Issues with Guacamole and Open Project
my cloudron hosts only 2 apps, guacamole and Open Project.
Their usage is very light, maximum concurrent users only 1-2 at any point of time.
Now all of a sudden my guacamole can't work.
Nov 16 17:38:26 guacd[16]: INFO: Creating new client for protocol "ssh" Nov 16 17:38:26 guacd[16]: INFO: Connection ID is "$81311092-340e-41c0-896a-70355c781e98" Nov 16 17:38:26 guacd[454]: DEBUG: Processing instruction: size Nov 16 17:38:26 guacd[454]: DEBUG: Processing instruction: audio Nov 16 17:38:26 guacd[454]: DEBUG: Processing instruction: video Nov 16 17:38:26 guacd[454]: DEBUG: Processing instruction: image Nov 16 17:38:26 guacd[454]: DEBUG: Processing instruction: timezone Nov 16 17:38:26 guacd[454]: DEBUG: Processing instruction: name Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "scrollback" omitted. Using default value of 1000. Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "font-name" omitted. Using default value of "monospace". Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "enable-sftp" omitted. Using default value of 0. Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "sftp-root-directory" omitted. Using default value of "/". Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "sftp-disable-download" omitted. Using default value of 0. Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "sftp-disable-upload" omitted. Using default value of 0. Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "read-only" omitted. Using default value of 0. Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "typescript-name" omitted. Using default value of "typescript". Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "create-typescript-path" omitted. Using default value of 0. Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "recording-name" omitted. Using default value of "recording". Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "recording-exclude-output" omitted. Using default value of 0. Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "recording-exclude-mouse" omitted. Using default value of 0. Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "recording-include-keys" omitted. Using default value of 0. Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "create-recording-path" omitted. Using default value of 0. Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "server-alive-interval" omitted. Using default value of 0. Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "backspace" omitted. Using default value of 127. Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "terminal-type" omitted. Using default value of "linux". Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "timezone" omitted. Using default value of "Asia/Bangkok". Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "disable-copy" omitted. Using default value of 0. Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "disable-paste" omitted. Using default value of 0. Nov 16 17:38:26 guacd[454]: DEBUG: Parameter "wol-send-packet" omitted. Using default value of 0. Nov 16 17:38:26 guacd[454]: INFO: User "@4e64e1aa-c52f-4b18-8e5b-6d55e2c7253a" joined connection "$81311092-340e-41c0-896a-70355c781e98" (1 users now present) Nov 16 17:38:26 guacd[454]: DEBUG: Client is using protocol version "VERSION_1_5_0" Nov 16 17:38:26 10:38:26.890 [http-nio-8080-exec-5] INFO o.a.g.tunnel.TunnelRequestService - User "gnulab" connected to connection "7". Nov 16 17:38:36 guacd[454]: ERROR: Error parsing given address or port: Temporary failure in name resolution Nov 16 17:38:36 guacd[454]: INFO: User "@4e64e1aa-c52f-4b18-8e5b-6d55e2c7253a" disconnected (0 users remain) Nov 16 17:38:36 guacd[454]: INFO: Last user of connection "$81311092-340e-41c0-896a-70355c781e98" disconnected Nov 16 17:38:36 guacd[454]: DEBUG: Requesting termination of client... Nov 16 17:38:36 Exception in thread "Thread-44" java.lang.IllegalStateException: Message will not be sent because the WebSocket session has been closed Nov 16 17:38:36 at org.apache.tomcat.websocket.WsRemoteEndpointImplBase.writeMessagePart(WsRemoteEndpointImplBase.java:442) Nov 16 17:38:36 at org.apache.tomcat.websocket.WsRemoteEndpointImplBase.sendMessageBlock(WsRemoteEndpointImplBase.java:314) Nov 16 17:38:36 at org.apache.tomcat.websocket.WsRemoteEndpointImplBase.sendMessageBlock(WsRemoteEndpointImplBase.java:254) Nov 16 17:38:36 at org.apache.tomcat.websocket.WsRemoteEndpointImplBase.sendString(WsRemoteEndpointImplBase.java:195) Nov 16 17:38:36 at org.apache.tomcat.websocket.WsRemoteEndpointBasic.sendText(WsRemoteEndpointBasic.java:37) Nov 16 17:38:36 at org.apache.guacamole.websocket.GuacamoleWebSocketTunnelEndpoint.sendInstruction(GuacamoleWebSocketTunnelEndpoint.java:152) Nov 16 17:38:36 at org.apache.guacamole.websocket.GuacamoleWebSocketTunnelEndpoint.access$200(GuacamoleWebSocketTunnelEndpoint.java:53) Nov 16 17:38:36 at org.apache.guacamole.websocket.GuacamoleWebSocketTunnelEndpoint$2.run(GuacamoleWebSocketTunnelEndpoint.java:253) Nov 16 17:38:37 10:38:36.997 [http-nio-8080-exec-9] INFO o.a.g.tunnel.TunnelRequestService - User "gnulab" disconnected from connection "7". Duration: 10106 milliseconds Nov 16 17:38:37 guacd[454]: DEBUG: Client terminated successfully. Nov 16 17:38:37 guacd[16]: INFO: Connection "$81311092-340e-41c0-896a-70355c781e98" removed.Open Project couldn't be launched too.
