  3. dolibarr - ERP & CRM for Business
44 Posts 10 Posters 22.6k Views 11 Watching
  • BrutalBirdieB BrutalBirdie
    @robi => @luckow wrote
    What is the reason to login as an admin, select ldap users from a dropdown and add them to the userbase in dolibarr? Without that workflow it isn't possible to login as an allowed user (from the cloudron app/dashboard perspective).
    Tested with a fresh installation.
    https://forum.cloudron.io/topic/3474/unusual-ldap-user-workflow?_=1604397103462
    BrutalBirdieB
    BrutalBirdieB
    Since @robi and @luckow has fallen for this trap, I will assume other users will fall for it as well.
    Maybe mention this behavior in the initial setup notification?
      I think this is a bug where the LDAP -> Dolibarr part of the LDAP plugin isn't populating users.
      Hope @erics or @staff can take a look.
      • jdaviescoatesJ
        @staff this is now in the app store and marked as stable so I guess this should be marked as solved πŸ™‚
          Thanks for the reminder. The forum section for Dolibarr is at https://forum.cloudron.io/category/107/dolibarr
          I will mark this then as solved and lock the thread.
