  2. LAMP
  3. Problem with LAMP
Problem with LAMP
Scheduled Pinned Locked Moved Solved LAMP
lampownershipchangeproblem
3 Posts 3 Posters 1.5k Views 3 Watching
  • matix131997M
    matix131997M
    matix131997
    I am after upgrading my Cloudron version to 8.1.0
    There is still a problem in the latest version as in the previous version that is after extracting from .zip or .tar it changes the ownership.
    After extracting, the folder changes from “www-data” to “root”.
    During the change from “root” to “www-data” at the end it seems to switch to “root” at the last second. You have to take a good look at what is happening. Because of this, I can't update the app.
      Maybe still a bug in the filemanager then. Will look into this. Until this is fixed you can extract it and use the webterminal to change the ownership maybe?
        Closed due to inactivity
