  3. Yellowtent not able to resolve host
3 Posts 2 Posters 1.2k Views 1 Watching
  • D Offline
    D Offline
    Dreamcatch22
    Hello All,
    I updated my server and ran into a problem. My dashboard loads but nothing shows up. I think it is a dns issue but not sure.
    When I run this command: systemctl status box
    I see that yellowtent is "unable to resolve host"
    So, I run this command: "home/yellowtent/box/setup/start.sh" and get this:
    Any ideas or suggestions on how to fix?
    Thanks
    • D Offline
      D Offline
      Dreamcatch22
      This thread was resolved at this URL:
      https://forum.cloudron.io/topic/7213/collectd-is-unable-to-start
      • D Dreamcatch22
        girishG Do not disturb
        @Dreamcatch22 I am fixing the docs to add the resolution of the other thread.
        About the "unable to resolve host" issue, that is just a warning. But to fix it, you have to make sure that your server's hostname (/etc/hostname) has an entry in the /etc/hosts . See https://askubuntu.com/questions/59458/error-message-sudo-unable-to-resolve-host-none for example on how to fix that.
