  3. Mixpost
Mixpost
164 Posts 15 Posters 127.6k Views 18 Watching
  • humptyH humpty
    @girish Mixpost requires a process monitor to be installed. I'm running into issues when trying to install Supervisor in the LAMP terminal (did not do it for the entire VPS). Does Cloudron have that installed or is it using a different process monitor? I ask because it seems to be installed according to the error message I get when trying to install supervisor.
    Reading package lists... Done
    Building dependency tree... Done
    Reading state information... Done
    supervisor is already the newest version (4.2.1-1ubuntu1).
    W: Not using locking for read only lock file /var/lib/dpkg/lock-frontend
    E: Archives directory /var/cache/apt/archives/partial is missing. - Acquire (2: No such file or directory)
    https://docs.inovector.com/books/server-configuration-mixpost/page/installing-configuring-supervisor
    @humptydumpty maybe you can use @service ? See https://docs.cloudron.io/apps/#cron . Those cron tasks run alongside the app.
    • humptyH
      humptyH
      humpty
      @plusone-nick With Dima's help, I fixed the issues that were blocking the upgrade from 0.10.4 to V1. I'll post the process in a separate post. However, my question about supervisor hasn't been answered by anyone yet, and I'm baffled how the app is working without it.
      My question to you is how did you get supervisor to install properly, and where did you install it? On the VPS level (as root alongside Cloudron) or within the app's terminal (containerized)?
      • humptyH
        humptyH
        humpty
        I reached out to Dima on Mixpost's Discord, and we figured out what is causing the error when running php artisan migrate. In short, there were two issues:
        • Mismatch in the migration file naming of what's in the file manager and what's in the database migration tables.
        • Wrong ownership of the migration table file that gets created with root and has to be www-data.
        To Fix it:
        You need to open both the file manager and access the database at yourdomain.com/phpmyadmin (login credentials are in /app/data/phpmyadmin_login.txt).
        In the file manager navigate to:
        /app/data/mixpost-pro-team-app/database/migrations
        change the ownership of any files with root to www-data
        Using phpmyadmin navigate to:
        migrations table
        Now, compare the file names of both and rename the files in the file manager to match what is in the database. For me, the date was different.
        Note: create_mixpost_v1_tables will not exist for you yet. That gets created during the upgrade steps later on.
        • humptyH
          humptyH
          humpty
          #84
          Full Upgrade Guide:
          I followed this doc page:
          https://docs.inovector.com/books/mixpost-pro-team/page/upgrading-to-v1
          In the terminal:
          cd to app/data/mixpost-pro-team-app
          run command:
          composer require inovector/mixpost-pro-team "^1.0"
          run command:
          php artisan make:migration create_mixpost_v1_tables
          Go to the file manager: /app/data/mixpost-pro-team-app/database/migrations
          and change ownership of 2023_08_21_121342_create_mixpost_v1_tables.php file from root to www-data
          Note: your file name will differ as it will have a different date at the beginning.
          Open 2023_08_21_121342_create_mixpost_v1_tables.php and replace its content with the migration content from the source guide I posted above. For reference, the code is:
          <?php
          use Illuminate\Database\Migrations\Migration;
          use Illuminate\Database\Schema\Blueprint;
          use Illuminate\Support\Facades\Schema;
          use Inovector\Mixpost\Models\Account;
          return new class extends Migration
              public function up(): void
                  Schema::table('mixpost_accounts', function (Blueprint $table) {
                      $table->boolean('authorized')->default(false)->after('data');
                  Account::withoutWorkspace()->update(['authorized' => true]);
                  Schema::table('mixpost_settings', function (Blueprint $table) {
                      $table->unique(['user_id', 'name']);
                  Schema::create('mixpost_user_two_factor_auth', function (Blueprint $table) {
                      $table->id();
                      $table->bigInteger('user_id')->unsigned()->index();
                      $table->foreign('user_id')->references('id')->on('users')->onDelete('cascade');
                      $table->text('secret_key');
                      $table->text('recovery_codes');
                      $table->timestamp('confirmed_at')->nullable();
                      $table->timestamps();
                  Schema::create('mixpost_pages', function (Blueprint $table) {
                      $table->id();
                      $table->uuid('uuid')->unique();
                      $table->string('name')->nullable();
                      $table->string('slug')->unique();
                      $table->string('meta_title')->nullable();
                      $table->text('meta_description')->nullable();
                      $table->string('layout');
                      $table->boolean('status')->default(0);
                  Schema::create('mixpost_blocks', function (Blueprint $table) {
                      $table->id();
                      $table->string('name');
                      $table->string('module');
                      $table->json('content')->nullable();
                  Schema::create('mixpost_page_block', function (Blueprint $table) {
                      $table->id();
                      $table->foreignId('page_id')->constrained('mixpost_pages')->onDelete('cascade');
                      $table->foreignId('block_id')->constrained('mixpost_blocks')->onDelete('cascade');
                      $table->json('options')->nullable();
                      $table->integer('sort_order')->nullable();
                  Schema::create('mixpost_configs', function (Blueprint $table) {
                      $table->id();
                      $table->string('group');
                      $table->json('payload')->nullable();
                      $table->unique(['group', 'name']);
          Run command:
          php artisan migrate
          Note: if you get an error at this step, see my post above this one for a fix. Basically, it is a file name mismatch of what's in the /migration folder and the migration table in the database. Rename the file manager files to match the database to fix.
