  2. OpenWebUI
  3. Open web UI not responding
11 Posts 2 Posters 4.3k Views 2 Watching
  • A
    A
    Algaweb
    Hello, I manage two Cloudrons on two VPS's from one location and from one provider. On both instances I've got Open Web UI installed. One server it works fine but on the other I get the message "This app is currently not responding. Please try refreshing the page in a few minutes." Both instances of Open Web UI are on the same newest version. I checked troubleshooting and it looks fine. Do you have any idea, what is causing it?
    • J
      @Algaweb what's in the app logs ? https://docs.cloudron.io/apps/#log-viewer
      • A
        A
        Algaweb
        Sending here. There are some errors...
        • A
          A
          Algaweb
          J 1 Reply Last reply
          • A Algaweb
            @Algaweb per the logs , maybe you put something in /app/data/env.sh ? On line 8, there is a syntax error . Check using the File manager what is on line 8
            • A
              A
              Algaweb
              You are right, I entered this there:
              ENABLE_GOOGLE_DRIVE_INTEGRATION=True
              GOOGLE_DRIVE_CLIENT_ID=<your_client_id>
              GOOGLE_DRIVE_API_KEY=<your_api_key>
              I was figuring out, where to put credentials for Google drive integration. Is it in this env.sh file or elsewhere? Or is it without the first line just client and api?
              • A
                A
                Algaweb
                anyway, thank you for your help!
                • J
                  @Algaweb I think that's the correct place. In Cloudron, the convention is that if it is env.sh (i.e ending with sh), you have to use the "export" keyword since it is a shell script.
                  So,
                  export ENABLE_GOOGLE_DRIVE_INTEGRATION=True
                  • A
                    A
                    Algaweb
                    All right,
                    so would this be the correct input?
                    export GOOGLE_DRIVE_CLIENT_ID=<your_client_id>
                    export GOOGLE_DRIVE_API_KEY=<your_api_key>
                    Or just on the first line?
                    • A Algaweb
                      All right,
                      @Algaweb yes, correct. export keyword for each line .
                      • A
                        A
                        Algaweb
                        Perfect, thank you!
