  2. Superset
  3. Superset: Permission denied for snowflake database connection
Scheduled Pinned Locked Moved Solved Superset
15 Posts 3 Posters 5.8k Views 3 Watching
  • rapmac13160R Offline
    rapmac13160
    Snowflake database connection in Superset suddenly stopped to operate with the following error message:
    Error: [Errno 13] Permission denied: '/root/.config/snowflake/config.toml'
    This is the same when I try to test the connection in the settings directly.
    Thank you in advance.
      Haven't heard of snowflake in the context of databases before, but looks like support for it has to be installed manually. I tried the upstream docs at https://superset.apache.org/docs/configuration/databases#installing-database-drivers to install that via pip but for some reason I can't even get the app to list snowflake as an option. How did you install that?
        The snowflake driver is already included in the package. The issue appears to be something else.
          From what I can make out, Snowflake CLI uses config.toml - https://docs.snowflake.com/en/developer-guide/snowflake-cli/connecting/configure-cli . Not sure why superset wants config.toml . Might be a question for the uptsream project?
            rapmac13160
            Hi, do you need any information from me ?
              @rapmac13160 we don't have experience with snowflake and don't have a set up to test. So, you will have to help us debug this further.
              You said "suddenly stopped to operate" . Does this mean it worked before and just stopped working recently? What changed?
                rapmac13160
                wrote on last edited by rapmac13160
                Sure. Yes the connection worked well in the past month. I did not check superset for few months and when i connected few days ago, this message appeared. It can possibly be linked to an update of superset.
                It was working fine at that time https://forum.cloudron.io/topic/11457/install-prophet-package/10?_=1732531616852
                  @rapmac13160 do you think you can generate some test snowflake credentials / database for us to test? If you can send them to support@cloudron.io, we can test it .
                  I signed up at snowflake.com but tbh I couldn't make much sense of it. Can't even figure how to set up a database and generate access tokens.
                    rapmac13160
                    Hi @girish, they are sent to the adress
                      @rapmac13160 thanks, the issue is https://github.com/snowflakedb/snowflake-connector-python/issues/2108 . I have left a note there. I am updating the package with a workaround - https://git.cloudron.io/cloudron/superset-app/-/merge_requests/4
                        rapmac13160
                        @girish thanks for the investigation, let me know when ok.
                          @rapmac13160 new package is out
                            rapmac13160
                            @girish it works perfectly fine thanks!
                              rapmac13160
                              Hi, just did the upgrade of Superset and the error is backScreenshot 2024-12-13 at 20.23.18.png
                              rapmac13160R 1 Reply Last reply
                              • rapmac13160R rapmac13160
                                rapmac13160
                                @rapmac13160 Not exactly the same but it seems very similar
                                • rapmac13160R rapmac13160 referenced this topic on