          run commands (one at a time):
          php artisan vendor:publish --tag=mixpost-config --force
          php artisan route:cache
          php artisan mixpost:clear-settings-cache
          php artisan mixpost:clear-services-cache
          php artisan horizon:terminate
          Restart the app
          run commands:
          cd /app/data/mixpost-pro-team-app/
          php artisan horizon
          Make sure Horizon isn't killing itself and that it reports back. If so, you are DONE!
          • humptyH
            humptyH
            humpty
            #85
            @girish something is keeping horizon alive. Dima and I have no clue what or how. This cron job isn't doing that. Any idea what's going on? Is there some function that comes preinstalled with Cloudron that could be replacing/handling the supervisor job?
            * * * * * cd /app/data/mixpost-pro-team-app && php artisan schedule:run >> /app/data/null 2>&1
            • P
              P
              privsec
              If you install a fresh instance, do you need to worry about the upgrade? Or does this upgrade process have to be followed for each subsequent update?
              humptyH 1 Reply Last reply
              • P privsec
                humptyH
                humptyH
                humpty
                #87
                @privsec a fresh install will get you to v1 but you might still encounter an error when running php artisan migrate. In that case, follow my post above the upgrade guide to get that sorted out. I think we’ll encounter the same issues when upgrading in the future because the file ownership defaults to root and not www-data for newly added files, so the upgrade guide should apply to future updates.
                • humptyH humpty
                  P
                  P
                  plusone-nick
                  @humptydumpty Ayeee! 👍😎 GG +1
                  Well done. I have not messed with my instance recently - my Horizon would eventually kill or become inactive somehow and I would have to manually restart.
                  I was planning on a rebuild and more TS so i will test your steps and report back
                  ✌💙+1
                  • P plusone-nick
                    humptyH
                    humptyH
                    humpty
                    @plusone-nick I just checked Horizon and it's still running on my instance. I linked Twitter yesterday and made two posts which worked as intended. I think we got a working and stable guide going for Mixpost! The only issue left is figuring out the Horizon magic. How is it alive?! It feels like we created Frankenstein and now trying to see what makes him tick 😂
                    • humptyH
                      humptyH
                      humpty
                      @girish We sorted out all Mixpost installation errors but the Horizon mystery remains. Dima has no clue how Horizon is staying alive without Supervisor. Any thoughts?
                      • P
                        P
                        privsec
                        @humptydumpty and @plusone-nick
                        Do we need to have Horizon stay alive? Is there a way we can confirm it is up, and if it is not working, what do you do?
                        • P privsec
                          humptyH
                          humptyH
                          humpty
                          #92
                          @privsec Horizon has to stay alive. It's a must.
                          Go to your domain.com/mixpost/admin/system/status page and it should all be green like this.
                          Also, when you ran the command: php artisan horizon
                          If you wait a few seconds, you should see it report back something similar to a ping test:
                          bla bla bla.... 15ms
                          bla bla bla... 8ms
                          Otherwise, it will say KILLED instead.
