  3. I built a thing using Cloudron - testers wanted
cloudronhostinghelp wanted
31 Posts 12 Posters 6.0k Views 11 Watching
  • 32463 3246
    @luckow aww too late! Jellyfin and Emby etc should not be on offer. Let me fix that for you 😄
    luckowL
    luckowL
    luckow
    @3246 The underlying problem is a lack of quotas for apps on Cloudron. Since this cannot be solved at the platform level, the only option is to set a volume per app. For example, you could define a volume of 10 GB for Jellyfin (or Nextcloud or Sogo ...), move the app into this volume, and give the customer the option to purchase more GB for more money.
    Problem solved.
    32463 1 Reply Last reply
    • luckowL luckow
      Problem solved.
      32463
      32463
      3246
      @luckow thanks, that sounds like a good idea. I'll investigate that.
      👉 Find our more www.bebraver.online
      • humptyH
        humptyH
        humpty
        Now the pricing is different. Initially, it was 5.99 for all but a few (Mattermost was one).
        • humptyH humpty
          32463
          32463
          3246
          @humptydumpty that looks right to me. I am looking at the caching which might be the root cause.
          • C
            C
            crazybrad
            @3246 One idea is to separate the apps into high, medium, low resources (especially considering @luckow cooking channel). Launch your service with attractive prices using just the "low" apps, where you won't get burned and need to jack up the prices, something your target audience will likely hate.
            Another thought is I personally find the list of Cloudron apps mind-boggling at times. I would also consider offering packages which might include bundles of apps that match business needs (e.g. CRM + Email + Bitwarden). You increase the transaction size, reduce the decision fatigue, and if you price it as Buy 3, Get 1 Free, the economies will surely drive some business. Solopreneur, freelancer, etc. Think about what they need and bundle a solution!
            • 32463
              32463
              3246
              Thanks @crazybrad. Originally I was thinking just to offer a small range of apps and offer bundle deals. It evolved into the current model with pricing tiers and a comprehensive assortment. However, I am working on a type of bundle like Nextcloud and Collabora. It's not yet working the way I want it to though.
              @nebulon et al, I am thinking of using /api/v1/apps/:id/configure/storage to move app data to an XFS volume to solve the 'unlimited storage quota' problem. I will use quotas with XFS.
              The approach:
              1. The setAppStorage() API call moves the app's data directory from the default /home/yellowtent/appsdata/<appid> to /mnt/volumes/appdata/svc_<id>/ on the XFS volume
              2. SSH-based quota management via sshExec()
              3. The XFS project quota is transparent to Cloudron — it just enforces a size limit on that subdirectory
              4. Backups/restores work as usual
              Bearing in mind the orchestrator is separate from the Cloudrons (multiples). Does that approach make sense? Am I missing something vital?
              • 32463 3246
                Hiho folks.
                Cloudron is awesome and I finally got around to building something that completely hides it from the users' eyes 😜
                To make it super easy, barely an inconvenience for the non-technical user, I created (drum roll 🥁 please):
                https://instantappshosting.com
                Which is now in public beta and you can have a free app or two in return for telling me what's not right (kinda a not-buy-two get a third free deal).
                Please DM me for the special Cloudron supporters coupon which gives you 100% off the sticker price.
                Hope you like it and thanks to the Cloudron crew and this amazing community. I look forward to extending my business license soon as I grow my Cloudrons.
                Over to you.
                @3246 nice simple approach, good for end-users.
                Limited online so have not checked - have you excluded apps which have licence restrictions, no managed service. Forget which, but there are a few.
                • J
                  @3246 have you see this already - https://docs.cloudron.io/guides/per-app-storage-limit ?
                    necrevistonnezrN
                    necrevistonnezrN
                    Super Fan
                    @timconsidine said in I built a thing using Cloudron - testers wanted:
                    Anything with a BUSL (Business Source License) or similar (NocoDB, Hashicorp products, etc.)
                      32463
                      32463
                      3246
                      @joseph thanks. Is it in the API yet?
                      • 32463 3246
                        Hello @3246
                        This can not be in the API since this is a file system setup.
