  2. AdGuard Home
  3. AdGuard Home Wildcard aliases
Scheduled Pinned Locked Moved Solved AdGuard Home
porkbunwildcard
56 Posts 6 Posters 35.5k Views 6 Watching
  • L lukas
    @Kubernetes I want to use DoT / DoH on my Android / iOS devices and allow only my clients to use this AdGuard Home instance. I'm doing something wrong?
    KubernetesK
    KubernetesK
    Kubernetes
    @lukas Okay, then you don't need an Alias in Cloudron for AdGuard. What you need to do is to configure the ClientIDs as I mentioned in your other Thread directly in the AdGuard Home Admin Interface 🙂
    L 1 Reply Last reply
    • KubernetesK Kubernetes
      lukas
      wrote on last edited by lukas
      #22
      @Kubernetes But If I don't need an Alias for AdGaurd in Cloudron, how do I set the Client Identifier ind Adroids Private DNS and / or in AdGuard App? Sorry but it's confusing for me.
      It this Guide https://docs.cloudron.io/apps/adguard-home/#security i need DoT for my Android devices, to an wildcard alias is needed to identify my Android devices
      KubernetesK 1 Reply Last reply
      • L lukas
        KubernetesK
        KubernetesK
        Kubernetes
        @lukas You have to set the ClientID in Adguard Home Admin Interface, but not in Cloudron. Then all you need to do is to combine the URL to your Adguard Home with the ClientID you have configured already.
        This should look like this:
        https://adguard.yourdomain.tld/dns-query/CLIENTID
        I assume that you never had a look at the Adguard Home Admin Interface, did you? There is a tab "Setup Assistant" which explains how to do it with Android, Windows, Browser, iOS, Router....
        I hope that helps?
          I hope that helps?
          lukas
          #24
          @Kubernetes said in AdGuard Home Wildcard aliases:
          yes, but for Android I have to use DoT and not DoH ?
          DoT
          DNS over TLS (DoT) is supported and uses port 853 by default. DoT is required for Android's "Private DNS mode" (available since Android 9.0 Pie).
          To use Client ID identifiers, you must add a wildcard subdomain alias of the form *.adguard.domain.com.
          • L lukas
            DoT
            KubernetesK
            KubernetesK
            Kubernetes
            @lukas Ahh, okay, I don't use DoT, so I don't know how this is setup correctly.
              lukas
              @Kubernetes as I understand this, for DoT I need a wildcard domain. In AdGuard Adnroid app I can use DoH with your string, this works fine.
              • L lukas
                @girish so until issue is fixed no chance to use AdGuard Home DoT / DoH ?
                @lukas to give an update, I still haven't gotten a response from Porkbun. They were supposed to reply last monday. Sent them a reminder on Friday.
                  lukas
                  #28
                  @girish I switched now from Porkbun API to Wildcard Domain. How to get it working now?
                  Just get this:
                  Apr 29 22:16:09 2023/04/29 20:16:09.334842 [error] handling tcp: reading msg: reading len: remote error: tls: unknown certificate authority
                  Apr 29 22:16:09 2023/04/29 20:16:09.584416 [error] handling tcp: reading msg: reading len: remote error: tls: unknown certificate authority
                  Apr 29 22:16:09 2023/04/29 20:16:09.602320 [error] handling tcp: reading msg: reading len: remote error: tls: unknown certificate authority
                  • L lukas
                    Just get this:
                    @lukas Yeah, so they never got back 😕 I even sent them a reminder. Please point them to this thread (if you are a customer). I sent mails from girish@cloudron.io
                    Unfortunately, one cannot create a wildcard certificate from the Wildcard Domain. This is because Let's Encrypt requires you to set values in the DNS to get a wildcard cert. With a wildcard provider, Cloudron has no way to program the DNS. Only fix right now is to switch to some other programmable DNS provider. Sorry...
                    L 2 Replies Last reply
                      lukas
                      #30
                      @girish is there any other way to do this? I switched my Nameservers to Bunny.net from this domain, so I wait to next cloudron release 🙂
                      • L lukas
                        @lukas Yup, so in next release, it should work 🤞 You have to switch to some other provider for something immediate (like today).
                          lukas
                          @girish ok, then I will wait for next release. Will it come today? 🙂
                            lukas
                            @girish said in AdGuard Home Wildcard aliases:
                            Yeah, so they never got back I even sent them a reminder. Please point them to this thread (if you are a customer). I sent mails from girish@cloudron.io
                            you got maybe any ticket number? I will contact them now
                            • L lukas
                              @lukas they didn't give me one.
                                lukas
                                @girish update to latest Cloudron Version, bunny.net integration is working fine (thanks for this), but DoT on my Android Phone is still not working, in AdGuard Home Log I see:
                                May 02 10:35:57 2023/05/02 08:35:57.599729 [error] handling tcp: reading msg: reading len: remote error: tls: bad certificate
                                May 02 10:35:57 2023/05/02 08:35:57.907614 [error] handling tcp: reading msg: reading len: remote error: tls: bad certificate
                                May 02 10:35:57 2023/05/02 08:35:57.914408 [error] handling tcp: reading msg: reading len: remote error: tls: bad certificate
                                What is wrong? I use <clientname>.adguard.mydomain.TLD and I added an Alias (*.adgaurd) to AdGuard Home.
                                What is wrong?
                                Thank you and Regards,
                                Lukas
                                • L lukas
                                  What is wrong?
                                  Lukas
                                  @lukas If you go to Location view and click Save (without making any changes), does that help the situation ? That should maybe (re)trigger getting the cert.
                                    lukas
                                    @girish did not help. This looks also not fine:
                                    Certificate chain is invalid
                                    • L lukas
                                      @lukas can you check the output of openssl x509 -text -in /etc/certs/_.adguard.domain.cert in the web terminal of adguard ? Does it seem like a valid Let's Encrypt certificate?
                                        lukas
                                        @girish I see an output. Which part do you need from this ouput?
                                        • L lukas
                                          @lukas The first few lines should give us the issuer and expiry like this:
                                          Certificate:
                                              Data:
                                                  Version: 3 (0x2)
                                                  Serial Number:
                                                      04:1d:71:e7:48:c7:d3:80:02:ac:c1:ac:5b:79:e5:3f:3e:4e
                                                  Signature Algorithm: sha256WithRSAEncryption
                                                  Issuer: C = US, O = Let's Encrypt, CN = R3
                                                  Validity
                                                      Not Before: Apr 15 02:11:00 2023 GMT
                                                      Not After : Jul 14 02:10:59 2023 GMT
                                          Then later down, you should also see the SAN section:
                                                      X509v3 Subject Alternative Name:
                                                          DNS:*.girish.in
                                          Ideally, there should the wildcard and non-wildcard DNS listed above in your case.
