  2. Meemo
  3. Meemo doesn't load after upgrade from v1.13.2 to v1.14.0
Scheduled Pinned Locked Moved Solved Meemo
3 Posts 2 Posters 1.3k Views 2 Watching
  • svigneauS Offline
    svigneauS Offline
    svigneau
    Meemo doesn't load after upgrading from v1.13.2 to v1.14.0. Only the top bar with the "Meemo" and "About" links is visible but no other content can be accessed. The log returns the following error:
    ERROR (node:1) Warning: Accessing non-existent property 'MongoError' of module exports inside circular dependency
    How could I fix this?
    • svigneauS svigneau
      @svigneau the latest meemo is 1.16.0, can you update all the way ?
      svigneauS 1 Reply Last reply
        svigneauS Offline
        svigneauS Offline
        svigneau
        @girish It worked 🙂 I didn't realize there was another update that fixed the MongoDB issue. Thank you for your help!
