  3. Problem with domain setup and Bunny.net
bunnydnsdomain setupaccess tokens
4 Posts 2 Posters 2.1k Views 2 Watching
  • matix131997M Offline
    matix131997
    Hello.
    I am reporting once again 😄 Last time with this error I reported in June how you introduced the possibility to connect Bunny DNS.
    I am after freshly installing Cloudron on my home server. On the first installation, I wanted to connect the domain to Bunny, but it displayed an error. I had to switch to Manual. After installing everything and from the "Domains" panel, there I was able to connect to Bunny without any problem.
    • matix131997M matix131997
      Hello.
      @matix131997 that seems like a bug, I will test a new installation now.
        @matix131997 This was a bug in the UI code (setupdns view code). Fixed in https://git.cloudron.io/cloudron/box/-/commit/003bc457bf95a5b555a83d76b36199f3acec8ece
        As a workaround:
        • Setup the DNS as manual or wildcard for a start
        • Then, after you setup admin etc, go to Domains View and change it to Bunny. This view does not have this bug.
        • matix131997M matix131997 referenced this topic on
          matix131997
          wrote on last edited by matix131997