                          If its not working, then you need to redo the installation and apply the "fix" that I posted in comment #83
                          • humptyH humpty referenced this topic on
                          • P
                            P
                            privsec
                            Ol, so do the steps listed in comment #49 and then comment #83
                            Would one need to do these same steps every time an upgrade is needed?
                            How do you retain customers account logins when doing an upgrade?
                            • P privsec
                              humptyH
                              humptyH
                              humpty
                              #94
                              @privsec Please keep in mind, I just installed it too and I haven't used the app before, so I'm in the same boat as you. However, since we worked out all the errors, the upgrade path should keep all existing posts/users/media/etc. intact.
                              Start with Nick's installation guide (#49) (skip step 10; somehow the app works without supervisor) and apply the fixes in #83 to get rid of the errors during the outlined steps. Yes, I believe we will have to do the fixes for each upgrade since any new files that get added by the upgrade will default to root ownership which need to be changed to www-data.
                              My suggestion is to try to install it the first time while keeping in mind that it's a test run just to familiarize yourself with the process. Then, you'll know when to apply the fixes during the intial installation. A cool thing you can do here is to create a backup of the fresh LAMP that you can restore to. If you delete the app and reinstall it, then all the credentials (mysql, phpmyadmin, etc.) will change.
                              One thing that wasn't mentioned yet, during the installation, you'll be asked "do you want to save these credentials". Say Yes!
                              I feel comfortable enough to start using the app for my own use. I wouldn't dare give it out to paid clients since it's not a packaged app and Horizon is working automagically but no one knows how because it shouldn't be able to stay alive! With that said, Cloudron backups work and the app itself is stable enough for production use.
                              • humptyH
                                humptyH
                                humpty
                                @privsec I just realized my mistake. For the initial installation follow #49 (skip step 10; somehow the app works without supervisor) and apply the fixes in #83 to get rid of the errors during the outlined steps.
                                In the future when you need to upgrade from v1.0 to v1.X, follow the upgrade guide in comment #84 and apply the fixes in comment #83. If you do #49 again, user data won't transfer over.
                                • P
                                  P
                                  privsec
                                  Ahh, awesome, ok. Thank you
                                  • humptyH humpty
                                    @humptydumpty interesting. LAMP app has no special code to run horizon in the background. There must be something else running it. Have you tried to use ps to figure out what the parent process of horizon is?
                                      humptyH
                                      humptyH
                                      humpty
                                      #98
                                      @girish I ran ps aux (had to look that up, I love that you're mistaking my copy/paste skills with actual coding knowledge 😂 )
                                      root@fb19c14f-edfa-432b-b7a1-89f306948ce0:/app/data/mixpost-pro-team-app# ps aux
                                      USER         PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
                                      root           1  0.0  0.1 320052 53260 pts/0    Ss+  Aug21   0:13 /usr/sbin/apache2 -DFOREGROUND
                                      root          17  0.0  0.0   2928  1008 pts/0    S+   Aug21   0:00 /bin/cat
                                      root          18  0.0  0.0   2928  1000 pts/0    S+   Aug21   0:01 /bin/cat
                                      root          22  0.0  0.0   5048  4032 pts/1    Ss   Aug21   0:00 /bin/bash
                                      root          34  0.1  0.2 292272 80148 pts/1    S+   Aug21   3:33 php artisan horizon
                                      root          36  0.1  0.2 292276 79832 pts/1    S+   Aug21   3:36 /usr/bin/php8.1 artisan horizon:supervisor fb19c14f-edfa-432b-b7a1-89f306948ce0-CXZh:supervisor-1 redis --workers-name=default --balance=auto --
                                      root          37  0.1  0.2 292276 80208 pts/1    S+   Aug21   3:22 /usr/bin/php8.1 artisan horizon:supervisor fb19c14f-edfa-432b-b7a1-89f306948ce0-CXZh:mixpost-heavy mixpost-redis --workers-name=default --balanc
                                      root        1528  0.0  0.2 369804 90236 pts/1    S+   Aug21   1:09 /usr/bin/php8.1 artisan horizon:work mixpost-redis --name=default --supervisor=fb19c14f-edfa-432b-b7a1-89f306948ce0-CXZh:mixpost-heavy --backoff
