  3. Besoin d'Aide pour Installer Cloudron sur SSD et Applications sur Disque Dur / Title: Need Help Installing Cloudron on SSD and Applications on Hard Drive
installationvolumes
3 Posts 3 Posters 1.2k Views 3 Watching
  • M
    mathieula1
    French Version
    Bonjour, je suis nouveau avec Cloudron et avec Linux. J'ai un ordinateur avec un SSD et un disque dur. Je voudrais savoir s'il est possible d'installer Cloudron sur le SSD et les applications sur le disque dur. Merci.
    English Version
    Hello, I am new to Cloudron and Linux. I have a computer with an SSD and a hard drive. I would like to know if it is possible to install Cloudron on the SSD and the applications on the hard drive. Thank you.
    • necrevistonnezrN
      necrevistonnezrN
      Super Fan
      The app itself needs to be on the main volume AFAIK, the app data can be moved to a volume, e.g. the HDD, see https://docs.cloudron.io/volumes/
      If you’re both new to Cloudron and Linux, it’s possible that you experience some frustration along the way - Cloudron is as ‚easy‘ as it gets for self-hosting but still requires some background knowledge.
        To add to what @necrevistonnezr said, add the hard drive as a Cloudron volume and use https://docs.cloudron.io/apps/#data-directory to move the app's data into that volume.
