  3. Enable HSTS preload for this site and all subdomains problem
Scheduled Pinned Locked Moved Solved Discuss
hstshttpserrorx509
3 Posts 3 Posters 1.8k Views 3 Watching
  • L
    CA Maintainer
    After setting up a Cloudron site and installing an application on the bare domain, we tried to enable HSTS preloading. You can reach the site using an https:// address. The following error was returned when testing it here:
    https://hstspreload.org/
    Error: www subdomain does not support HTTPS
    Domain error: The www subdomain exists, but we couldn't connect to it using HTTPS ("tls: failed to verify certificate: x509: certificate is not valid for any names, but wanted to match www.haggis.top"). Since many people type this by habit, HSTS preloading would likely cause issues for your site.
    • L LoudLemur marked this topic as a question on
      Have you seen https://docs.cloudron.io/apps/#hsts-preload ?
      • L LoudLemur
        Super Fan
        @LoudLemur I had no idea what HSTS Preloading is, but I just read https://www.howtogeek.com/devops/what-is-hsts-and-how-do-you-set-it-up/ and it sounds like it's best to proceed slowly with caution.
        In your case it sounds like you're missing a wildcard certificate that covers all subdomains including www.
