  2. Package development
  3. problem installin Cloudron CLI on a linux ubuntu machine (my local machine)
Scheduled Pinned Locked Moved Solved Package development
3 Posts 2 Posters 860 Views 2 Watching
  • M
    manuel
    hi guys , hope you are well. i am trying to follow your packaging tutorial i am stuck installing the cloudron CLI on my command line using npm.
    I get this error message. i am not very knowlegeable on nodejs. so any help or idea of what can be the problem is welcome.
    sudo npm install -g cloudron
    [sudo] password for manuel:
    /usr/bin/env: ‘node’: No such file or directory
    I tried to install another package globally and it works fine.
    thanks!
    • M manuel
      thanks!
      @manuel said in problem installin Cloudron CLI on a linux ubuntu machine (my local machine):
      I guess you have to install nodejs?
      • M
        manuel
        ok. this is solved, thanks! i had nodejs installed. it worked today without the "sudo" i dont know why
