  3. Mixpost
Mixpost
164 Posts 15 Posters 124.2k Views 18 Watching
  • humptyH
    humptyH
    humpty
    You're using SSL instead of TLS. Yeah, by default, only the mail_from_address had quotations which I found odd. Let me copy yours and see how it goes.
    • humptyH humpty
      @andreasdueren BTW, in your Cloudron > Email, is your mail server name smtp or mail?
      I have it as mail. In credentials.txt, it shows mail as value for the first two lines.
      andreasduerenA
      andreasduerenA
      andreasdueren
      @humptydumpty said in Mixpost:
      Mail server location is mail. Also shows mail in the credentials.
      • humptyH humpty
        andreasduerenA
        andreasduerenA
        andreasdueren
        #143
        Yes it's one of the changes I made. But I reckon both should work.
        • humptyH
          humptyH
          humpty
          No luck yet. I'm starting to suspect my server set up.
          • cloudron #1 ("mail" mail server for incoming + SMTP relay for outgoing)
          • cloudron #2 - mixpost is installed here (no incoming mail + SMTP relay for outgoing)
          All other apps can send and receive mail on cloudron #2 (receiving goes thru CR #1 obviously) just fine so I know the setup works.
          Later today I'll try creating a dedicated SMTP user in Mailgun and using that instead to bypass any possible server config issues.
          • humptyH
            humptyH
            humpty
            Using SMTP relay user credentials didn't work either. In the Mixpost dashboard > admin console > Laravel Horizon, you can see the failed jobs. Here's the code from the failed "reset password" job. In the terminal, you can also see Horizon running the reset password notification job and then it fails (see screenshot).
            Exception
            Illuminate\Queue\MaxAttemptsExceededException: Inovector\Mixpost\Notifications\ResetPassword has been attempted too many times. in /app/data/mixpost-pro-team-app/vendor/laravel/framework/src/Illuminate/Queue/MaxAttemptsExceededException.php:24
            Stack trace:
            #0 /app/data/mixpost-pro-team-app/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(785): Illuminate\Queue\MaxAttemptsExceededException::forJob()
            #1 /app/data/mixpost-pro-team-app/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(519): Illuminate\Queue\Worker->maxAttemptsExceededException()
            #2 /app/data/mixpost-pro-team-app/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(428): Illuminate\Queue\Worker->markJobAsFailedIfAlreadyExceedsMaxAttempts()
            #3 /app/data/mixpost-pro-team-app/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(389): Illuminate\Queue\Worker->process()
            #4 /app/data/mixpost-pro-team-app/vendor/laravel/framework/src/Illuminate/Queue/Worker.php(176): Illuminate\Queue\Worker->runJob()
            #5 /app/data/mixpost-pro-team-app/vendor/laravel/framework/src/Illuminate/Queue/Console/WorkCommand.php(137): Illuminate\Queue\Worker->daemon()
            #6 /app/data/mixpost-pro-team-app/vendor/laravel/framework/src/Illuminate/Queue/Console/WorkCommand.php(120): Illuminate\Queue\Console\WorkCommand->runWorker()
            #7 /app/data/mixpost-pro-team-app/vendor/laravel/horizon/src/Console/WorkCommand.php(51): Illuminate\Queue\Console\WorkCommand->handle()
            #8 /app/data/mixpost-pro-team-app/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Laravel\Horizon\Console\WorkCommand->handle()
            #9 /app/data/mixpost-pro-team-app/vendor/laravel/framework/src/Illuminate/Container/Util.php(41): Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
            #10 /app/data/mixpost-pro-team-app/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure()
            #11 /app/data/mixpost-pro-team-app/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(35): Illuminate\Container\BoundMethod::callBoundMethod()
            #12 /app/data/mixpost-pro-team-app/vendor/laravel/framework/src/Illuminate/Container/Container.php(662): Illuminate\Container\BoundMethod::call()
            #13 /app/data/mixpost-pro-team-app/vendor/laravel/framework/src/Illuminate/Console/Command.php(211): Illuminate\Container\Container->call()
            #14 /app/data/mixpost-pro-team-app/vendor/symfony/console/Command/Command.php(326): Illuminate\Console\Command->execute()
