  2. Listmonk
  3. System templates
System templates
Scheduled Pinned Locked Moved Listmonk
8 Posts 3 Posters 3.5k Views 3 Watching
  • WiseMetalheadW Offline
    WiseMetalhead
    Listmonk supports editing system templates. For this we must copy /static directory to an external directory and specify the path with the flag.
    Perhaps it makes sense to put the system templates to /app/data/ and set flag by default?
    • WiseMetalheadW WiseMetalhead
      @WiseMetalhead I did put it in the package (https://git.cloudron.io/cloudron/listmonk-app/-/blob/master/start.sh#L46) but I haven't tested it. You can put static things in /app/data/static.
      WiseMetalheadW 1 Reply Last reply
        WiseMetalhead
        @girish Well, at first glance, it doesn't seem to work.
        If you upload logo.png file to /app/data/static/public/static directory, listmonk continues to display its own logo. Restarting the app does not fix the issue.
        WiseMetalheadW timconsidineT 2 Replies Last reply
          WiseMetalhead
          wrote on last edited by WiseMetalhead
          @WiseMetalhead said in System templates:
          The problem resolved itself. Logo has changed after upgrading Cloudron and rebooting the server.
            timconsidineT Offline
            Just starting to explore Listmonk, so interested to know whether we should be using that directory or just /app/data/static ?
              WiseMetalhead
              @timconsidine said in System templates:
              I think directory tree should look like this.
                @WiseMetalhead Did it change the logo for you inside the app itself? I do see the logo in the login screen but the logo inside remains listmonk's.For reference, I uploaded svg and png.
                  WiseMetalhead
                  @girish The logo has changed only for login screen, subscription page and emails.