Nov 14 18:23:52 => Seed database if needed basic data for standard edition Nov 14 18:24:12 *** Seeding for locale: 'en' Nov 14 18:24:15 *** Loading action_cable_engine seed data Nov 14 18:24:15 *** Loading action_mailbox seed data Nov 14 18:24:15 *** Loading action_text seed data Nov 14 18:24:15 *** Loading action_view_railtie seed data Nov 14 18:24:15 *** Loading active_storage seed data Nov 14 18:24:15 *** Loading budgets_engine seed data Nov 14 18:24:15 *** Loading costs seed data Nov 14 18:24:15 *** Loading dashboards seed data Nov 14 18:24:15 *** Loading date_validator_engine seed data Nov 14 18:24:15 *** Loading doorkeeper_engine seed data Nov 14 18:24:15 *** Loading grids_engine seed data Nov 14 18:24:15 *** Loading lookbook seed data Nov 14 18:24:15 *** Loading my_page_engine seed data Nov 14 18:24:15 *** Loading ok_computer seed data Nov 14 18:24:15 *** Loading openproject_auth_plugins seed data Nov 14 18:24:15 *** Loading openproject_auth_saml seed data Nov 14 18:24:15 *** Loading openproject_avatars seed data Nov 14 18:24:15 *** Loading openproject_backlogs seed data Nov 14 18:24:15 *** Loading openproject_bim seed data Nov 14 18:24:15 *** Loading openproject_boards seed data Nov 14 18:24:15 *** Loading openproject_calendar seed data Nov 14 18:24:15 *** Loading openproject_documents seed data Nov 14 18:24:15 *** Loading openproject_github_integration seed data Nov 14 18:24:15 *** Loading openproject_job_status seed data Nov 14 18:24:15 *** Loading openproject_ldap_groups seed data Nov 14 18:24:15 *** Loading openproject_meeting seed data Nov 14 18:24:15 *** Loading openproject_openid_connect seed data Nov 14 18:24:15 *** Loading openproject_recaptcha seed data Nov 14 18:24:15 *** Loading openproject_reporting seed data Nov 14 18:24:15 *** Loading openproject_storages seed data Nov 14 18:24:15 *** Loading openproject_team_planner seed data Nov 14 18:24:15 *** Loading openproject_two_factor_authentication seed data Nov 14 18:24:15 *** Loading openproject_webhooks seed data Nov 14 18:24:15 *** Loading openproject_xls_export seed data Nov 14 18:24:15 *** Loading overviews seed data Nov 14 18:24:15 *** Loading primer_view_components seed data Nov 14 18:24:15 *** Loading turbo seed data Nov 14 18:24:15 *** Loading view_component_engine seed data Nov 14 18:24:15 *** No need to seed an admin as there already is one. Nov 14 18:24:15 *** Seeding admin user Nov 14 18:24:15 *** Seeding data from environment variables Nov 14 18:24:15 *** Seeding demo data Nov 14 18:24:15 *** Skipping BasicData::Backlogs::SettingSeeder Nov 14 18:24:15 *** Skipping DemoData::OverviewSeeder Nov 14 18:24:15 *** Skipping DemoData::ProjectsSeeder Nov 14 18:24:15 *** Skipping EnvData::LdapSeeder Nov 14 18:24:15 *** Skipping colors as there are already some configured Nov 14 18:24:15 *** Skipping document categories as there are already some configured Nov 14 18:24:15 *** Skipping open color palette as there