  3. HashiCorp Vault
HashiCorp Vault
32 Posts 5 Posters 14.4k Views 5 Watching
    @ultraviolet https://github.com/euanmcgregor/vault-cloudron/pull/2 fixes the mlock issue
    fbartelsF 1 Reply Last reply
      fbartelsF
      fbartelsF
      fbartels
      @girish ah, yes of course. You need to set the capability on the binary to make use of it (as non root).
        We can probably remove the supervisor use entirely and just use gosu exec cloudron:cloudron but maybe it's there for a reason
        • ultravioletU
          ultravioletU
          ultraviolet
          thanks both, I have never had a pull request before!! I am just looking at them now.
          • ultravioletU ultraviolet
            @fbartels I did try to get ldap going, the issue doing it automatically during install is you need to unseal and login to the vault before you can enable the LDAP. Which is hard when the login info is in a text file I am sure it is possible but my knowledge is a bit limited on that, plus it might not be idempotent.
            When I tried it manually it gave me that exact error I am still checking to see what the issue might be but I have kind of drawn a blank at the moment. Will take a fresh look later this week when I get a bit of time.
            fbartelsF
            fbartelsF
            fbartels
            wrote on last edited by fbartels
            #25
            @ultraviolet I managed to get ldap login working. In the end I needed to change the lookup attribute (it weird that you can configure a search filter for groups, but not for users).
            Change is in https://github.com/euanmcgregor/vault-cloudron/pull/4
            Edit: OIDC login is not yet working btw.
            ultravioletU 1 Reply Last reply
            • fbartelsF fbartels
              ultravioletU
              ultravioletU
              ultraviolet
              wrote on last edited by ultraviolet
              #26
              @fbartels awesome stuff on the LDAP. 👍
              I have made a few more tweaks with permissions and I have merged your request too. I have also removed the initial init for the vault. It is now done via the GUI which I like better because there are no keys being added to the container plus the user experience is a bit nicer. I have still kept the logic in in case someone wants to automate it.
              • ultravioletU
                ultravioletU
                ultraviolet
                Sorted, I think I have been running it for most of the day testing some stuff. Not sure if this is app store worthy but it interesting to learn about.
                Thanks for your help @fbartels and @girish
                  @ultraviolet I think it will be a great addition to the store. Are you able to add a license file to the package? Like https://git.cloudron.io/cloudron/pixelfed-app/-/blob/master/LICENSE (MIT). You can change copyright to be yours.
                  Once you do that, I can fix it up and get it published.
                  @fbartels @ultraviolet How does the LDAP login work ? I don't see ldap-config.sh called from anywhere.
                    ultravioletU
                    ultravioletU
                    ultraviolet
                    @girish sweet. I will do that no problem. The LDAP has to be done manually as the vault needs to be init'd and unsealed so you would need to execute the script manually.
                      I will add the LDAP notes to the docs then.
                        ultravioletU
                        ultravioletU
                        ultraviolet
                        @girish License has been added to the repo.
                          I have now published this as unstable! Thanks @ultraviolet . The repo is at https://git.cloudron.io/cloudron/vault-app and you should have push access already. I am writing tests before marking it as stable.