                                      www-data    9960  0.1  0.1 321308 43272 pts/0    S+   02:25   0:02 /usr/sbin/apache2 -DFOREGROUND
                                      www-data   10041  0.2  0.1 321056 42980 pts/0    S+   02:44   0:00 /usr/sbin/apache2 -DFOREGROUND
                                      root       10042  0.0  0.0   5048  4012 pts/2    Ss   02:45   0:00 /bin/bash
                                      root       10078  6.8  0.2 292228 79640 pts/1    S+   02:49   0:00 /usr/bin/php8.1 artisan horizon:work redis --name=default --supervisor=fb19c14f-edfa-432b-b7a1-89f306948ce0-CXZh:supervisor-1 --backoff=0 --max-
                                      root       10083  0.0  0.0   7480  3224 pts/2    R+   02:49   0:00 ps aux
                                      Edit: old dog learned a new trick (ps auxf)
                                      root@fb19c14f-edfa-432b-b7a1-89f306948ce0:/app/data/mixpost-pro-team-app# ps auxf
                                      root       10042  0.0  0.0   5048  4016 pts/2    Ss   02:45   0:00 /bin/bash
                                      root       10148  0.0  0.0   7480  3084 pts/2    R+   03:04   0:00  \_ ps auxf
                                      root          34  0.1  0.2 292272 80148 pts/1    S+   Aug21   3:35  \_ php artisan horizon
                                      root          36  0.1  0.2 292276 79832 pts/1    S+   Aug21   3:38      \_ /usr/bin/php8.1 artisan horizon:supervisor fb19c14f-edfa-432b-b7a1-89f306948ce0-CXZh:supervisor-1 redis --workers-name=default --balance
                                      root       10143  0.9  0.2 292228 79708 pts/1    S+   03:03   0:00      |   \_ /usr/bin/php8.1 artisan horizon:work redis --name=default --supervisor=fb19c14f-edfa-432b-b7a1-89f306948ce0-CXZh:supervisor-1 --back
                                      root          37  0.1  0.2 292276 80208 pts/1    S+   Aug21   3:23      \_ /usr/bin/php8.1 artisan horizon:supervisor fb19c14f-edfa-432b-b7a1-89f306948ce0-CXZh:mixpost-heavy mixpost-redis --workers-name=default
                                      root        1528  0.0  0.2 369804 90236 pts/1    S+   Aug21   1:09          \_ /usr/bin/php8.1 artisan horizon:work mixpost-redis --name=default --supervisor=fb19c14f-edfa-432b-b7a1-89f306948ce0-CXZh:mixpost-hea
                                      www-data    9960  0.1  0.1 321308 43276 pts/0    S+   02:25   0:04 /usr/sbin/apache2 -DFOREGROUND
                                      www-data   10041  0.1  0.1 321056 43004 pts/0    S+   02:44   0:02 /usr/sbin/apache2 -DFOREGROUND
                                      www-data   10090  0.1  0.1 321056 42988 pts/0    S+   02:51   0:01 /usr/sbin/apache2 -DFOREGROUND
                                      more copy paste info i found online 🙂
                                      root@fb19c14f-edfa-432b-b7a1-89f306948ce0:/app/data/mixpost-pro-team-app# ps -Flww -p 34
                                      F S UID          PID    PPID  C PRI  NI ADDR SZ WCHAN    RSS PSR STIME TTY          TIME CMD
                                      0 S root          34      22  0  80   0 - 73068 hrtime 80148   5 Aug21 pts/1    00:03:35 php artisan horizon
                                      root@fb19c14f-edfa-432b-b7a1-89f306948ce0:/app/data/mixpost-pro-team-app# cd /proc/34
                                      root@fb19c14f-edfa-432b-b7a1-89f306948ce0:/proc/34# ls
                                      arch_status  cgroup      coredump_filter     environ  gid_map   map_files  mounts      numa_maps      pagemap      root       setgroups     stat     task            uid_map
                                      attr         clear_refs  cpu_resctrl_groups  exe      io        maps       mountstats  oom_adj        patch_state  sched      smaps         statm    timens_offsets  wchan
                                      autogroup    cmdline     cpuset              fd       limits    mem        net         oom_score      personality  schedstat  smaps_rollup  status   timers
                                      auxv         comm        cwd                 fdinfo   loginuid  mountinfo  ns          oom_score_adj  projid_map   sessionid  stack         syscall  timerslack_ns
                                      root@fb19c14f-edfa-432b-b7a1-89f306948ce0:/proc/34# cat /proc/34/status
                                      Umask:  0022
                                      State:  S (sleeping)
                                      Tgid:   34
                                      Ngid:   0
                                      Pid:    34
                                      PPid:   22
                                      TracerPid:      0
                                      Uid:    0       0       0       0
                                      Gid:    0       0       0       0
                                      FDSize: 256
                                      Groups: 0
                                      NStgid: 34
                                      NSpid:  34
                                      NSpgid: 34
                                      NSsid:  22
                                      VmPeak:   292324 kB
                                      VmSize:   292272 kB
                                      VmLck:         0 kB
                                      VmPin:         0 kB
