  3. Mixpost
Mixpost
164 Posts 15 Posters 130.3k Views 18 Watching
    @plusone-nick The redis IP is dynamic, so you should connect to it by name. You can use the credentials in /app/data/credentials.txt (this is the same as the env vars). Does that not work?
    P
    P
    plusone-nick
    @girish going to test further tonight
    ✌💙+1
      P
      P
      plusone-nick
      @girish got it working with the docker host name in .env (CLOUDRON_REDIS_HOST) it did not like the (CLOUDRON_REDIS_URL)
      Have to get Horizon installed and the stuff Scheduled, will report back 🫡
      ✌💙+1
      • P
        P
        plusone-nick
        @girish Got horizon installed, but it soon kills as there is no schedule set. The Mixpost instructions advise setting a mixpost-horizon.conf in /etc/supervisor/conf.d but as you know its read only.
        What is the best method to approach this?
        ✌💙+1
        • P
          P
          plusone-nick
          EDIT: Apologies I got the Schedule going with the cron job... It's the Horizon/Supervisor config at /etc/supervisor/conf.d which is the last blocker
          ✌💙+1
          • humptyH
            humptyH
            humpty
            Go, Nick. Go! 💪
            • P
              P
              plusone-nick
              @humptydumpty lol 🫡
              Final update for now: got all services "UP" and "working"
              BUT... - still need to have Horizon/Supervisor Config set as it only stays alive for a little, in that time I was able to push some posts through
              Dwindled down from 38 to 7 errors – something regarding: Illuminate & Symfony
              [2023-08-06 22:56:13] production.ERROR: Not enough arguments (missing: "name"). {"exception":"[object] (Symfony\Component\Console\Exception\RuntimeException(code: 0): Not enough arguments (missing: "name"). at /app/data/mixpost-pro-team-app/vendor/symfony/console/Input/Input.php:76)
              [stacktrace]
              #0 /app/data/mixpost-pro-team-app/vendor/symfony/console/Command/Command.php(321): Symfony\Component\Console\Input\Input->validate()
              #1 /app/data/mixpost-pro-team-app/vendor/laravel/framework/src/Illuminate/Console/Command.php(181): Symfony\Component\Console\Command\Command->run()
              #2 /app/data/mixpost-pro-team-app/vendor/symfony/console/Application.php(1081): Illuminate\Console\Command->run()
              #3 /app/data/mixpost-pro-team-app/vendor/symfony/console/Application.php(320): Symfony\Component\Console\Application->doRunCommand()
              #4 /app/data/mixpost-pro-team-app/vendor/symfony/console/Application.php(174): Symfony\Component\Console\Application->doRun()
              #5 /app/data/mixpost-pro-team-app/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(201): Symfony\Component\Console\Application->run()
              #6 /app/data/mixpost-pro-team-app/artisan(37): Illuminate\Foundation\Console\Kernel->handle()
              #7 {main}
              @girish @lao9s any thoughts or suggestions? 🤓
              ✌💙+1
              • P plusone-nick
                @humptydumpty lol 🫡
                [stacktrace]
                #7 {main}
                @plusone-nick said in Mixpost:
                this seems like some CLI is expecting more arguments (specifically --name or something)
                • P
                  P
                  plusone-nick
                  All errors cleared, and the system has been up for about two days going on three so i think it's safe to say its usable
                  Still need a workaround for one last step to complete: configure a process monitor Supervisor as it wants to write to /etc/supervisor/conf.d
                  Other than that i will document the steps i took and share them here before the end of the week
                  ✌💙+1
                  • P
                    P
                    plusone-nick
                    wrote on last edited by plusone-nick
                    #49
                    Cloudron + Mixpost + LAMP = +1
                    Note: this is for the Pro/Enterprise version of Mixpost
                    On a fresh LAMP install open a terminal
                    Step 1:
                     cd /app/data/
                    Step 2:
                     composer create-project inovector/mixpost-pro-team-app
                    Step 3: From the File Manager: You can use command line if you like
                     Change owner of the mixpost-pro-team-app folder to www-data
