  3. Failed to mount (inactive): mount.nfs: Protocol not supported
nfsbackups
6 Posts 2 Posters 2.7k Views 2 Watching
  • D Offline
    D Offline
    DualOSWinWiz
    Hi i am getting a strange message on my one of the cloudron instance when i am setting up a NFS mount its giving me the error and their are no Logs been created.
    my NAS is from QNAP
    • D Offline
      D Offline
      DualOSWinWiz
      reboot the server then got
      Failed to mount (inactive): Created symlink /run/systemd/system/remote-fs.target.wants/rpc-statd.service → /lib/systemd/system/rpc-statd.service. mount.nfs: Protocol not supported
      • D Offline
        D Offline
        DualOSWinWiz
        wrote on last edited by DualOSWinWiz
        above both error came on NFSv2 and NFSv3 but when i activated NFSv4 the error is now
        Failed to mount (inactive): mount.nfs: mounting 10.XX.XXX.11:/cloudron-backup/cloudron-data failed, reason given by server: No such file or directory
          @DualOSWinWiz you can check if you are able to mount using simple mount command . Looks like some configuration error on the server or the remote directory being given to the client is wrong.
          D 1 Reply Last reply
            D Offline
            D Offline
            DualOSWinWiz
            @girish on the ubuntu server 22.04?
            • D DualOSWinWiz
              @DualOSWinWiz yes, correct. This looks like some kernel related issue or some missing ubuntu package. Can you try to make the NFS mounting work with just the CLI . This will remove Cloudron out of the equation. I think it is possible some missing package or miscompiled kernel.
