  2. Directus
  3. Issue with very high memory usage
Scheduled Pinned Locked Moved Solved Directus
7 Posts 4 Posters 3.5k Views 4 Watching
  • S Offline
    S Offline
    shrey
    Have been facing some significant issues with the memory usage, of the Directus app.
    Started the discussion in Directus' github a few days ago:
    https://github.com/directus/directus/issues/21308
    So far, the main area of suspicion seems to be the behaviour of the underlying S3 adapter.
    Would be good to find out if this is indeed something that can be resolved on the Cloudron end?
      Hello @shrey
      This topic is still marked as unsolved.
      Do you still need assistance?
      S Offline
      S Offline
      shrey
      Hi @james . Haven't encountered the issue in a while now, also because that particular Directus app is not in use anymore.
      • S shrey
        wrote on last edited by robi
        @shrey what happens after a restart? how long after does it jump up?
        S 1 Reply Last reply
          S Offline
          S Offline
          shrey
          @robi
          After restart, the memory completely frees up again.
            @shrey it's related to s3 adapter. we just use the upstream one, so it's not related to cloudron end.
            • S shrey has marked this topic as unsolved on
              S Offline
              S Offline
              shrey
              wrote on last edited by shrey
              @girish said in Issue with very high memory usage:
              not sure about this.
              When i create a Directus project on a VPS using docker (docker compose or via Portainer), with almost identical configuration as the Cloudron Directus project, i don't get this issue.
              Example: Container memory usage when uploading a 8GB file to Directus, barely goes up by some 200MB, whereas in Cloudron, the memory always gets consumed by the entire size of the file (8GB in this case).
                Hello @shrey
                  Hello @shrey
                  S Offline
                  S Offline
                  shrey