                                      VmHWM:     80148 kB
                                      VmRSS:     80148 kB
                                      RssAnon:           20828 kB
                                      RssFile:           37968 kB
                                      RssShmem:          21352 kB
                                      VmData:    21536 kB
                                      VmStk:       132 kB
                                      VmExe:      3020 kB
                                      VmLib:     62052 kB
                                      VmPTE:       312 kB
                                      VmSwap:        0 kB
                                      HugetlbPages:          0 kB
                                      CoreDumping:    0
                                      THP_enabled:    1
                                      Threads:        1
                                      SigQ:   2/120015
                                      SigPnd: 0000000000000000
                                      ShdPnd: 0000000000000000
                                      SigBlk: 0000000000000000
                                      SigIgn: 0000000000001000
                                      SigCgt: 0000000004024a07
                                      CapInh: 0000000000000000
                                      CapPrm: 00000000a80405fb
                                      CapEff: 00000000a80405fb
                                      CapBnd: 00000000a80405fb
                                      CapAmb: 0000000000000000
                                      NoNewPrivs:     0
                                      Seccomp:        2
                                      Seccomp_filters:        1
                                      Speculation_Store_Bypass:       thread force mitigated
                                      SpeculationIndirectBranch:      conditional force disabled
                                      Cpus_allowed:   ff
                                      Cpus_allowed_list:      0-7
                                      Mems_allowed:   00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000001
                                      Mems_allowed_list:      0
                                      voluntary_ctxt_switches:        339836
                                      nonvoluntary_ctxt_switches:     387995
                                      • humptyH humpty
                                        Umask:  0022
                                        State:  S (sleeping)
                                        Tgid:   34
                                        Ngid:   0
                                        Pid:    34
                                        PPid:   22
                                        TracerPid:      0
                                        Uid:    0       0       0       0
                                        Gid:    0       0       0       0
                                        FDSize: 256
                                        Groups: 0
                                        NStgid: 34
                                        NSpid:  34
                                        NSpgid: 34
                                        NSsid:  22
                                        VmPeak:   292324 kB
                                        VmSize:   292272 kB
                                        VmLck:         0 kB
                                        VmPin:         0 kB
                                        VmHWM:     80148 kB
                                        VmRSS:     80148 kB
                                        RssAnon:           20828 kB
                                        RssFile:           37968 kB
                                        RssShmem:          21352 kB
                                        VmData:    21536 kB
                                        VmStk:       132 kB
                                        VmExe:      3020 kB
                                        VmLib:     62052 kB
                                        VmPTE:       312 kB
                                        VmSwap:        0 kB
                                        HugetlbPages:          0 kB
                                        CoreDumping:    0
                                        THP_enabled:    1
                                        Threads:        1
                                        SigQ:   2/120015
                                        NoNewPrivs:     0
                                        Seccomp:        2
                                        Seccomp_filters:        1
                                        Cpus_allowed:   ff
                                        @humptydumpty Could it be that you started php artisan horizon manually on a web terminal ? Have you tested that it starts up automatically after restarting the app ? (which kills all the existing web terminal sessions).
                                          humptyH
                                          humptyH
                                          humpty
                                          @girish You're right, after a restart Horizon is inactive. Can this be turned on automatically via a cron like you suggested before? If so, what code should I be using?
