  2. PeerTube
  3. PeerTube not starting
Scheduled Pinned Locked Moved Solved PeerTube
6 Posts 4 Posters 2.9k Views 4 Watching
  • S
    S
    stantropics
    since the latest update my peertube is not responding anymore, error in the logs is:
    2020-07-23 07:27:03.363 error: Cannot install application. {
    Jul 23 09:27:03 "err": {
    Jul 23 09:27:03 "stack": "Error: ENOENT: no such file or directory, mkdir '/app/code/storage'",
    Jul 23 09:27:03 "message": "ENOENT: no such file or directory, mkdir '/app/code/storage'",
    Jul 23 09:27:03 "errno": -2,
    Jul 23 09:27:03 "code": "ENOENT",
    Jul 23 09:27:03 "syscall": "mkdir",
    Jul 23 09:27:03 "path": "/app/code/storage"
    Jul 23 09:27:03 }
    Jul 23 09:27:03 }
    Does anybody know how to solve this?
    Thanks in advance. 🙂
      Was this from an update? The storage should be at /app/data/storage/. If you do a fresh install, does it work then as expected?
      imc67I S 2 Replies Last reply
        imc67I
        imc67I
        imc67
        translator Super Fan
        @nebulon I did a fresh install this morning and it works fine!
          S
          S
          stantropics
          @nebulon Peertube used to work and this happened after one of the last updates.
            @stantropics Since the package is still unstable, I haven't paid particular attention to seamless updates. There are still bugs in the package that needs to be sorted before the updates can be reliable. Are you able to start afresh?
            S 1 Reply Last reply
              S
              S
              stantropics
              @girish sure thing. Just wanted to let you know.
