  3. Cannot mount Hetzner storage box for backups using SSHFS
hetznersshfsstoragebox
33 Posts 10 Posters 22.9k Views 11 Watching
  • SansGuidonS
    SansGuidonS
    SansGuidon
    Hey folks
    I recently struggled a bit with those steps as well, but it was because I had set a passphrase for my SSH keys at creation time and Cloudron does not prompt for that anywhere.
    Is that in the plans for the future @girish ?
    Thanks !
    About me / Now
      @SansGuidon how would automatic mounting on boot work if the ssh key had a passphrase? If you put the password in clear text in a config file, it's probably more insecure than having no password at all (especially if you reuse passwords or a part of it...).
      • SansGuidonS
        SansGuidonS
        SansGuidon
        #23
        @girish it could be an option to do it manually the first time for security reasons, with login keyring asked once.
        I mean I'd like that the option is at least given 🙂 , and of course not hardcoding the passphrase in the form.
        About me / Now
          @SansGuidon yeah, maybe. Have to investigate 🙂 Feel free to open a thread in https://forum.cloudron.io/category/97/feature-requests and we can see how much interest is there.
            Super Fan
            #25
            @girish said in Cannot mount Hetzner storage box for backups using SSHFS:
            It wouldn't. But I've got the same problem.
            I've already got a pair of SSH keys (with a passphrase) that I can successfully use to login to both my Storage Box and my VPS.
            But of course this doesn't work for the Backup set-up because it requires a passphrase.
            So, how can I create an additional set of non-passphrase keys just for use with the Storage Box?
            Thanks!
              You should be able to follow the docs at https://docs.hetzner.com/storage/storage-box/backup-space-ssh-keys for generating and using new keys.
                Super Fan
                #27
                @nebulon thanks but those Hetzner docs just aren't clear nor detailed enough and having read them lots of times I'm still none the wiser.
                It says:
                Warning: With the default settings, using ssh-keygen will overwrite an existing SSH key! As an alternative, with the parameter -f, you can specify a different file path.
                But that just isn't enough detail for me.
                It isn't at all clear about how to create/ add an additional pair of ssh-keys whilst keeping the existing ones intact.
                  #28
                  So you would create a new key pair with ssh-keygen -f ./newkey at least on linux. When prompted for a password, just press enter. Then you have the keypair in the current working directory where you ran that command.
                  From there you can upload the public portion of the key as mentioned in the hetzner docs and use the private key for your Cloudron configs.
                    It says:
                    Super Fan
                    #29
                    @jdaviescoates said in Cannot mount Hetzner storage box for backups using SSHFS:
                    It says:
                    OK, I had a play around and I've managed to do it:
                    On my local machine I did this:
                    ssh-keygen -f /home/josef/.ssh-storage/id_rsa
                    Generating public/private rsa key pair.
                    Enter passphrase (empty for no passphrase):
                    Enter same passphrase again:
                    Your identification has been saved in /home/josef/.ssh-storage/id_rsa
                    Your public key has been saved in /home/josef/.ssh-storage/id_rsa.pub
                    Then I copied the public key i.e. ~/.ssh-storage/id_rsa.pub up to my Hetzner Storage Box by doing this:
                    cat ~/.ssh-storage/id_rsa.pub | ssh -p23 uxxxxxx@uxxxxxx.your-storagebox.de install-ssh-key
                    uxxxxxx@uxxxxxx.your-storagebox.de's password:
                    Key No. 1 (ssh-rsa josef@josef-ThinkPad-T510) was installed in RFC4716 format
                    Key No. 1 (ssh-rsa josef@josef-ThinkPad-T510) was installed in OpenSSH format
                    Then I copied the contents of the private key i.e. ~/.ssh-storage/id_rsa into the private key box in the Cloudron backup configuration:
                    And then it worked - hooray!
                      Super Fan
                      @nebulon thanks. This was on a new Cloudron that still had default file system backups at /var/backups - now I've got this set-up and working OK I guess I can now completely delete that backups folder?
                        yes you can clear out the /var/backups folder
                          Super Fan
                          #32
                          @nebulon thanks, just to be doubly clear can I completely delete that /var/backups folder, or just delete it's contents? thanks!
                            Just purge contents of the folder or delete the folder and recreate it with the same permissions. Other bits of Linux sometimes put logs there.