            #15 /app/data/mixpost-pro-team-app/vendor/laravel/framework/src/Illuminate/Console/Command.php(180): Symfony\Component\Console\Command\Command->run()
            #16 /app/data/mixpost-pro-team-app/vendor/symfony/console/Application.php(1096): Illuminate\Console\Command->run()
            #17 /app/data/mixpost-pro-team-app/vendor/symfony/console/Application.php(324): Symfony\Component\Console\Application->doRunCommand()
            #18 /app/data/mixpost-pro-team-app/vendor/symfony/console/Application.php(175): Symfony\Component\Console\Application->doRun()
            #19 /app/data/mixpost-pro-team-app/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(201): Symfony\Component\Console\Application->run()
            #20 /app/data/mixpost-pro-team-app/artisan(35): Illuminate\Foundation\Console\Kernel->handle()
            #21 {main}
            Exception Context
            null
            Data
            "notifiables": {
            "class": "Inovector\Mixpost\Models\User",
            "id": [
            "relations": [
            "connection": "mysql",
            "collectionClass": null
            "notification": {
            "token": "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX",
            "id": "XXXXXXXXXXXXXXXXXXXXXXXXXX",
            "locale": "en-GB"
            "channels": [
            "mail"
            Note: XXXXXXX values are hidden for privacy
            @lao9s Can you please take a look at this? P.S. I opened a ticket on discord that went unanswered.
              @humptydumpty just to double check credentials, you can try the swaks CLI tool in the web terminal. See https://docs.cloudron.io/packaging/addons/#sendmail for an example
                @andreasdueren said in Mixpost:
                The mail server location is for the "external facing" domain name. So, it would be mail.domain.com for the external world. The mail that you use in the env variables is the internal DNS i.e the mail container is named mail internally. Both these are totally different! mail containers name will not change in the foreseeable future but mail.domain.com could be changed by user to whatever they want.
                • humptyH humpty
                  andreasduerenA
                  andreasduerenA
                  andreasdueren
                  @humptydumpty I'm not using my Cloudron for incoming mail either. So I don't think this is an issue.
                  • humptyH
                    humptyH
                    humpty
                    I'm not sure if I'm using the swaks command right. In the app's terminal, I typed swaks it said To, I pasted the >swaks bla bla (first line), it said connection refused on port 25. Did the same for the second line and got the same result.
                    Anyway, I think there's a mistake in the docs: https://docs.cloudron.io/packaging/addons/#sendmail where it says CLOUDRON_MAIL_DOMAIN= # the domain name to use for email sending (i.e username@domain) shouldn't it be mydomain.com and not username@domain?
                    • jdaviescoatesJ
                      All this just makes it clear to me that this app needs packaging so everything Just Works, as is the Cloudron way.
                      • humptyH humpty
                        @humptydumpty you should be able to cut and paste the command as-is and it will work. The port is not 25, it's 2525
                        I will fix the typo in the docs, but it's trying to say the "i.e the domain part of username@domain"
                        humptyH 1 Reply Last reply
                          humptyH
                          humptyH
                          humpty
                          #152
                          @girish I received the test emails that I sent to my Protonmail address! What does that mean in terms of the app not sending the reset email?
                            @humptydumpty I guess it means it is either a configuration issue or a mixpost issue because Cloudron side is OK
                            • andreasduerenA
                              andreasduerenA
                              andreasdueren
                              @humptydumpty here is my complete .env file in case there is something else in there that's useful:
                              Did you activate MIXPOST_FORGOT_PASSWORD=true for example?
