  3. misunderstood free and pro plan.
license
15 Posts 7 Posters 3.7k Views 7 Watching
  • M Offline
    M Offline
    MostlyHarmless
    Just did another dumb thing. I though when I was on the pro plan I could create another cloudron install. I wanted to change the name and I couldnt find a delete option so I created a second. It wasnt until I logged on that I saw upgrade to premium. Can I move my premium to the new one and delete the old?
    Regards,
      Hello @MostlyHarmless
      for all license related question please contact support@cloudron.io directly.
      Please also link this forum post in your message for faster processing.
      After your issue is resolved, please also write an update here.
      Thanks
      M 1 Reply Last reply
        Thanks
        M Offline
        M Offline
        MostlyHarmless
        @james Hi James,
        I sent an email but the reply said to come back here. I think it was automated. Just letting you know.
        • M MostlyHarmless
          @james Hi James,
          @MostlyHarmless said in misunderstood free and pro plan.:
          Sounds to me like the wording of this auto response needs editing/ updating by @staff for clarity. As it is it's evidently leading to confusion.
          scookeS 1 Reply Last reply
            scookeS Offline
            scookeS Offline
            scooke
            @jdaviescoates There was an earlier post, not sure how long ago, from staff explaining that since the Free plan's Support is to be found in the Forums, that support requests forward the user to the Forum. Makes sense to me. I suppose they could include some pop-up for such redirects that repeat this once such a user arrives here via an email link.
            • scookeS scooke
              @scooke clearly the text of the auto-response email is not clear enough 🙂
                scookeS Offline
                scookeS Offline
                scooke
                @jdaviescoates OK, I'm gonna check it out.
                I do have another Free plan. When I click on Support the page that loads doesn't even give me an option to send an email. Pretty clear that the forums are my Support. So I will next send an email to support@cloudron.io from that Free plan's email address and see what happens.
                • scookeS Offline
                  scookeS Offline
                  scooke
                  Got the auto-reply:
                  Hello Shane,
                  Thanks for contacting Cloudron Support.
                  We have moved our technical support for the Pro plan to the forum and only sensitive issues are handled here. For technical and app related questions, please post at https://forum.cloudron.io/category/4/support . This helps us build a knowledge base for other users and is SEO friendly.
                  Some tips when posting to the forum:
                  * Please give us as much information as possible to help you
                  * Anonymize any logs, domains and user related information
                  Kind regards,
                  Cloudron Team
                  Pretty clear the Forum is where support happens, even for the Pro plan.
                  I suppose OP didn't include the "link this forum post in your message"? The wording of Support in this topic sure made it seem like if OP emailed Support with the link that something else would happen, like an actual email reply. So, it is more the post of Support here that is confusing (unless OP didn't include the link).
                  • scookeS scooke
                    Got the auto-reply:
                    Hello Shane,
                    Kind regards,
                    Cloudron Team
                    @scooke what is confusing people is that staff on here say "email support@" and so they do, only to be told by the auto reply to come back here. Very clearly suboptimal UX.
                      scookeS Offline
                      scookeS Offline
                      scooke
                      @jdaviescoates But it isn't the UI. The UI is very clear where Support is. What appears to be suboptimal is the direction from individual Staff.
                      I imagine though this is still a way for them to filter the true sensitive requests from the others. The user does have to jump through an extra hoop, but I assume that also means the help they get, when they get it, is faster and better than shuttling emails back and forth trying to determine the real issue. Plus, it gives Staff a heads-up about what they are facing - if OP didn't include the link, prepare for hassles!
                        This sentence:
                        States 1x technical support > forum and 1x technical and app related questions > forum.
                        Since your inquiry is neither technical nor app related, but license related, this sentence does not apply.
                        In the spirit of improving this workflow, it would be great to get some input from you guys what sentence would be more fitting.
                        Looking forward for input.
                        • M Offline
                          M Offline
                          MostlyHarmless
                          Just to confirm that the forum thread was included as was a screen shot of the account details for both. maybe the positioning for the link which was at the very bottom caused the problem. At the end of the day I'm happy to do what is asked as I know I created this problem 😞 As for the wider discussion. It has been my (unproven) observation that, as the world has become faster and busier people on the hop just scan everything and if I'm being honest, dont organise it optimally. My simple low tech suggestion. Put thread links in the subject header like my ss. Simple, easy to do and standardises everything
                          I don't know what forum control you have but a popup from an admin with a picture would help
                          Something like this maybe:
                          Regards,
                          MH
                            This was handled in support now.
                            • C Offline
                              C Offline
                              ccfu
                              I think the mail is clear (technical support -> forum) but just to avoid any misunderstandings maybe consider specifiying what is meant by senstive issues (licensing, billing, legal, issues requiring the sharing of data).
                              • C ccfu
                                @ccfu great suggestion. I have put added your idea to the auto-reply now.
