  3. Mixpost
Mixpost
164 Posts 15 Posters 132.9k Views 18 Watching
  • humptyH humpty
    @girish You're right, after a restart Horizon is inactive. Can this be turned on automatically via a cron like you suggested before? If so, what code should I be using?
    #101
    @humptydumpty yes, correct, you can just put it in the app's cron . Alternately, the LAMP app supports a startup script - https://docs.cloudron.io/apps/lamp/#custom-startup-script .
    • humptyH
      humptyH
      humpty
      #102
      App won't start. I think I know why its because the php artisan horizon has to be cd'd to /app/data/mixpost-pro-team-app/ first. How do you enter that in run.sh? startup script didn't work.
      After much trial and error, I got the cron method to start horizon automatically after I remembered the @service cron Girish mentioned in an earlier post.
      @service cd /app/data/mixpost-pro-team-app && php artisan horizon
      * * * * * cd /app/data/mixpost-pro-team-app && php artisan schedule:run >> /app/data/null 2>&1
      @plusone-nick add this cron to your install guide
      • humptyH
        humptyH
        humpty
        I updated from Mixpost Pro v.1.0.0 to v.1.2.0 using the official Mixpost update guide. But you need to do one thing beforehand, and another at the end to complete the steps on Cloudron.
        Step 1: navigate to the mixpost folder before starting the update process
        cd /app/data/mixpost-pro-team-app/
        Step 2: follow update guide https://docs.inovector.com/books/mixpost-pro/page/in-your-standalone-or-laravel-app
        Step 3: finish it off by running
         php artisan horizon
        Done.
        • humptyH
          humptyH
          humpty
          #104
          Starting to hit storage issues. I received a backup failed notification. The app size was around 100MB for a fresh install. Now it's 3.98 GB! I'm not really using the app yet or uploading any media so the increase must be from the last update I did (v1.0 to v1.2).
          Edit: The culprit is the log file located at /mixpost-pro-team-app/storage/logs/laravel.log (in my case it grew to over 5GB!). It had a lot of Redis references. The app's Redis is green in services and is using around 1/3 of the allocated 150MB so nothing out of the ordinary. The values in the .env file match what's in the credentials.txt file so that's good too. I'll update the post if Dima finds the root cause.
          a few lines of the laravel.log file: https://pastebin.com/bkWK1LGA
          • humptyH humpty
            @humptydumpty maybe you can symlink that file to somewhere in /run so that it is not part of the backup.
            humptyH 1 Reply Last reply
              humptyH
              humptyH
              humpty
              #106
              @girish I'll have to look into how I can accomplish that. Thanks for the hint!
              Edit: I don't see a /run folder. Do you mean run.sh?
              Edit 2: I think I found out how to do it via the run.sh method: https://docs.cloudron.io/apps/lamp/#custom-startup-script
              The example on that page is:
              # create symlinks
              rm -rf /app/data/var/cache
              mkdir -p /run/cache
              ln -sf /run/cache /app/data/var/cache
              correct me if I'm wrong, but for my use case it should be something like:
              # create symlinks
              rm -rf /app/data/mixpost-pro-team-app/storage/logs
              mkdir -p /run/logs
              ln -sf /run/logs /app/data/mixpost-pro-team-app/storage/logs
              Edit 3: The app started fine with the code above in run.sh. Now, it looks like this in the file manager, so I guess it's working.
              @girish I can't open the logs folder in the file manager; clicking on it does nothing. I'm worried that the log file will get too large and will require manual deletion in the future. What's the easiest way to access the folder or better yet, a way to auto-delete the log file after x days?
              • humptyH
                humptyH
                humpty
                @girish what's the file location for the /run folder that I symlinked earlier? I logged in via SFTP using FileZilla and can see the all the server folders (/) but haven't been able to locate the symlinked folder.
                • humptyH humpty
                  #108
                  @humptydumpty that sftp looks suspect. Only the /app/data directory is exposed via SFTP and not the entire container filesystem. Looks like you are logged in somewhere else.
                  There is no way to browse /run etc via SFTP. You have to use the Web Terminal.
                    humptyH
                    humptyH
                    humpty
                    #109
                    @girish I'm logging in as root and I'm positive that the IP is my Contabo VPS. On first login, the page looks like this.
                    Then, I can click on / and it shows this:
                    Any way, there's no way to access the /logs folder now via the web terminal in Cloudron dashboard. It's showing a grey file icon and double-clicking or right-clicking > open, does nothing. Brain fart! You're saying web terminal and I'm even typing it but thinking of the file manager 🤦 Nevermind!
                    • humptyH
                      humptyH
                      humpty
                      #110
                      To continue on the root SFTP access thing, I can see /box and /boxdata in the /yellowtent folder.
                      Should I be concerned about this?
                      • humptyH humpty
                        #111
                        @humptydumpty said in Mixpost:
                        concerned about? you are browsing the server's filesystem. The app runs as a container and has it's own filesytem. The app's filesystem is difficult to browse via SFTP.
                        • humptyH
                          humptyH
                          humpty
                          Ah, noted. I misunderstood what you meant and thought that I shouldn't have been able to browse/see the server folders. Thanks for bearing with me!
                          • jdaviescoatesJ
                            Super Fan
                            Any updates/ progress on getting this into the App Store? Could @Staff or any other @appdev help it along?
                            @lao9s I will buy a Pro licence as soon as this is in the Cloudron App Store 🙂
                            (also still kicking myself I didn't get a lifetime one while I could 🤦 even though I still wouldn't've been able to use it yet 😆 )
                              @jdaviescoates https://forum.cloudron.io/post/70435 still remains valid. It's not possible to package this for Cloudron .
                              jdaviescoatesJ robiR 2 Replies Last reply
                                Super Fan
                                @girish said in Mixpost:
                                Any chance you can change the way it works @lao9s ?
                                • rmdesR
                                  rmdesR
                                  rmdes
                                  Still really exciting to see this up and running on cloudron with hands on approach using the LAMP, I'm definitely going to try this out 🙂
                                    That's not quite entirely true, no? There is a writable part in /app/data and /var/run. It could be excluded from backups too depending on what directory it is downloaded to, say a hidden .pro dir.
                                    It's also possible to create an in-memory file system, and have it download the Pro version there at every start. Otherwise it's the lite version.
                                      humptyH
                                      humptyH
                                      humpty
                                      @robi I wish this can get sorted out. Keeping up with updates manually is a real PITA.
                                        I started a guide for Mixpost Lite in this thread:
                                        https://forum.cloudron.io/topic/11088/mixpost-lite-install-guide-for-lamp-app
                                        Let me know if I missed something.
                                          andreasduerenA
                                          andreasduerenA
                                          andreasdueren
                                          @robi said in Mixpost:
                                          BTW this also works no problem in the enterprise version.
