  3. Cloudron instances keep crashing because of NFS backup mount is not availlable
backups
6 Posts 3 Posters 2.5k Views 3 Watching
  • O Offline
    O Offline
    opensourced
    Within the last month, I had 3 cloudron instances (running productive apps for clients) crashing, because the NFS mount could not be mounted and the root filesystem was used instead.
    I find it frustrating to run into this issue so often. Mostly because I know it can happen every moment and I cant do anything about it.
    How about adding a checkbox in the backup settings with the title "Skip backup if storage is not available"?
    • O opensourced
      nebulonN Away
      nebulonN Away
      @opensourced this is fixed in latest versions of Cloudron, the backup task will stop if the it is not mounted. On which Cloudron version are you?
      O 1 Reply Last reply
        O Offline
        O Offline
        opensourced
        @nebulon The instance that crashed on sunday is (and was at that time) running v7.2.5
        • O opensourced
          nebulonN Away
          nebulonN Away
          @opensourced this is only fixed in the upcoming patch release 7.3.3
            O Offline
            O Offline
            opensourced
            @nebulon nice! looking forward to this.. do you already know the release date?
            • O opensourced
              girishG Do not disturb
              @opensourced you can update to 7.3.2 which has the fix for this. Settings -> Check For Updates. It will say Unstable but it should be stable (there are a few bugs outstanding but nothing major).
