  3. Firezone - FOSS noconf Mesh VPN using Wireguard, alternative to ZeroTier, Tailscale, OmniEdge, Netmaker etc
10 Posts 7 Posters 7.1k Views 9 Watching
  • marcusquinnM
    marcusquinnM
    • https://www.firezone.dev/
    • https://github.com/firezone/firezone
    • https://docs.firezone.dev/deploy
    • https://docs.firezone.dev/deploy/docker/
    • https://github.com/firezone/fz_docker
    • https://docs.firezone.dev/authenticate/oidc/keycloak/
    • https://alternativeto.net/software/firezone/about/
    • https://alternativeto.net/software/firezone/?license=opensource
    • https://forum.cloudron.io/topic/7560/omniedge-decentralised-noconf-mesh-vpn-using-wireguard-alternative-to-zerotier-tailscale-etc
    • https://forum.cloudron.io/topic/7563/tailscale-decentralised-noconf-mesh-vpn-using-wireguard-alternative-to-zerotier-etc
    • https://forum.cloudron.io/topic/7565/netmaker-foss-noconf-mesh-vpn-using-wireguard-alternative-to-zerotier-tailscale-omniedge-etc
    • https://forum.cloudron.io/topic/7571/netbird-foss-noconf-mesh-vpn-using-wireguard-alternative-to-zerotier-tailscale-omniedge-netmaker-etc
    Self-hosted secure remote access
    Firezone is an open-source VPN and firewall server built on WireGuard® to be stable, performant, and lightweight. Deploy in minutes on your own infrastructure.
    sudo -E bash -c "$(curl -fsSL https://github.com/firezone/firezone/raw/master/scripts/install.sh)"
    alt text
    Uses the standard Wireguard clients for all platforms, and the QR code generation looks good for making the setups easy enough for non-technical users.
    Looks like it supports Keycloak, so may interest @nj
    Common Use Cases
    NAT Gateway (Static IP)
    Restrict access for a self-hosted web app to a single whitelisted static IP running Firezone. (a highly recommended additional layer of protection for self-hosted apps that don't need to be exposed to on public IPs).
    Reverse Tunnels
    Enable an administrator to access a server, container, or machine that is normally behind a NAT or firewall.
    Split Tunnels
    Only traffic to defined IP ranges will be routed through the VPN server.
    timconsidineT micmcM 2 Replies Last reply
    12
      alt text
      Common Use Cases
      Reverse Tunnels
      Split Tunnels
      @marcusquinn not sure I know enough yet to judge, but I’m drawn more to this one out of the various options posted.
      Just my initial unqualified 2p
      murgeroM 1 Reply Last reply
        murgeroM
        murgeroM
        murgero
        @timconsidine I actually JUST installed this on a non-cloudron server and I gotta say it would be perfect as an app.
        https://urgero.org
          alt text
          Common Use Cases
          Reverse Tunnels
          Split Tunnels
          micmcM
          micmcM
          micmc
          @marcusquinn Awesome find!
          (coming soon...)
          • micmcM micmc
            necrevistonnezrN
            necrevistonnezrN
            @micmc does that work with dynamic IPs as well?
              marcusquinnM
              marcusquinnM
              @necrevistonnezr My complete guess is the broker service needs a fixed IP or domain mapped to a dynamic DNS service, but that clients shouldn't need fixed IPs.
              • fbartelsF fbartels referenced this topic on
              • marcusquinnM
                marcusquinnM
                Docker deployment now preferred: https://docs.firezone.dev/deploy/docker/
                • marcusquinnM
                  marcusquinnM
                  Keycloak integration: https://docs.firezone.dev/authenticate/oidc/keycloak/
                  • KubernetesK
                    KubernetesK
                    Kubernetes
                    Having this on Cloudron would be fantastic
                    • L
                      Thanks to @marcusquinn for helping me find this request. There is at the moment an early access beta test for version 1.0 available here. Your contact details would be needed:
                      https://www.firezone.dev/product/early-access