                    Step 4 Enter the mixpost-pro-team-app folder and open .env and Populate:
                    APP_URL=https://YOUR-DOMAIN
                    APP_ENV=production (WHEN READY)
                    APP_DEBUG=fale
                    Step 5: Populate SQL (creds @: /app/data/credentials.txt)
                    DB_HOST=172.18.30.1            /
                    DB_PORT=3306                     /
                    DB_DATABASE=CLOUDRON_MYSQL_DATABASE
                    DB_USERNAME=CLOUDRON_MYSQL_USERNAME
                    DB_PASSWORD=CLOUDRON_MYSQL_PASSWORD
                    NOTE: I had to put the slash / after the two DB_ env vars because the numbers were causing a line bug in the markdown while generating this post so make sure to remove them if you copy and paste the whole code block
                    Step 6: Populate REDIS (creds @: /app/data/credentials.txt )
                    REDIS_HOST=CLOUDRON_REDIS_HOST
                    REDIS_PASSWORD=CLOUDRON_REDIS_PASSWORD
                    REDIS_PORT=6379
                    - Save and Close
                    Step 7: Configure Database Tables:
                    cd /app/data/mixpost-pro-team-app
                    php artisan queue:batches-table
                    php artisan migrate
                    php artisan vendor:publish --tag=mixpost-config
                    Step 8: go to and edit
                    /app/data/apache/app.conf
                    Change both instances of: /app/data/public
                    To:
                    /app/data/mixpost-pro-team-app/public
                    - Save and Close
                    Step 9: On the CRON tab paste and save below:
                    * * * * * cd /app/data/mixpost-pro-team-app && php artisan schedule:run >> /app/data/null 2>&1
                    Step 10: Install Supervisor:
                    sudo apt-get install supervisor
                    Step 11: Cache Config:
                    php artisan config:cache
                    Step 12: Cache Routes:
                    php artisan route:cache
                    Step 13: Restart the APP to save the config
                    Step 14: Go to /app/data/mixpost-pro-team-app/ & Then Start Horizon
                    cd /app/data/mixpost-pro-team-app/
                    php artisan horizon
                    Step 15: Go to the landing page and register!
                    NOTE: i think there is still a need to figure out a solution to configure Supervisor: https://docs.inovector.com/books/server-configuration-mixpost/page/installing-configuring-supervisor
                    • Until then manually start the app with php artisan horizon as needed
                    • I Only have one license so I had to retrace the steps I took. If there are any errors please forgive me!
                    • If anyone runs into issues let me know. I will help troubleshoot and can rebuild my instance as needed =]
                      ✌️💖+1
                    ✌💙+1
                    humptyH 1 Reply Last reply
                    • P plusone-nick
                      Step 1:
                       cd /app/data/
                      Step 2:
                      APP_DEBUG=fale
                      DB_PORT=3306                     /
                      REDIS_PORT=6379
                      - Save and Close
                      php artisan migrate
                      To:
                      - Save and Close
                      php artisan horizon
                        ✌️💖+1
                      humptyH
                      humptyH
                      humpty
                      @plusone-nick I have a Pro license and haven't been able to try Mixpost yet. I'll give it shot soon and report back. Thank you so much for getting this going!!
                      • humptyH
                        humptyH
                        humpty
                        @plusone-nick Step 7 error: Could not open input file: artisan
                        I decided to continue anyway. Step 8 & 9 were easy. Step 10 error: bash: cd: app/Console/: No such file or directory
                        This is where I stopped. To backtrack a bit, what exactly do you mean by populate? I might have messed up Step 5 & 6. I tried to use the variables and not the actual values since it's mentioned they change on app restart so, CLOUDRON_MYSQL_DATABASE but that didn't get me through Step 7. Then, I tried the actual values of each field which were located in /app/data/credentials.txt. That didn't help with Step 7 either.
