  2. Commento++
  3. Issue : Anybody can signup - no way to block signup process
Scheduled Pinned Locked Moved Solved Commento++
4 Posts 3 Posters 1.4k Views 4 Watching
  • P Offline
    P Offline
    parhelium
    Hey,
    I noticed anybody can signup to my instance of commento++.
    It will be great if there will be option to block new signups.
    Thanks !
    • subvenS Offline
      subvenS Offline
      subven
      Please take a look at the docs. It is described there.
        Yes, once disabled, you will see "New user registrations are forbidden and closed."
          P Offline
          P Offline
          parhelium
          @girish confirm it works.my bad.
