  3. issue with installing. init script failed
installation
2 Posts 2 Posters 857 Views 2 Watching
  • Kingkobra813K
    Kingkobra813K
    Kingkobra813
    I'm trying to install cloudron on fresh install of Ubuntu 20.04.2.0 LTS (Focal Fossa)
             Cloudron Setup (latest)
     Follow setup logs in a second terminal with:
     $ tail -f /var/log/cloudron-setup.log
     Join us at https://forum.cloudron.io for any questions.
    => Updating apt and installing script dependencies
    => Checking version
    => Downloading version 6.3.6 ...
    => Installing base dependencies and downloading docker images (this takes some time) ...Init script failed. See /var/log/cloudron-setup.log for details
    Below is the /var/log/cloudron-setup.log
    Running cloudron-setup with args : --
    Hit:1 http://us.archive.ubuntu.com/ubuntu focal InRelease
    Get:2 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
    Get:3 http://us.archive.ubuntu.com/ubuntu focal-backports InRelease [101 kB]
    Get:4 http://us.archive.ubuntu.com/ubuntu focal-security InRelease [114 kB]
    Get:5 http://us.archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages [1,163 kB]
    Get:6 http://us.archive.ubuntu.com/ubuntu focal-updates/main Translation-en [251 kB]
    Get:7 http://us.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages [847 kB]
    Get:8 http://us.archive.ubuntu.com/ubuntu focal-updates/universe Translation-en [178 kB]
    Fetched 2,768 kB in 2s (1,636 kB/s)
    Reading package lists...
    Building dependency tree...
    Reading state information...
    python3 is already the newest version (3.8.2-0ubuntu2).
    curl is already the newest version (7.68.0-1ubuntu2.6).
    software-properties-common is already the newest version (0.98.9.5).
    ubuntu-standard is already the newest version (1.450.2).
    0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
    readonly SOURCE_DIR="$(cd "$(dirname "${BASH_SOURCE[0]}")" && pwd)"
    readonly arg_infraversionpath="${SOURCE_DIR}/../src"
    function die {
        echo $1
        exit 1
    export DEBIAN_FRONTEND=noninteractive
    readonly ubuntu_codename=$(lsb_release -cs)
    readonly ubuntu_version=$(lsb_release -rs)
    # hold grub since updating it breaks on some VPS providers. also, dist-upgrade will trigger it
    apt-mark hold grub* >/dev/null
    apt-get -o Dpkg::Options::="--force-confdef" update -y
    Hit:2 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease
    Hit:3 http://us.archive.ubuntu.com/ubuntu focal-backports InRelease
    Hit:4 http://us.archive.ubuntu.com/ubuntu focal-security InRelease
    apt-get -o Dpkg::Options::="--force-confdef" upgrade -y
    Calculating upgrade...
    The following packages have been kept back:
      fwupd fwupd-signed libfwupd2 libfwupdplugin1 ubuntu-advantage-tools
    The following packages will be upgraded:
      base-files motd-news-config update-notifier-common
    3 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
    Need to get 198 kB of archives.
    After this operation, 0 B of additional disk space will be used.
    Get:1 http://us.archive.ubuntu.com/ubuntu focal-updates/main amd64 motd-news-config all 11ubuntu5.4 [4,544 B]
    Get:2 http://us.archive.ubuntu.com/ubuntu focal-updates/main amd64 base-files amd64 11ubuntu5.4 [60.6 kB]
    Get:3 http://us.archive.ubuntu.com/ubuntu focal-updates/main amd64 update-notifier-common all 3.192.30.9 [133 kB]
    Fetched 198 kB in 0s (473 kB/s)
    (Reading database ... 73387 files and directories currently installed.)
    Preparing to unpack .../motd-news-config_11ubuntu5.4_all.deb ...
    Unpacking motd-news-config (11ubuntu5.4) over (11ubuntu5.3) ...
    Preparing to unpack .../base-files_11ubuntu5.4_amd64.deb ...
    Warning: Stopping motd-news.service, but it can still be activated by:
      motd-news.timer
    Unpacking base-files (11ubuntu5.4) over (11ubuntu5.3) ...
    Setting up base-files (11ubuntu5.4) ...
    Installing new version of config file /etc/issue ...
    Installing new version of config file /etc/issue.net ...
    Installing new version of config file /etc/lsb-release ...
    motd-news.service is a disabled or a static unit, not starting it.
    Preparing to unpack .../update-notifier-common_3.192.30.9_all.deb ...
    Unpacking update-notifier-common (3.192.30.9) over (3.192.30.8) ...
    Setting up motd-news-config (11ubuntu5.4) ...
