  3. Certificate expiry problems (perhaps related to DNS migration)
certificates
11 Posts 4 Posters 3.4k Views 4 Watching
  • R Offline
    R Offline
    Robin
    So as I discussed a while ago, I did a DNS migration (https://forum.cloudron.io/topic/7429/how-to-do-a-smooth-dns-migration/2) from a manually updated wildcard, to Hetzner. For the most part, this has gone smoothly, but I seem to be running into a corner case with Lets Encrypt certificates. I've started getting upcoming expiry warnings for a bunch of domains now. I tried to force renewal, which gave me the following logs (for each service on subdomain.example.com)...
    Aug 15 12:01:04 box:tasks update 6255: {"percent":76,"message":"Ensuring certs of xxx.subdomain.example.com"}
    Aug 15 12:01:04 box:reverseproxy ensureCertificate: xxx.subdomain.example.com certificate already exists at /home/yellowtent/platformdata/nginx/cert/_.subdomain.example.com.key
    Aug 15 12:01:04 box:reverseproxy expiryDate: /home/yellowtent/platformdata/nginx/cert/_.subdomain.example.com.cert notAfter=Oct 26 11:00:56 2022 GMT daysLeft=72.04156950231481
    Aug 15 12:01:04 box:reverseproxy providerMatchesSync: /home/yellowtent/platformdata/nginx/cert/_.subdomain.example.com.cert subject=CN = *.subdomain.example.com domain=*.subdomain.example.com issuer=C = US, O = Let's Encrypt, CN = R3 wildcard=true/true prod=true/true issuerMismatch=false wildcardMismatch=false match=true
    This looks okay, in theory, but then at the end I see the following:
    Aug 15 12:01:04 box:reverseproxy expiryDate: /home/yellowtent/platformdata/nginx/cert/xxx.subdomain.example.com.cert notAfter=Sep 3 11:00:56 2022 GMT daysLeft=19.041567395833333
    And the daysLeft here seems to match up with the mail warnings I'm getting...
    So they don't seem to be renewing properly... Is there something I can do to force a renewal? And is this some kind of a bug/unhandled edge case in Cloudron, perhaps caused by the DNS provider switch?
    • R Robin
      @Robin There seems to be two certs . The one with _ is the wildcard cert. The one with xxx is the single domain cert. I guess this can happen when you switch the DNS provider to programmatic to manual/wildcard or vice-versa.
      Currently, are you using programmatic DNS or manual/wildcard ? If you go to the Location view of the app and click on Save, it should use the certificate of the latest configuration.
      R humptydumptyH 2 Replies Last reply
        R Offline
        R Offline
        Robin
        @girish I switched from wildcard over to programmatic (via Hetzner). I didn't update individual apps after that change, but I guess I can try that and see what happens...
        • R Robin
          @Robin Should ideally not have to do this individually. Renew certs should do this in the background, but clearly isn't...
          R 1 Reply Last reply
            R Offline
            R Offline
            Robin
            @girish Hmm, one remaining problem... What do I do about my dashboard, which is also affected by the same problem? Would changing its location temporarily (and then switching back) fix it?
              humptydumptyH Offline
              humptydumpty
              @girish said in Certificate expiry problems (perhaps related to DNS migration):
              Is it possible to have this note mentioned in the docs and somewhere on the "Domains & Certs" page?
              Thanks!
              • R Robin
                @Robin If you delete the dashboard nginx config with the name my.xx.conf in /home/yellowtent/platformdata/nginx/applications and then systemctl restart box, it should fix things up.
                • R Offline
                  R Offline
                  Robin
                  So, I still got more cert warnings despite moving the app locations around, and removing the dashboard config, so I decided to try be a bit more brutal about it. I removed the wildcard cert:
                  rm /home/yellowtent/platformdata/nginx/cert/_.xxx.*
                  Restarted box, and everything seemed OK. Then I triggered Renew All Certs again, and ... ended up with a new wildcard cert! That doesn't make sense to me... Is there something I can look at that would explain why it wanted to create that? Or some proper way I can nuke the DNS configuration from orbit so it ends up sensible again?
                  • R Robin
                    @Robin Anything in the logs? This might be a bit tricky to get to the bottom of since the code assumes things when certs and configs are missing and starts from "scratch".
                    • R Offline
                      R Offline
                      Robin
                      Nothing that mentioned the _ (wildcard) cert at least, which is part of why I'm stumped. I don't know what is creating it, or where to look.
                      • jamesJ Online
                        jamesJ Online
                        Closed due to inactivity
