  3. less permissive volume sharing
9 Posts 3 Posters 3.6k Views 3 Watching
  • R
    R
    Recliner2042
    In the docs, it says to chmod 777 any volume you want shared between various apps.
    Is there an easy way to be more restrictive about this? What if I only want two apps to have access, and don't want every local machine user to?
    • R
      R
      Recliner2042
      I see at the bottom of the page https://docs.cloudron.io/volumes/#sharing there are instructions to share with all users of the media group. Is the chmod 777 really still necessary when doing that? And if I want to be specific about which apps have access, then do I create a new group, add the run-as users to it, and then follow the same instructions for media but with my new group?
      • murgeroM
        murgeroM
        murgero
        It uses linux permissions, I'd expect that chown'ing the folder(s) in question to yellowtent would be enough - otherwise there isn't much that can be done via cloudron for the volumes. Restrict the folder to the yellowtent user and group (Cloudron's user) and I think that'll be enough - but it wont restrict per-app.
        https://urgero.org
        R 1 Reply Last reply
        • murgeroM murgero
          R
          R
          Recliner2042
          @murgero Thank you. That's what I was thinking. But it wasn't the case. Apps can't write to a directory owned by yellowtent.
          murgeroM 1 Reply Last reply
          • R Recliner2042
            murgeroM
            murgeroM
            murgero
            @Recliner2042 oh, does it have to be root? I don't use the shared volumes currently so I wasn't 100% sure, just working of basic Linux Knowledge
            https://urgero.org
            • murgeroM murgero
              R
              R
              Recliner2042
              wrote on last edited by Recliner2042
              @murgero I'm pretty sure you have to create a group, place each run-as app-user into that group, and then make the group own the directory. But I'm not an expert at this stuff.
              • R
                R
                Recliner2042
                @girish did you mark this solved because I got it right in my last post?
                  @Recliner2042 yes, sorry, I thought the problem was solved. Is that not the case?
                    R
                    R
                    Recliner2042
                    @girish Well, it wasn't exactly a problem. I was just asking an important question, and wanted a confirmation that I guessed the right answer.
