  2. Roundcube
  3. Help getting a Roundcube plugin installed and working
Scheduled Pinned Locked Moved Solved Roundcube
roundcubeplugins
4 Posts 2 Posters 2.5k Views 2 Watching
  • jdaviescoatesJ
    I'm trying to install this message label plugin:
    https://plugins.roundcube.net/packages/kreapptivo/message_label
    I've tried to follow the instructions at:
    https://cloudron.io/documentation/apps/roundcube/#plugins
    I went into the Roundcube web terminal and did:
    cd /app/data/plugins
    git clone https://umount@github.com/umount/message_label.git message_label
    chown -R www-data:www-data /app/data/plugins
    But then, if I paste:
    array_push($config['plugins'], 'message_label');
    Into /app/data/customconfig.php
    Well, then the app doesn't work at all - I just get a blank white screen.
    However, if I change it to:
    array_push($rcmail_config['plugins'], 'message_label');
    Then the app works, but the plugin doesn't appear to be have been installed/ working.
    Help! 🙂
      @jdaviescoates Most likely it's some bug in the plugin. It's not been developed for 5 years...
        @girish ah, damn. I was alerted to it by @necrevistonnezr who said it was new (I guess because it appears in new list here https://plugins.roundcube.net/explore/ ) but now I see what you mean.
        But, just for info, should array_push($config['plugins'], 'myplugin'); in the instructions actually be array_push($rcmail_config['plugins'], 'myplugin'); (i.e. $config or $rcmail_config).
        Thanks.
          @jdaviescoates it should be array_push($config['plugins'], 'myplugin');
