  2. SOGo
  3. ActiveSync
ActiveSync
Scheduled Pinned Locked Moved Solved SOGo
41 Posts 11 Posters 24.4k Views 12 Watching
    In the latest package now has active sync enabled. It should be enabled without having to adjust configs just update to latest. Please report back any issues!
    Jarod
    @nebulon Works great. Maybe add an hint somewhere, that you have to point you mail client to the sogo domain and not the mail server domain. It is logical but I only got to the conclusion after a few seconds of receiving an error.
    • P
      P
      privsec
      What what!?!
      Active sync is now working!?!!!
      • S
        S
        scurtis
        What is the format of the Activesync URL for SoGo?
        I was trying to set it up on iOS which logs in fine but doesnt sync. Am assuming the Activesync URL is more than just the https://sogo.domain.name
        Thanks.
          Something like:
          • S
            S
            scurtis
            Thanks for the screenshots - all working now. Appears to be working well - this is a really good choice for email/calendar/contacts all synced to iOS now.
            I also tried adding autodiscover DNS CNAME and SRV entries as per a post on the SOGO mailing list - but that doesn't seem to work. Might be nice if the correct DNS entries for this could be worked out to simplify client setup.
              @scurtis from what I have read in msn docs, you have to set up a autodiscover.xml. Maybe you can try https://docs.cloudron.io/email/#autodiscoverxml
              • J
                Jarod
                wrote on last edited by Jarod
                #27
                • andreasduerenA
                  andreasduerenA
                  andreasdueren
                  Seems to work well on iOS, thank you so much for finally implementing this!
                  However on macOS I can connect to it but it won't actually load my mails in the app:
                  Any idea what's wrong?
                  fbartelsF 1 Reply Last reply
                    fbartelsF
                    fbartelsF
                    fbartels
                    @andreasdueren the macOS mail app only implements ews (exchange webservices) and not eas (exchange active sync).
                    • C
                      C
                      crazybrad
                      @andreasdueren FYI, I found this Apple reference and it seems to imply a difference between mac OSX and iOS/iPadOS support... which was more clearly summarized by @fbartels:) And this Microsoft reference on the difference between EAS and EWS.
                        G
                        G
                        Guillaume
                        @nebulon Many thanks for this !
                        It seems to work pretty well, take my subscription Cloudron ! 🙂
                        • J
                          Jarod
                          @nebulon ActiveSync is kinda hard on resources. How can I disable it, so that my users cannot use it? I tried to edit the nginx.conf in the SOGo pack via terminal, but it's read-only, so I don't wanna mess with it.
                            How is this showing up resources wise? I would assume this will only impact, if active sync clients are used.
                            J 1 Reply Last reply
                              Jarod
                              @nebulon I added three of my accounts on my iPhone. In roundabout 5 seconds, it produced more the 500 lines of log. And this all the time.
                                Have you tried to use imap/smtp instead of active sync on the iphone then?
                                  Jarod
                                  @nebulon Yes. It works way better. The question still is, how I can block active sync. I have roundabout 30 user on my instance and I don't want one to accidentally ActiveSync.
                                    ActiveSync is indeed a bit hard to test from my side. Is the main reason here that the logs are flooding the system or something else? Maybe we have to reduce logging. Have you looked upstream with SOGo to get some info on active sync and resource usage?
                                      Jarod
                                      @nebulon I cannot really post a log, because most of them contains folder names but it seams, that every device goes through all of its folders very often and it gets logged. 10 seconds of log, after the initial sync with the device, contained without spaces, 49534 letters in 53 lines. Mostly LIST and stuff like that.
                                        Have you tried to reduce the debug logs by editing sogo.conf in the app? For example there is SOGoDebugRequests which may be good to have to NO and there are potentially other config variables (after editing the file you have to restart the app).
                                          I have disabled the verbose logging now in the latest package. I will look into making ActiveSync optional next.