                              # You app name. It is usually equal to the name of your project.
                              APP_NAME='tld.ld'
                              # Your application environment. If you are ready for production, set 'production'
                              APP_ENV=production
                              # Is used to encrypt and decrypt sensitive data. Generate it with: 'php artisan key:generate'
                              APP_KEY=base64:yfWnd+DKiAnIPluqqzkREDlLGdqXoxibScsdyFjmIwo=
                              # Debug mode. If the environment is in production, we recommend setting it to 'false'
                              APP_DEBUG=false
                              # URL of your application. Important: it is not allowed to be a slash at the end of the url.
                              APP_URL=https://app.tld.ld
                              APP_DOMAIN=app.tld.ld
                              # Mysql connection setup
                              DB_CONNECTION=mysql # Change this only if you know what you are doing
                              DB_HOST=mysql
                              DB_PORT=3306
                              DB_DATABASE="250d30918200a8b2"
                              DB_USERNAME="250d30918200a8b2"
                              DB_PASSWORD="06c15ecba68b9e77baf5f6ab246dff2dfd6a2676479c46a1"
                              # Redis connection setup
                              REDIS_HOST=redis-ef2a63d9-1366-42fe-a555-87818d6f1633
                              REDIS_PASSWORD=683300f802ec17947a4a1c9fbe0951c7aed452106c00c257
                              REDIS_PORT=6379
                              # Default Queue Connection Name
                              QUEUE_CONNECTION=redis
                              # Default Cache Store
                              CACHE_DRIVER=redis
                              # Default Session Driver
                              SESSION_DRIVER=redis
                              # Default log channel for Mixpost
                              MIXPOST_LOG_CHANNEL=mixpost
                              # change URL prefix "/mixpost"
                              MIXPOST_CORE_PATH="a"
                              # The disk on which to store added files. Disks: "public", "s3". For "s3" you should fill in the AWS_* credentials below.
                              MIXPOST_DISK=public
                              # AWS Credentials
                              These are filled in but not in use.
                              # SMTP
                              MAIL_MAILER="smtp"
                              MAIL_HOST="mail"
                              MAIL_PORT="2525"
                              MAIL_USERNAME="app@tld.ld"
                              MAIL_PASSWORD="9b7e07a5419758685560d4741270044e4a846a1e1211b5a6"
                              MAIL_ENCRYPTION="ssl"
                              MAIL_FROM_ADDRESS="app@tld.ld"
                              MAIL_FROM_NAME="${APP_NAME}"
                              # Sentry
                              SENTRY_LARAVEL_DSN=null
                              MIXPOST_TWO_FACTOR_AUTH=true
                              MIXPOST_DEFAULT_LOCALE=de-DE
                              • humptyH
                                humptyH
                                humpty
                                Thanks @andreasdueren I have a lot of missing entries compared to yours. Somehow none of these got set up on a fresh Mixpost install, but adding them didn't resolve the issue 😞
                                * APP_ENV=production
                                * APP_DOMAIN=app.tld.ld (adjusted to same value as APP_URL)
                                * QUEUE_CONNECTION=redis
                                * CACHE_DRIVER=redis
                                * SESSION_DRIVER=redis
                                * MIXPOST_FORGOT_PASSWORD=true
                                * MIXPOST_TWO_FACTOR_AUTH=true
                                * MIXPOST_DEFAULT_LOCALE=de-DE (adjusted to en-US)
                                • humptyH humpty
                                  andreasduerenA
                                  andreasduerenA
                                  andreasdueren
                                  #156
                                  I remember pulling some of these off here. Sorry that didn't help.
                                  • andreasduerenA
                                    andreasduerenA
                                    andreasdueren
                                    @humptydumpty If you care, I can offer to take a look at your installation and compare to what I'm running to try to troubleshoot.
                                      humptyH
                                      humptyH
                                      humpty
                                      #158
                                      @andreasdueren I'll take you up on that if I can't figure this out after a fresh install attempt. I won't follow the guide we have on here and will follow the upstream docs this time. It's not a CR issue for sure. I have a ticket opened on Mixpost's Discord, and other non-CR users can't receive emails either.
                                      • David 0D
                                        David 0D
                                        David 0
                                        any news on this yet? I don't want to try hacking this together; I'd like to see Mixpost as an App in the Cloudron App Store 🙂
                                        • David 0D David 0
                                          @David-0 said in Mixpost:
                                          Me too! But I'm not sure anyone is working on that 😞 and the developer didn't really seem to get the need for it once he'd spotted that some people had successfully managed to hack it together themselves 😕