are already some configured Nov 14 18:24:15 *** Skipping priorities as there are already some configured Nov 14 18:24:15 *** Skipping roles as there are already some configured Nov 14 18:24:15 *** Skipping settings as all settings already exist in the db Nov 14 18:24:15 *** Skipping time entry activities as there are already some configured Nov 14 18:24:15 *** Skipping types, statuses and workflows as there are already some configured Nov 14 18:24:15 => Update LDAP config Nov 14 18:24:15 => Update general config Nov 14 18:24:15 INSERT 0 1 Nov 14 18:24:15 Loading discovered seeders: Backlogs::SettingSeeder, Documents::EnumerationSeeder Nov 14 18:24:15 UPDATE 0 Nov 14 18:24:15 UPDATE 1 Nov 14 18:24:15 UPDATE 1 Nov 14 18:24:15 ↳ Backlogs::SettingSeeder Nov 14 18:24:15 ↳ BuiltinUsersSeeder Nov 14 18:24:15 ↳ ColorSchemeSeeder Nov 14 18:24:15 ↳ ColorSeeder Nov 14 18:24:15 ↳ Creating global queries Nov 14 18:24:15 ↳ Creating groups Nov 14 18:24:15 ↳ Documents::EnumerationSeeder Nov 14 18:24:15 ↳ GlobalQuerySeeder Nov 14 18:24:15 ↳ GroupSeeder Nov 14 18:24:15 ↳ LdapSeeder Nov 14 18:24:15 ↳ OverviewSeeder Nov 14 18:24:15 ↳ PrioritySeeder Nov 14 18:24:15 ↳ ProjectsSeeder Nov 14 18:24:15 ↳ RoleSeeder Nov 14 18:24:15 ↳ SettingSeeder Nov 14 18:24:15 ↳ TimeEntryActivitySeeder Nov 14 18:24:15 ↳ WorkflowSeeder Nov 14 18:24:16 => Clear previous cache to reflect db changes Nov 14 18:24:16 UPDATE 0 Nov 14 18:24:16 UPDATE 0 Nov 14 18:24:16 UPDATE 0 Nov 14 18:24:16 UPDATE 0 Nov 14 18:24:16 UPDATE 0 Nov 14 18:24:16 UPDATE 0 Nov 14 18:24:16 UPDATE 0 Nov 14 18:24:16 UPDATE 0 Nov 14 18:24:16 UPDATE 1 Nov 14 18:24:16 UPDATE 1 Nov 14 18:24:16 UPDATE 1 Nov 14 18:24:16 UPDATE 1 Nov 14 18:24:24 => Fixup the directory permissions Nov 14 18:24:24 => Start apache Nov 14 18:24:25 Nov 14 18:24:25 [Tue Nov 14 11:24:25.751437 2023] [mpm_prefork:notice] [pid 1] AH00163: Apache/2.4.52 (Ubuntu) Phusion_Passenger/6.0.18 mod_perl/2.0.12 Perl/v5.34.0 configured -- resuming normal operations Nov 14 18:24:25 [Tue Nov 14 11:24:25.752753 2023] [core:notice] [pid 1] AH00094: Command line: '/usr/sbin/apache2 -D FOREGROUND'! Could not create nginx config directory: ENOSPC: no space left on device,2023-11-14T11:23:29.000Z => Migrate database
Looking at the log. Guacamole complains of dns resolution. Open Project complains of no disk space left.
So, how much disk space is really required by cloudron? And I doubt resolving dns isn't the problem faced by gaucamole.
How do I go about solving this instead of starting from scratch again?
Thank you
The disk stats are only updated once per day, so they are not a live state. Maybe your server by now has run out of disk space. If so please follow https://docs.cloudron.io/troubleshooting/#recovery-after-disk-full as since you were seeing dns issues, likely unbound is down.
N nebulon marked this topic as a question on
guacamole is solved. Redownloading trust key and restarting unbound solves it.
