  2. N8N
  3. n8n Connection lost
n8n Connection lost
4 Posts 2 Posters 2.3k Views 2 Watching
  • G
    G
    genie
    i have cloudflare - kemp load balancer - cloudron self hosted. tried disabling proxy on cloud flare does work https or http i read a article that nginx could be causing the issue but cant disable to test. other cloudron app working or had issue but simple fix this one cant figure out after days of trying also tried different browser can anyone help
    • G genie
      @genie so things work if cloudflare proxying is disabled but does not work when it's enabled? Can you post a browser screenshot of what you are seeing when cloudflare proxying is enabled ? Do you use any of the other cloudflare features like rocket caching etc ?
      G 1 Reply Last reply
        G
        G
        genie
        @girish sorry I meant doesn't
        I have full ssl/tls encryption to origin server and proxy that's all. It seems to work briefly but time out I believe the connection isn't remaining active to the server.
        this is the log from cloudron
        n8n ready on 0.0.0.0, port 5678
        2021-09-30T06:00:52.000Z Version: 0.140.0
        2021-09-30T06:00:52.000Z ================================
        2021-09-30T06:00:52.000Z Start Active Workflows:
        2021-09-30T06:00:52.000Z - My flow
        2021-09-30T06:00:52.000Z => Started
        2021-09-30T06:00:52.000Z Editor is now accessible via:
        2021-09-30T06:00:52.000Z http://localhost:5678/
        2021-09-30T06:00:52.000Z Press "o" to open in Browser.
        2021-09-30T07:00:53.000Z
        2021-09-30T07:00:53.000Z Loading configuration overwrites from:
        2021-09-30T07:00:53.000Z - /app/data/.n8n/app-config.json
        2021-09-30T08:00:52.000Z
        2021-09-30T08:00:52.000Z Loading configuration overwrites from:
        2021-09-30T08:00:52.000Z - /app/data/.n8n/app-config.json
        2021-09-30T09:00:52.000Z
        2021-09-30T09:00:52.000Z Loading configuration overwrites from:
        2021-09-30T09:00:52.000Z - /app/data/.n8n/app-config.json
        2021-09-30T10:00:52.000Z
        2021-09-30T10:00:52.000Z Loading configuration overwrites from:
        2021-09-30T10:00:52.000Z - /app/data/.n8n/app-config.json
        2021-09-30T11:00:52.000Z
        2021-09-30T11:00:52.000Z Loading configuration overwrites from:
        2021-09-30T11:00:52.000Z - /app/data/.n8n/app-config.json
        2021-09-30T12:00:52.000Z
        2021-09-30T12:00:52.000Z Loading configuration overwrites from:
        2021-09-30T12:00:52.000Z - /app/data/.n8n/app-config.json
        2021-09-30T13:00:52.000Z
        2021-09-30T13:00:52.000Z Loading configuration overwrites from:
        2021-09-30T13:00:52.000Z - /app/data/.n8n/app-config.json
        2021-09-30T14:00:52.000Z
        2021-09-30T14:00:52.000Z Loading configuration overwrites from:
        2021-09-30T14:00:52.000Z - /app/data/.n8n/app-config.json
        2021-09-30T15:00:52.000Z
        2021-09-30T15:00:52.000Z Loading configuration overwrites from:
        2021-09-30T15:00:52.000Z - /app/data/.n8n/app-config.json
        2021-09-30T16:00:52.000Z
        2021-09-30T16:00:52.000Z Loading configuration overwrites from:
        2021-09-30T16:00:52.000Z - /app/data/.n8n/app-config.json
        2021-09-30T17:00:52.000Z
        2021-09-30T17:00:52.000Z Loading configuration overwrites from:
        2021-09-30T17:00:52.000Z - /app/data/.n8n/app-config.json
        2021-09-30T18:00:52.000Z
        2021-09-30T18:00:52.000Z Loading configuration overwrites from:
        2021-09-30T18:00:52.000Z - /app/data/.n8n/app-config.json
        2021-09-30T19:00:52.000Z
        2021-09-30T19:00:52.000Z Loading configuration overwrites from:
        2021-09-30T19:00:52.000Z - /app/data/.n8n/app-config.json
        2021-09-30T20:00:52.000Z
        2021-09-30T20:00:52.000Z Loading configuration overwrites from:
        2021-09-30T20:00:52.000Z - /app/data/.n8n/app-config.json
        2021-09-30T21:00:52.000Z
        2021-09-30T21:00:52.000Z Loading configuration overwrites from:
        2021-09-30T21:00:52.000Z - /app/data/.n8n/app-config.json
        2021-09-30T22:00:52.000Z
        2021-09-30T22:00:52.000Z Loading configuration overwrites from:
        2021-09-30T22:00:52.000Z - /app/data/.n8n/app-config.json
        2021-09-30T23:00:52.000Z
        2021-09-30T23:00:52.000Z Loading configuration overwrites from:
        2021-09-30T23:00:52.000Z - /app/data/.n8n/app-config.json
        2021-10-01T00:00:53.000Z
        2021-10-01T00:00:53.000Z Loading configuration overwrites from:
        2021-10-01T00:00:53.000Z - /app/data/.n8n/app-config.json
        2021-10-01T01:00:53.000Z
        2021-10-01T01:00:53.000Z Loading configuration overwrites from:
        2021-10-01T01:00:53.000Z - /app/data/.n8n/app-config.json
        2021-10-01T01:19:19.000Z
        2021-10-01T01:19:19.000Z Loading configuration overwrites from:
        2021-10-01T01:19:19.000Z - /app/data/.n8n/app-config.json
        2021-10-01T01:23:41.000Z
        2021-10-01T01:23:41.000Z Loading configuration overwrites from:
        2021-10-01T01:23:41.000Z - /app/data/.n8n/app-config.json
        • G genie
          @genie I see, this seems to be something networking related and since there are a few things in between the browser and n8n maybe some network issue in the middle (sorry, I don't have any experience with kemp). For a start, does it work without kemp and cloudflare proxying? i.e straight connection from browser to the Cloudron n8n installation? That would be a good place to start debugging.
