  2. LAMP
  3. Using YARN
Using YARN
Scheduled Pinned Locked Moved Solved LAMP
18 Posts 5 Posters 9.5k Views 5 Watching
  • FoksVHoxF Offline
    FoksVHoxF Offline
    FoksVHox
    Hello!
    I'd like to hear how I'd be able to use the YARN package manager instead of NPM, in the LAMP app?
    • FoksVHoxF FoksVHox
      Hello!
      @FoksVHox yarn is already there. Does the below work in a Web Terminal ?
      root@d8e7cdf87e6b:/# yarn --version
      1.22.17
      FoksVHoxF 1 Reply Last reply
        1.22.17
        FoksVHoxF Offline
        FoksVHoxF Offline
        FoksVHox
        @girish said in Using YARN:
        yarn --version
        Sorry for the late reply, it indeed does, however, when using custom commands, that are specified within your package.json file, it doesn't work.
        This is my package.json file:
            "private": true,
            "scripts": {
                "dev": "vite",
                "build": "vite build"
            "devDependencies": {
                "@babel/core": "^7.18.13",
                "@babel/plugin-proposal-object-rest-spread": "^7.18.6",
                "@babel/plugin-syntax-dynamic-import": "^7.8.3",
                "@babel/plugin-transform-runtime": "^7.18.10",
                "@babel/preset-env": "^7.18.10",
                "@tailwindcss/forms": "^0.5.2",
                "alpinejs": "^3.10.3",
                "apexcharts": "^3.35.5",
                "autoprefixer": "^10.4.8",
                "axios": "^0.27",
                "clockwork-browser": "^1.1.1",
                "cross-env": "^7.0.3",
                "laravel-echo": "^1.14.0",
                "laravel-vite-plugin": "^0.5.0",
                "lodash": "^4.17.21",
                "mix-tailwindcss": "^1.3.0",
                "object-path": ">=0.11.8",
                "postcss": "^8.4.16",
                "pusher-js": "^7.4.0",
                "resolve-url-loader": "^5.0.0",
                "sass": "^1.54.7",
                "sass-loader": "^13.0.2",
                "tailwindcss": "^3.1.8",
                "vite": "^3.0.2",
                "vue-template-compiler": "^2.7.10",
                "webpack": "^5.74.0",
                "webpack-cli": "^4.10.0"
            "dependencies": {
                "@alpinejs/mask": "^3.10.3",
                "@tailwindcss/aspect-ratio": "^0.4.0",
                "@tailwindcss/line-clamp": "^0.4.0"
        When I run yarn build I get the following error.
        root@de780a18-b997-4803-a5b2-f07549cad279:/app/data/lectero# yarn build
        yarn run v1.22.17
        warning Skipping preferred cache folder "/usr/local/share/.cache/yarn" because it is not writable.
        warning Selected the next writable cache folder in the list, will be "/tmp/.yarn-cache-0".
        $ vite build
        warning Cannot find a suitable global folder. Tried these: "/usr/local, /usr/local/share/.yarn"
        /bin/sh: 1: vite: not found
        error Command failed with exit code 127.
        info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
        And I also think it has something to do with the version of Yarn not being version 2
          yarn --version
              "private": true,
              "scripts": {
                  "dev": "vite",
                  "axios": "^0.27",
                  "sass": "^1.54.7",
                  "vite": "^3.0.2",
              "dependencies": {
          yarn run v1.22.17
          $ vite build
          @FoksVHox have you run yarn install prior to running yarn build ?
            FoksVHoxF Offline
            FoksVHoxF Offline
            FoksVHox
            @nebulon Yes. I can confirm this has something to do with the version of Yarn not being Yarn v2.
              Actually to take a step back, from your package.json it looks like there is nothing yarn specific, couldn't you just use npm there instead?
                FoksVHoxF Offline
                FoksVHoxF Offline
                FoksVHox
                @nebulon said in Using YARN:
                Well I could, however, npm is often way slower than yarn is.
                  @FoksVHox actually I have mixed experience there since some npm releases. But either way would a few seconds make much difference in your case compared to it working?
                    FoksVHoxF Offline
                    FoksVHoxF Offline
                    FoksVHox
                    @nebulon I've tried to use npm but it seems that it won't work either.
                      @FoksVHox is there any other error with npm?
                        FoksVHoxF Offline
                        FoksVHoxF Offline
                        FoksVHox
                        @nebulon There is:
                        EACCES: permission denied, open '/app/data/lectero/public/build/assets/app.22fa980f.js'
                        error during build:
                        Error: EACCES: permission denied, open '/app/data/lectero/public/build/assets/app.22fa980f.js'
                        nebulonN girishG 2 Replies Last reply
                          @nebulon There is:
                          error during build:
                          @FoksVHox seems like a permission issue then. Make sure that the user, with whom you are running npm, has write access to those folders.
                            @nebulon There is:
                            error during build:
                            @FoksVHox If you are running as www-data user, you have to chown -R www-data:www-data /app/data/public
                              Was just investigating this a bit. What I found is that yarn wants to write as root user into /usr/local/share/.yarnrc. This is reported upstream as bug https://github.com/yarnpkg/yarn/issues/4628
                              Workaround (you can put this in /app/data/.bashrc if you like):
                              export YARN_DISABLE_SELF_UPDATE_CHECK="true"
                              After this, I am able to install easily:
                              root@38e05e7c-8aee-426e-85ef-a577d080c39c:/app/data/public# yarn add safetydance
                              yarn add v1.22.17
                              warning package.json: No license field
                              warning No license field
                              [1/4] Resolving packages...
                              [2/4] Fetching packages...
                              [3/4] Linking dependencies...
                              [4/4] Building fresh packages...
                              success Saved lockfile.
                              success Saved 1 new dependency.
                              info Direct dependencies
                              └─ safetydance@2.2.0
                              info All dependencies
                              Done in 1.15s.
                                yarn add v1.22.17
                                Done in 1.15s.
                                FoksVHoxF Offline
                                FoksVHoxF Offline
                                FoksVHox
                                @girish Will you update the thread once the issue has been resolved?
                                  @FoksVHox Will do. I am subscribed to that issue, but it's open for 5 years now, so I have no hope 🙂
                                  • C Offline
                                    C Offline
                                    charlesnw
                                    Is yarn no longer included?
                                    root@ab0364d2-83f6-46cd-96c5-f9c329d24af7:/app/data/public# yarn --version
                                    bash: yarn: command not found
                                      Hello @charlesnw
                                      With this commit: https://git.cloudron.io/platform/docker-base-image/-/commit/2e4f7fd5fde83652567dd0a00a695f523bef98d1 yarn was removed from the docker base image.
                                      So yes, yarn is no longer included in any app by default.