    Setting up update-notifier-common (3.192.30.9) ...
    Installing new version of config file /etc/cron.weekly/update-notifier-common ...
    Processing triggers for plymouth-theme-ubuntu-text (0.9.4git20200323-0ubuntu6.2) ...
    update-initramfs: deferring update (trigger activated)
    Processing triggers for install-info (6.7.0.dfsg.2-5) ...
    Processing triggers for man-db (2.9.1-1) ...
    Processing triggers for initramfs-tools (0.136ubuntu6.6) ...
    update-initramfs: Generating /boot/initrd.img-5.4.0-81-generic
    apt-mark unhold grub* >/dev/null
    echo "==> Installing required packages"
    debconf-set-selections <<< 'mysql-server mysql-server/root_password password password'
    debconf-set-selections <<< 'mysql-server mysql-server/root_password_again password password'
    # this enables automatic security upgrades (https://help.ubuntu.com/community/AutomaticSecurityUpdates)
    # resolvconf is needed for unbound to work property after disabling systemd-resolved in 18.04
    gpg_package=$([[ "${ubuntu_version}" == "16.04" ]] && echo "gnupg" || echo "gpg")
    mysql_package=$([[ "${ubuntu_version}" == "20.04" ]] && echo "mysql-server-8.0" || echo "mysql-server-5.7")
    apt-get -y install --no-install-recommends \
        acl \
        apparmor \
        build-essential \
        cifs-utils \
        cron \
        curl \
        debconf-utils \
        dmsetup \
        $gpg_package \
        ipset \
        iptables \
        libpython2.7 \
        linux-generic \
        logrotate \
        $mysql_package \
        nfs-common \
        openssh-server \
        pwgen \
        resolvconf \
        sshfs \
        swaks \
        tzdata \
        unattended-upgrades \
        unbound \
        unzip \
        xfsprogs
    acl is already the newest version (2.2.53-6).
    cron is already the newest version (3.0pl1-136ubuntu1).
    dmsetup is already the newest version (2:1.02.167-1ubuntu1).
    ipset is already the newest version (7.5-1~exp1).
    iptables is already the newest version (1.8.4-3ubuntu2).
    logrotate is already the newest version (3.14.0-4ubuntu3).
    unzip is already the newest version (6.0-25ubuntu1).
    xfsprogs is already the newest version (5.3.0-1ubuntu2).
    debconf-utils is already the newest version (1.5.73).
    pwgen is already the newest version (2.08-2).
    resolvconf is already the newest version (1.82).
    sshfs is already the newest version (3.6.0+repack+really2.10-0ubuntu1).
    swaks is already the newest version (20190914.0-1).
    apparmor is already the newest version (2.13.3-7ubuntu5.1).
    build-essential is already the newest version (12.8ubuntu1.1).
    cifs-utils is already the newest version (2:6.9-1ubuntu0.1).
    gpg is already the newest version (2.2.19-3ubuntu2.1).
    linux-generic is already the newest version (5.4.0.81.85).
    mysql-server-8.0 is already the newest version (8.0.26-0ubuntu0.20.04.2).
    nfs-common is already the newest version (1:1.3.4-2.5ubuntu3.4).
    openssh-server is already the newest version (1:8.2p1-4ubuntu0.3).
    tzdata is already the newest version (2021a-0ubuntu0.20.04).
    unattended-upgrades is already the newest version (2.3ubuntu0.1).
    libpython2.7 is already the newest version (2.7.18-1~20.04.1).
    unbound is already the newest version (1.9.4-2ubuntu1.2).
    0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
    echo "==> installing nginx for xenial for TLSv3 support"
    curl -sL http://nginx.org/packages/ubuntu/pool/nginx/n/nginx/nginx_1.18.0-2~${ubuntu_codename}_amd64.deb -o /tmp/nginx.deb
    • Kingkobra813K Kingkobra813
      => Checking version
      function die {
          echo $1
          exit 1
        motd-news.timer
          acl \
          apparmor \
          build-essential \
          cifs-utils \
          cron \
          curl \
          debconf-utils \
          dmsetup \
          $gpg_package \
          ipset \
          iptables \
          libpython2.7 \
          linux-generic \
          logrotate \
          $mysql_package \
          nfs-common \
          openssh-server \
          pwgen \
          resolvconf \
          sshfs \
          swaks \
          tzdata \
          unbound \
          unzip \
          xfsprogs
      @kingkobra813 Can you try running the script again and check if you get the same error? Looks like maybe nginx.org was maybe down temporarily?
      You can also check if this works:
      wget http://nginx.org/packages/ubuntu/pool/nginx/n/nginx/nginx_1.18.0-2~xenial_amd64.deb
