  3. FreeTAKServer for ATAK - Mesh Geo Information System
18 Posts 6 Posters 9.1k Views 6 Watching
  • C
    C
    CBCUN
    wrote on last edited by CBCUN
    ATAK (Android Team Awareness Kit):
    https://www.civtak.org/atak-about/
    FreeTAKServer Documentation:
    https://freetakteam.github.io/FreeTAKServer-User-Docs/Installation/Docker/
    FreeTAKServer Code:
    https://github.com/FreeTAKTeam/FreeTakServer
    FreeTAKServer Preview:
    ATAK Preview:
    • jdaviescoatesJ
      Super Fan
      Sounds very interesting!
      FTS allows you to connect ATAK clients to share geo information, to chat with all the connected clients, exchange files and more.
      From https://github.com/FreeTAKTeam/FreeTakServer
      • C
        C
        CBCUN
        FreeTAK UAS (FTUAS) is an Android application that can:
        • Control any DJI drone supported by the current DJI SDK
        • Stream the position of the drone to all the connected TAK clients
        • Stream the video Feed to all the connected TAK clients
        • Create a "target" on the map and stream with all the connected TAK clients
        • M
          Mastadamus
          I would absolutely love and use the hell out of this. heck i'd pay a bit for this.
          C 1 Reply Last reply
          • M Mastadamus
            C
            C
            CBCUN
            @Mastadamus said in FreeTAKServer for ATAK - Mesh Geo Information System:
            I think so, too. Programmer before. What and how much do you need to package the tool? ๐Ÿ™‚
            • C CBCUN
              @CBCUN This is the dockerfile, which shows that it's all python3 and the main issue I see so far is that it exposes a bunch of ports.
                C
                C
                CBCUN
                @robi said in FreeTAKServer for ATAK - Mesh Geo Information System:
                Ok, but issues you can solve, right? ๐Ÿ˜‰
                • C
                  C
                  CBCUN
                  Which programmer is up to the challenge? Give us an amount for the effort!
                  • C CBCUN
                    Super Fan
                    @CBCUN said in FreeTAKServer for ATAK - Mesh Geo Information System:
                    You could try tagging @appdev which should notify everyone on the forum who has packaged an app for Cloudron to date (I try to only use it sparingly, but if someone is offering them cash perhaps now is a good time - although now I've done it no need for you to do it too ๐Ÿ™‚ )
                      C
                      C
                      CBCUN
                      @jdaviescoates Ok. Thx ๐Ÿ™‚
                      • C CBCUN
                        @CBCUN The solution should be similar to the Traccar app.
                          C
                          C
                          CBCUN
                          @robi OK. Would you give the app packaging a try? How can i help ( iยดm not a programmer, should i do a little bit of research or collect money?) ;)?
                          • C CBCUN
                            @CBCUN there is a forum category for developers and there are some offering packaging assistance for a fee. Check it out.
                            • C CBCUN referenced this topic on
                            • subvenS
                              subvenS
                              subven
                              @CBCUN you just want the FreeTakServer packed as an Cloudron app? At first glance it does not look that complicated --> FreeTakServer Dockerfile
                              • subvenS subven
                                C
                                C
                                CBCUN
                                @subven said in FreeTAKServer for ATAK - Mesh Geo Information System:
                                Exactly. Ideally in such a way that the app can be made available to the community (via AppStore).
                                • C CBCUN
                                  C
                                  C
                                  CBCUN
                                  @CBCUN Still looking for some @appdev or upvoting...
                                  • C
                                    C
                                    CBCUN
                                    Still looking for Devs to set this up. Pushing ๐Ÿ™‚
                                    @appdev
                                    • L
                                      CA Maintainer
                                      If self-hosting this, what sort of hardware requirements would there be to make it work well?