As for Open Project, here is the disk usage from terminal:
root@g:~# df Filesystem 1K-blocks Used Available Use% Mounted on tmpfs 202340 1976 200364 1% /run /dev/vda1 53973208 31476756 19596548 62% / tmpfs 1011688 0 1011688 0% /dev/shm tmpfs 5120 0 5120 0% /run/lock overlay 53973208 31476756 19596548 62% /var/lib/docker/overlay2/2adb4e3aa02ae42d4f42f64b338abcc2dff9c441e278ed8c9c8b857449bd7b0e/merged overlay 53973208 31476756 19596548 62% /var/lib/docker/overlay2/893d943a6da7efd9c421d8b382545bf1087c6e321d7f579e37491463193568c6/merged overlay 53973208 31476756 19596548 62% /var/lib/docker/overlay2/def7ca2edc00af55f2e87d3d12a9b72ba544aa474daac0ce031f1e664649d767/merged overlay 53973208 31476756 19596548 62% /var/lib/docker/overlay2/e0fd7dcf64ccd46431170c11a9ccaabc0e4ae29ac5a461a1c037e82cd78b4575/merged overlay 53973208 31476756 19596548 62% /var/lib/docker/overlay2/56f8a71c02109cc65c8b7334d57f77b79825b997d2b3d035f73a16034766a058/merged overlay 53973208 31476756 19596548 62% /var/lib/docker/overlay2/dd08c4baa92862a501aadcad5256fcb91b25a9269b71190ac9af852597182e0a/merged overlay 53973208 31476756 19596548 62% /var/lib/docker/overlay2/dc062cba3af3f4f27c48e8759363d39567ebce34682da58479f749b9d3745af2/merged overlay 53973208 31476756 19596548 62% /var/lib/docker/overlay2/14af837367abe59eb18c5f5e6094390865e0272d72458cb340a9699bb16ea378/merged overlay 53973208 31476756 19596548 62% /var/lib/docker/overlay2/8069d9b97acc391211b4845ee94ea6e030070a90479bab02c392b96af47f4155/merged tmpfs 202336 4 202332 1% /run/user/0 root@g:~#root@g:~# df Filesystem 1K-blocks Used Available Use% Mounted on tmpfs 202340 1976 200364 1% /run /dev/vda1 53973208 31476756 19596548 62% / tmpfs 1011688 0 1011688 0% /dev/shm tmpfs 5120 0 5120 0% /run/lock overlay 53973208 31476756 19596548 62% /var/lib/docker/overlay2/2adb4e3aa02ae42d4f42f64b338abcc2dff9c441e278ed8c9c8b857449bd7b0e/merged overlay 53973208 31476756 19596548 62% /var/lib/docker/overlay2/893d943a6da7efd9c421d8b382545bf1087c6e321d7f579e37491463193568c6/merged overlay 53973208 31476756 19596548 62% /var/lib/docker/overlay2/def7ca2edc00af55f2e87d3d12a9b72ba544aa474daac0ce031f1e664649d767/merged overlay 53973208 31476756 19596548 62% /var/lib/docker/overlay2/e0fd7dcf64ccd46431170c11a9ccaabc0e4ae29ac5a461a1c037e82cd78b4575/merged overlay 53973208 31476756 19596548 62% /var/lib/docker/overlay2/56f8a71c02109cc65c8b7334d57f77b79825b997d2b3d035f73a16034766a058/merged overlay 53973208 31476756 19596548 62% /var/lib/docker/overlay2/dd08c4baa92862a501aadcad5256fcb91b25a9269b71190ac9af852597182e0a/merged overlay 53973208 31476756 19596548 62% /var/lib/docker/overlay2/dc062cba3af3f4f27c48e8759363d39567ebce34682da58479f749b9d3745af2/merged overlay 53973208 31476756 19596548 62% /var/lib/docker/overlay2/14af837367abe59eb18c5f5e6094390865e0272d72458cb340a9699bb16ea378/merged overlay 53973208 31476756 19596548 62% /var/lib/docker/overlay2/8069d9b97acc391211b4845ee94ea6e030070a90479bab02c392b96af47f4155/merged tmpfs 202336 4 202332 1% /run/user/0 root@g:~#/dev/vda1 53973208 31476756 19596548 62% /
Clearly 62% of the disk is still unused.So, how do I make cloudron 'sees' and uses that disk space?
Thank you.
Thank you.
J james has marked this topic as solved on
