  3. Tailscale - decentralised noconf Mesh VPN using Wireguard, alternative to ZeroTier etc
8 Posts 3 Posters 5.0k Views 7 Watching
  • marcusquinnM
    marcusquinnM
    • https://tailscale.com/
    • https://tailscale.com/kb/1054/dns/ (this look very useful - if you trust them of course)
    • https://github.com/tailscale/tailscale (not 100% sure how much is FOSS or reliant on their routing, could be more centralised than OmniEdge)
    • https://hub.docker.com/r/tailscale/tailscale
    • https://tailscale.com/blog/docker/
    • https://alternativeto.net/software/tailscale/about/
    • https://forum.cloudron.io/topic/7560/omniedge-decentralised-noconf-mesh-vpn-using-wireguard-alternative-to-zerotier-tailscale-etc (Alternative)
    • https://forum.cloudron.io/topic/7565/netmaker-foss-noconf-mesh-vpn-using-wireguard-alternative-to-zerotier-tailscale-omniedge-etc
    • https://forum.cloudron.io/topic/7567/firezone-foss-noconf-mesh-vpn-using-wireguard-alternative-to-zerotier-tailscale-omniedge-netmaker-etc
    • https://forum.cloudron.io/topic/7571/netbird-foss-noconf-mesh-vpn-using-wireguard-alternative-to-zerotier-tailscale-omniedge-netmaker-etc
    A secure network that just works
    Zero config VPN. Installs on any device in minutes, manages firewall rules for you, and works from anywhere.
    Available for:
    Linux
    Windows
    macOS
    iOS
    Raspberry Pi & ARM
    Android
    Synology
    Docker
    No config files, no firewall ports
    Create a secure network between your servers, computers, and cloud instances. Even when separated by firewalls or subnets, Tailscale just works.
    Every device on your network gets a stable IP and auto-assigned domain that stays consistent, no matter what Wi-Fi the device is on. It’s like a local network that works everywhere.
    Access controls & monitoring
    Define role-based access controls to restrict sensitive servers or authorize contractors to only see what they need. And every connection is centrally logged from both ends, viewable from a dashboard and logging API.
    Automatic key rotation
    Hourly and daily rotations minimizes the risk of stolen keys or stale credentials.
    Secured with WireGuard®
    Tailscale builds on top of WireGuard’s Noise protocol encryption, a peer-reviewed and trusted standard.
    Point-to-point connections
    Low latency and private. None of your traffic ever touches our servers.
    Audit-compliant logging
    Logging from both ends of the connection ensures your network traffic is tamper-proof.
      wrote on last edited by robi
      Dupe?
      Any reason it's not posted here, with 7 upvotes?
        Dupe?
        marcusquinnM
        marcusquinnM
        @robi Sorry, didn't see that, I do like my wishlist posts to have all the links and images though, so excuse the enthusiasm 🙂
          @marcusquinn I'd say DM me the markdown code to update the post, but it's not editable anymore (post since 2020)
            marcusquinnM
            marcusquinnM
            @robi NodeBB has nice cross-referencing links now though, I'm sure people can find and upvote both if desired.
              @marcusquinn maybe @girish will merge.
              • fbartelsF
                fbartelsF
                fbartels
                For Tailscale only the clients are open source, while their central unit is closed source.
                There is however https://github.com/juanfont/headscale and Tailscale recently allowed a pr to the Android app to make the server backend configurable.
                • fbartelsF fbartels
                  marcusquinnM
                  marcusquinnM
                  @fbartels Wow, open-source communities are amazing when they do this kinda thing just because. 👍
                  • fbartelsF fbartels referenced this topic on
