  2. Grafana
  3. How to monitor Cloudron and Cloudron-apps with Grafana ?
Scheduled Pinned Locked Moved Grafana
6 Posts 3 Posters 2.3k Views 5 Watching
  • JOduMonTJ Offline
    JOduMonTJ Offline
    JOduMonT
    wrote on last edited by JOduMonT
    Hi;
    I just installed Grafana because I want to visualise few logs but I can't figure how to access Cloudron logs and/or logs from Cloudron Apps.
    I means it seams I need to install telegraph and/or a similar service on the host.
    How do you manage that ?
    1. Do you access /var/log directly via Grafana ?
    2. If yes which plugins are you using ?
    3. What is I want to monitor the performance of the MySQL used by a WordPress ?
    4. I see a Data Sources / Graphite, it is the same Graphite than Cloudron use, how I connect to each others ?
    In short how to use Grafana in a Cloudron context 😉
    • marcusquinnM Offline
      One of our team developed these plugins for monitoring WP performance for interest:
      • https://github.com/rossigee/wordpress-web-request-metrics
      • https://github.com/rossigee/woocommerce-prometheus-metrics
      Otherwise, maybe something in these links: https://www.qwant.com/?q=wordpress grafana plugin
      JOduMonTJ 1 Reply Last reply
      • marcusquinnM marcusquinn
        JOduMonTJ Offline
        JOduMonTJ Offline
        JOduMonT
        @marcusquinn sound great, but from what I understand, I need to install Prometheus to digest the information for Grafana.
        • jimcavoliJ Offline
          jimcavoliJ Offline
          jimcavoli
          @j-dufraigne Grafana supports lots of backends, among them Prometheus, but also supports Graphite, ElasticSearch, InfluxDB, Cloudwatch, and many more via data source plugins. Cloudron's internal graphs are powered by Graphite (fed via collectd in case you're curious). The linked items above do need prometheus...which is on my list, but hasn't made it in yet.
          JOduMonTJ 2 Replies Last reply
          • jimcavoliJ jimcavoli
            JOduMonTJ Offline
            JOduMonTJ Offline
            JOduMonT
            @jimcavoli thank for the list.
            So to link graphite to grafana I need to install Prometheus on the Cloudron host ?
            what about the JSON plugin ?
            https://grafana.com/grafana/plugins/simpod-json-datasource
              JOduMonTJ Offline
              JOduMonTJ Offline
              JOduMonT
              @jimcavoli said in How to monitor Cloudron and Cloudron-apps with Grafana ?:
              but maybe I should focus on Collectd since my goal is to monitor IPTables
