Contabo
Hi! I just bought a VPS on Contabo. Now I see it's not supported by Cloudron. Is there any workaround to install it anyway? Or will you start supporting Contabo?
Thanks for a great product.
//Michael
Cloudron has a "generic" option to install which works most of the time on other VPS, see https://cloudron.io/documentation/installation/
Have you tried that? -
Have you tried that?@necrevistonnezr Hey! Thanks... i did not see the generic option. I just saw that Contabo was not on the list. I will try that in a moment and tell you how it went.
