  2. Surfer
  3. Login does not work anymore - White page
Scheduled Pinned Locked Moved Solved Surfer
17 Posts 6 Posters 3.0k Views 6 Watching
  • P Offline
    P Offline
    Patmo.de
    with the latest update, I cannot login into surfer anymore. There is no longer a web-login page available and when I try to login from the cloudron-backend, I will be logged in, but I cannot do anything there, since the backend is shown for second and then the loading-animation takes over and does never stop.
    Surfer was running quite well over the last month until there was the latest update.
    When I try the web-login, the page tries to load something but the page itself stays blank. There is no login form anymore.
    The Cloudron Version is 7.4.3 and there were some security updates that needed a reboot yesterday, but the problem came directly after updating surfer.
    I have two cloudron instances and this happens on both of them (tried it with the second one just a few minutes ago).
    In the javascript console I can see that /api/oidc/login throws an error 500.
    Any hints on what might be going wrong or how I can fix this are much appreciated.
    Thanks in advance
    Patrick
      https://forum.cloudron.io/topic/9515/surfer-version-6
        @Patmo-de the auth logic changed from ldap to openID in the backend with surfer 6. Could you check the app logs for that 500 error to get more info from the server side?
        Have you tried different browsers or maybe a incognito session to ensure caching does not interfere here?
        Also if you want us to take a direct look, send us a mail to support@cloudron.io with remote support enabled https://docs.cloudron.io/support/#remote-support
        humptyH 1 Reply Last reply
          humptyH Offline
          humptyH Offline
          humpty
          @nebulon said in Login does not work anymore - White page:
          Does that mean we can’t log in with our Cloudron users anymore? If so, how do we log in? Sorry for the noob questions but I never used oidc before.
            Only the login method is changed. Since Cloudron is now also an OpenID provider, we are moving apps one-by-one from LDAP to OpenID connect where possible. This allows for a real single sign on experience.
            • P Offline
              P Offline
              Patmo.de
              Thanks @robi and @nebulon for your quick replies. I read about the switch to oID (maybe not focused enough), and I was unsure about how this affected my installation.
              I tried firefox (normal + private), chrome and edge and the results were all the same - a white page instead of a login form. I will retry it in the middle of the upcoming week and see, if there are any add-ons or browser plug-ins that keep the form from showing up/loading.
                @Patmo-de I just installed Surfer 6.0 on the demo Cloudron and was able to log into the admin page.
                I did notice that the page had to redirect to the new oidc URL, but still brought up the username/pw form.
                You can try it there yourself.
                • P Offline
                  P Offline
                  Patmo.de
                  Thanks, @robi. I tried it in the demo Cloudron, too. Everything was in place. The only difference I could spot is, that I am on v7.4.3 (Ubuntu 22.04.1 LTS) on my server, while the demo is on v7.5.0 (Ubuntu 20.04.4 LTS). I will dig deeper into this in the middle of the next week, when there is more time (an no more deadline approaching).
                  • N Offline
                    N Offline
                    natzilla
                    I get the white page while it attempts something, and then I get hit with the page
                    status "Internal Server Error"
                    message "Issuer.discover() failed.\n RequestError: connect ECONNREFUSED x.x.x.x:443\n RequestError: connect ECONNREFUSED x.x.x.x:443"
                    girishG nebulonN 2 Replies Last reply
                    • N natzilla
                      @natzilla Are you on Cloudron 7.5.0 and are you able to login to Cloudron dashboard itself?
                      N 1 Reply Last reply
                        N Offline
                        N Offline
                        natzilla
                        @girish ahh, I'm on 7.4.3, is 7.5 required? And yes I can access the cloudron management.
                        • N natzilla
                          @natzilla It's not required, but I was wondering if this was related to oidc in general. In 7.5.0, the cloudron dashboard has also moved to oidc. Best to stick to 7.4.3 till we figure this out because you may not be login altogether with 7.5.0.
                          Next question is if you are on a private network. OIDC requires apps to be able to access the dashboard which is of course on the very same server . Is there some custom DNS setup or something you can think of?
                            N Offline
                            N Offline
                            natzilla
                            @girish thanks for the heads up. I disabled auto updates for now. As far as my dns goes, no I don't have anything special just normal a records.
                            This particular setup has two domains on it, but I would think that wouldn't be a factor.
                            As far as my Ubuntu version it's on 22.04.2.
                            • N natzilla
                              @natzilla 7.5.0 won't auto update , so it's not a problem. But if you can write to support@cloudron.io we can debug this further.
                              • N natzilla
                                @natzilla hm this may be related to the app trying to fetch a resource from the dashboard from whithin the app. I have seen some network setups where this wasn't working.
                                  N Offline
                                  N Offline
                                  natzilla
                                  @girish I'll send in a ticket through the cloudron dashboard.
                                  • P Offline
                                    P Offline
                                    Patmo.de
                                    Hi. I only figured out my original problem with surfer (and suddenly with other apps too) about one or two months ago and it was because I was missing some points that are detailed here: https://forum.cloudron.io/post/78855 Thanks to @Jan-Macenka for sharing his thoughts and tipps. I put this here in case of others with "old installations" searching for similar topics.
