  2. Rallly
  3. Rallly 3.0 Pro features missing
Scheduled Pinned Locked Moved Solved Rallly
9 Posts 5 Posters 4.2k Views 4 Watching
  • David 0D
    David 0D
    David 0
    Hey,
    I noteiced that after updating Rallly to v3.0 the pro features are missing. According to the developer, they should be available with the self hosted version. He stated, that cloudron might use an older package?
    Can you confirm that, @nebulon?
    best
    David
    • jdaviescoatesJ
      I had never noticed any pro anything before, but I note that now I see this stuff, which seems confusing on a self-hosted instance:
      • jdaviescoatesJ
        I also just spotted this in the Cloudron changelog:
        Changelog:
        Update Rallly to 3.0.0
        Full changelog
        The AUTHREQUIRED parameter has been removed. As of version 3, users must be logged in to create and manage polls. To further avoid use of your instance by unauthorized users, you are encouraged to use the ALLOWEDEMAILS parameter to limit who can register and login on your instance.
        Poll finalization
        Custom poll settings (hide participant list, hide scores, disable comments)
        Poll duplication
        (emphasis added)
        So now I'm wondering how we do that?
          This also plays into the fact that we have not set the selfhosted environment variable in the past. This comes with the next package update.
          • L
            lukevella
            Hi @nebulon, isn't Clouldron running the image from Docker Hub? This has the environment configured for self-hosting during build time. At least that is the expected behavior.
            fbartelsF 1 Reply Last reply
              linking the upstream thread https://github.com/lukevella/rallly/discussions/702#discussioncomment-7016212
              • L lukevella
                fbartelsF
                fbartelsF
                fbartels
                @lukevella No, cloudron is generally using their own docker images so have more control over the environment.
                  This should be solved with latest package update
                  • David 0D
                    David 0D
                    David 0
                    Great. Everything works fine now.
