24 emendesfr-vt-prod-cloudron sshd[31508]: Disconnected from invalid user test02 XX.XX.XX.XX port 42620 [preauth]
      lines 1530-1561/1561 (END)
      • jeauJ jeau
        @jeau Do you have any stopped apps ? If so, I think the issue is that you have to delete their nginx configs under /home/yellowtent/platformdata/nginx/ (they will have the app id in the filename). After you delete those configs, systemctl restart nginx will bring it back up.
        S 1 Reply Last reply
          To give more context: in a previous release of Cloudron, we started deleting "old certs" ( > 6 months) . The certs of stopped apps is not renewed. This means that the nginx configs of stopped apps start referencing missing cert files and this causes nginx to not start. The fix is simply to remove those nginx configs. You can see which config is causing the issue from journalctl -u nginx -fa .
            jeauJ Offline
            jeauJ Offline
            jeau
            @girish great thanks, it's works. I have to clean up my old stuffs 😉
            However, I have a problem that I noticed before this event.
            I have an application that works but displays this error: Error : Nginx Error - Error reloading nginx: reload exited with code 1 signal null
            • jeauJ jeau
              jeauJ Offline
              jeauJ Offline
              jeau
              @jeau said in After a reboot, nginx does not start:
              it's an active Wordpress app
              • jeauJ jeau
                jeauJ Offline
                jeauJ Offline
                jeau
                I restarted the application and it works correctly now ...
                thanks @girish
                • Z zylstra referenced this topic on
                  S Offline
                  S Offline
                  stoccafisso
                  wrote on last edited by stoccafisso
                  Hi @girish
                  I have a similar problem (missing certificate so nginx does not start)
                  root@my:~# journalctl -u nginx -fa
                  -- Logs begin at Wed 2022-08-03 20:41:55 UTC. --
                  Aug 03 23:45:02 my nginx[17769]: nginx: [emerg] cannot load certificate key "/home/yellowtent/platformdata/nginx/cert/_.domainnamexxxx.info.key": PEM_read_bio_PrivateKey() failed (SSL: error:0906D06C:PEM routines:PEM_read_bio:no start line:Expecting: ANY PRIVATE KEY)
                  I find app config files in /home/yellowtent/platformdata/nginx/applications
                  But the nginx-log messages does not tell what app exactly is creating the problem.
                  May I delete all config files, or do I have to go "trial and error" with each file to figure it out?
                  Where do I find the nginx config files for the app relating to the missing certificate?
                  • S stoccafisso
                    Hi @girish
                    S Offline
                    S Offline
                    stoccafisso
                    Problem solved. I deleted ALL config files and restarted the server.
                    • avatar1024A Offline
                      avatar1024A Offline
                      avatar1024
                      Just wanted to say I've also hit just this issue. Cleaning up the nginx app config files did the trick but I wonder if this can be avoided in the future? Or may be it has already be addressed and I'm only hitting it because of some legacy stuff from previous Cloudron version? (this instance is currently running 7.5.0 but hasn't had a fresh install in a long while).
                      • avatar1024A avatar1024 referenced this topic on
                      • scookeS scooke referenced this topic on