                        • humptyH humpty
                          P
                          P
                          plusone-nick
                          @humptydumpty you can't use the variables until you set them in the .env file
                          so you have to remove the placeholders like "CLOUDRON_MYSQL_DATABASE" and put the value for that variable which is located in /app/data/credentials.txt
                          They are like 16 and 32 characters long
                          ✌💙+1
                          • humptyH
                            humptyH
                            humpty
                            #53
                            OK, I made the changes and this is my .env file:
                            Still, step 7 with same error.
                            • humptyH
                              humptyH
                              humpty
                              #54
                              I think I'm doing Step 7 wrong. Do you paste all 3 commands together in the terminal or do these go elsewhere?
                              Edit: I'm reading thru Mixpost's docs, and I think I prematurely changed the APP_ENV to production. They have that listed after doing the artisan stuff and when the UI is up. I'll try again tomorrow with a fresh mind. Doing this after work is a horrible idea😵
                              • humptyH humpty
                                P
                                P
                                plusone-nick
                                @humptydumpty do them one at a time and i think you can change it back. I will try a build from scratch tomorrow and go thru the docs to update as needed.
                                ✌💙+1
                                • P
                                  P
                                  plusone-nick
                                  #56
                                  @humptydumpty i see it - your DB host is wrong: should be DB_HOST=172.18.30.1
                                  everything else looks correct.
                                  ✌💙+1
                                  • humptyH
                                    humptyH
                                    humpty
                                    I changed DB_Host to:
                                    • 172.18.30.1
                                    • 172.18.0.1 (this is the LDAP port for me)
                                    • 172.0.0.1 (this was the default in there originally)
                                    Then, I tried those values for the both fields, DB_Host and for REDIS_HOST just in case they both needed to match.
                                    Same step 7 error. I'm going to start again with a fresh LAMP install.
                                    • humptyH
                                      humptyH
                                      humpty
                                      #58
                                      I figured it out. I had to cd into the mixpost-pro-team-app folder before doing step 7.
                                      Line of 1 step 7 went OK. Line 2 with an error. Line 3 went OK.
                                      In Connection.php line 795:
                                        SQLSTATE[42S01]: Base table or view already exists: 1050 Table 'job_batches' already exists (Connection: mysql, SQL: create table `job_batches` (`id` varchar(255) not null, `name` varchar(255) not null, `to
                                        tal_jobs` int not null, `pending_jobs` int not null, `failed_jobs` int not null, `failed_job_ids` longtext not null, `options` mediumtext null, `cancelled_at` int null, `created_at` int not null, `finished_
                                        at` int null) default character set utf8mb4 collate 'utf8mb4_unicode_ci')
                                      In Connection.php line 580:
                                      Step 10: I nano'd into kernel.php and removed the two references of void, but there's no &. I found actual lines of code in there, so I left those untouched and saved.
                                      Step 11: not sure whether to stay in app/code or cd into /data or the mixpost app folder but running step 11's command shows this:
                                      Reading package lists... Done
                                      Building dependency tree... Done
                                      Reading state information... Done
                                      supervisor is already the newest version (4.2.1-1ubuntu1).
                                      W: Not using locking for read only lock file /var/lib/dpkg/lock-frontend
                                      E: Archives directory /var/cache/apt/archives/partial is missing. - Acquire (2: No such file or directory)
                                      Step 12: I encouter an error after running the command
                                      PHP Parse error:  syntax error, unexpected token "{" in /app/data/mixpost-pro-team-app/app/Console/Kernel.php on line 14
                                      Going to stop here for now. Changed my mind.
                                      I changed the environment from local to production. The app is live on my subdomain, despite all the errors. Woohoo!
                                      What does your kernel.php file look like?
                                      • humptyH humpty
                                        P
                                        P
                                        plusone-nick
                                        @humptydumpty remove the ":" at the end of each function and test
                                        ✌💙+1
                                        • humptyH
                                          humptyH
                                          humpty
                                          It's all green.
                                          I am still getting an error on step 11 when installing supervisor.
                                          But the rest of the steps went smoothly. Now to the real questions:
                                          • What does the upgrade process look like?
                                          • Do Cloudron backups work in case things go south?
