  3. ERPNext - cost-effective ERP solution
124 Posts 38 Posters 161.3k Views 43 Watching
  • L LoudLemur
    @girish said in ERPNext - cost-effective ERP solution:
    TBH, I don't think we will be able to support this sort of selfhosting complexity.
    Cloudron does brilliantly at hosting Nextcloud, which I think is a somewhat similar, complex application. What is it about Nextcloud which makes it possible where ERPnext is too tricky?
    @LoudLemur you can see this post by @nj who already spent 100+ hours on this. The app also (when previously investigated) required database admin credentials and had restrictions on how username/password is created etc. All this makes it basically unviable for selfhosting imo, in general. I am sure it can be made to run with Cloudron with a lot of effort , but it's not worth it (for us).
    • timconsidineT
      Totally understand @girish
      My 2p : "big" systems deserve their own dedicated deployment, e.g. own VPS
        @JLX89 doesn't seem like it's easy to host this on Cloudron yet. TBH, I don't think we will be able to support this sort of selfhosting complexity.
        JLX89
        @girish Thank you for following up! Yes, that makes total sense.
        • nileshN
          nileshN
          nilesh
          @girish Were these issues ever reported to ERPNext? I couldn't find any mention of cloudron ever in their repository: https://github.com/frappe/erpnext/issues?q=is%3Aissue+is%3Aopen+cloudron
          • nileshN
            nileshN
            nilesh
            • M makemrproper referenced this topic on
            • Z
              Z
              zonzonzon
              Is the ERPNext package on Cloudron still operational at this point? It has been a long time since I’ve seen any updates on this topic @nj
              • njN
                njN
                nj
                wrote on last edited by nj
                #107
                Yes, the package still works.
                New Installation using my image
                To directly install ERPNext if you haven't previously, use this command:
                Remember to replace <yourdomain.com> with youre actual domain.
                cloudron login my.<yourdomain.com>
                cloudron install --image njsubedi/cloudron-erpnext -l erp.<yourdomain.com>
                Open the file manager to look for the credentials.
                If you need to login with LDAP, you can do that by using the terminal of this app, and run /app/pkg/setup-ldap.sh add
                Otherwise, that's all you need to do.
                Updating
                If you previously used ths app and want to continue using version-14, you need to do is run gosu cloudron bench update --reset once in a while to keep things up to date.
                Now, I have upgraded the code to use version-15 by default.
                If you were previously running on version-14 and now need to update to version-15 that's pretty easy too.
                Just run gosu cloudron bench switch-to-branch version-15 frappe erpnext --upgrade
                Then run gosu cloudron bench migrate
                Founder / Coder • My Apps
                B 1 Reply Last reply
                • Z
                  Z
                  zonzonzon
                  @nj Hello, what is the most optimal method for backing up data from Cloudron currently, especially for ERPNext on Cloudron? Thank you.
                  • njN
                    njN
                    nj
                    #109
                    Currently, the data is automatically backed up. But I have also setup S3 backup to BackBlaze just to be double sure. Cloudron backup can be used for full restore of the site. It contains the database, files, and everything. ERPNext backup can be used to restore to a fresh installation.
                    Cloudron Auto Backup
                    S3 Backup Settings in ERPNext
                    PS: I would highly recommend utilizing your cloud provider's "Automatic Backup" or "Automatic Snapshot" feature that allows you to automatically backup the whole VPS everyday. This way you have redundant backups. Make sure to use multiple vendors. For eg: if you host your VPS on AWS,
                    1. Use AWS's automatic VPS backup system
                    2. Configure Cloudron backups to say, DigitalOcean spaces
                    3. Configure ERPNext backups to say, Backblaze
                      If all three are in a nearby region, latency won't be an issue, and you'd hardly ever deal with data loss, unless all three cloud providers close your account on the same day.
                    • Z
                      Z
                      zonzonzon
                      @nj Thank you very much. I will follow your guidance. Have a great day.
                      • andreasduerenA
                        andreasduerenA
                        andreasdueren
                        What's keeping this from being officially packaged and offered in the App Store?
                          @andreasdueren I'm not sure, but I think perhaps most of this still applies:
                          https://forum.cloudron.io/post/59314
                          • njN nj
                            Updating
                            B
                            B
                            BetaBreak
                            wrote on last edited by BetaBreak
                            #113
                            @nj thanks for packaging this application. It is very much needed!
                            When I try to install, using your instructions, it I get the error:
                            No CloudronManifest.json found
                            Do you know what I could be doing wrong? Do I need to first pull the image from dockerhub?
                            Thanks!
                            • P
                              P
                              plusone-nick
                              @BetaBreak is https://github.com/njsubedi/cloudron-erpnext/blob/master/CloudronManifest.json in your root dir?
                              ✌💙+1
                              B Z 2 Replies Last reply
                              • P plusone-nick
                                B
                                B
                                BetaBreak
                                #115
                                @plusone-nick I downloaded the zip file from https://github.com/njsubedi/cloudron-erpnext locally on my computer and cd in that folder. Than I used the instruction provided by @nj https://forum.cloudron.io/post/87732 to get it running on cloudron.
                                • P
                                  P
                                  plusone-nick
                                  Noted, focusing on the error - is the CloudronManifest.json file currently in the system? As the output is suggesting the file is not there, maybe it's gone 🤷‍♂️
                                  ✌💙+1
                                  Z 1 Reply Last reply
                                  • P plusone-nick
                                    Z
                                    Z
                                    zonzonzon
                                    @plusone-nick You need to load the CloudronManifest into the root directory on your computer and run the installation command from that root directory.
                                    • P plusone-nick
                                      Z
                                      Z
                                      zonzonzon
                                      @plusone-nick Yes, you need to download everything and put them all in one folder, then try to run the installation command from the folder containing these files. (Cloudron CLI on Windows)
                                      • I igaudette referenced this topic on
                                      • M
                                        makemrproper
                                        wrote on last edited by makemrproper
                                        #119
                                        Any hope at all?
                                        I need business applications and it would be great to leverage Cloudron beneath them. Therefore ExpNext and Odoo would add so much value to the portfolio of applications offered through Cloudron.
                                        Yes there is Dolibarr, but it is not adequate.
                                        Cloudron fan
                                        Paying Customer
                                        • M makemrproper
                                          Any hope at all?
                                          @makemrproper Use EspoCRM
                                          M 1 Reply Last reply
