  2. WordPress (Managed)
  3. WebP Conversion plugin for WP errors
Scheduled Pinned Locked Moved WordPress (Managed)
9 Posts 2 Posters 3.5k Views 2 Watching
  • ianhyzyI Offline
    ianhyzyI Offline
    ianhyzy
    wrote on last edited by ianhyzy
    Hi there, I'm trying to install some automatic WebP conversion plugins and they're having issues. I tried with the free Webp converter for media plugin and get an error where it can't change .htaccess rules:
    Another plugin, Imagify, has the following error:
    The backup folder /app/data/wp-content/uploads/backup/ cannot be created or is not writable by the server, original images cannot be saved!
    Is this something I can create manually, or is this not a good idea given that I'm on the "managed" wordpress app and not the dev one?
    • ianhyzyI ianhyzy
      @ianhyzy yes, you can create that directory using the file manager if that's what the plugin requires. This is safe to do since it's inside /app/data .
      ianhyzyI 3 Replies Last reply
        ianhyzyI Offline
        ianhyzyI Offline
        ianhyzy
          ianhyzyI Offline
          ianhyzyI Offline
          ianhyzy
            ianhyzyI Offline
            ianhyzyI Offline
            ianhyzy
            @girish I made the folder but the plugin is still saying it doesn't have permission - is there anything special I need to do to give the wordpress user permission?
            • ianhyzyI ianhyzy
              @ianhyzy how do I reproduce this? I can regenerate images just fine with that plugin.
                I can also see webp files generated. But I just realized that you commented about htaccess issue with this plugin. Do you see that error on a fresh install?
                  The imagify also seems to work. That plugin uploads to some service it seems (not 100% sure but looks like it).
                  It also replaced inserted images at webp links using htaccess. I did not have to create any directory by hand, it created it automatically for me.
                  Can you try restarting the app and try again? I wonder if the permissions of the data directory somehow got messed up.
                  ianhyzyI 1 Reply Last reply
                    ianhyzyI Offline
                    ianhyzyI Offline
                    ianhyzy
                    @girish I got it working (I think?) but I didn't change anything, I just rebooted again. I also used WebP express which is free and has more features than the paid options. thanks for checking though!
